Old Feb 12, 2004, 04:11 PM
astroboy is offline
Find More Posts by astroboy
Superhero, Third Class
astroboy's Avatar
Carson City, NV
Joined Nov 2000
Styrene vs. ABS
Are there any advantages to one over the other in vacuforming cowls, wheel pants, and the like? Does ABS require a special adhesive?
Also, is it easy to tell the two apart by sight? I just received an order of what was supposed to be styrene. He had written on one sheet "styrene and ABS(Darker)." There were a few sheets that were a little darker white than the others, but the main difference was that some sheets had a matte finish, while others were fairly glossy.
Jeff
astroboy is offline Find More Posts by astroboy
Old Feb 12, 2004, 06:56 PM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
ABS is a form of styrene: Acrylonitrile-butadiende-styrene
There is no plastic that is actually just pure styrene as that is a liquid. The name styrene usually is used to refer to either ABS or Polystyrene which is the simplest form of polymerized (plastic) styrene. Polystyrene would not be a good choice for vacuum forming because it is too brittle. Plastic scale models are an example of ordinary polystyrene.
ABS on the other hand is very flexible and impact resistant. You probably actually have ABS. You may be able to tell if its polystyrene if a sample snaps easily when bent double (depending on thickness)
Gerald is offline Find More Posts by Gerald
Old Feb 13, 2004, 03:29 PM
astroboy is offline
astroboy's Avatar
Carson City, NV
Joined Nov 2000
Thanks, Gerald. The guy I ordered it from said there was little difference between the ABS and the (poly)styrene. I wonder if it could be what I've heard called "High Impact Polystyrene." I'll try your test tonight.
Jeff
Old Feb 16, 2004, 03:56 PM
astroboy is offline
astroboy's Avatar
Carson City, NV
Joined Nov 2000
Well, I took a strip each of "ABS" and "PS", 1/4" wide and a couple inches long, and bent them double. The ABS didn't break; the crease turned white, which I recall reading many years ago is what ABS does when it reaches the point of no return, bend-wise. The PS broke, but it didn't snap. When I creased it, it just fractured and broke in two.
Jeff
Old Feb 16, 2004, 04:44 PM
Gerald is offline
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Looks like you confirmed that you've got some of each kind. Use the ABS for vacuum molding.
wood vs abs blades on T-rex luc Mini Helis 5 Oct 16, 2005 05:37 PM
