Old Sep 02, 2013, 10:54 AM
9Mach is offline
Find More Posts by 9Mach
Joined Jan 2013
Push Rods and Threads
Start
A 2-56 rod is supposed to be a #2 diameter thread with a pitch of 56 threads per inch (TPI). That is a nominal .086" diameter (44 Gauge) for a class 2A thread. The class determines the thread depth with a lower number being less depth and strength and a more sloppy fit. Number sizes are in .013" increments so a #1 would be .073" and a #5 would be .125" (1/8"). All of the factory rods I have seen have a ROD size of .072". I think the threads are rolled and not cut at the factory. I am guessing that rolling will squeeze the hot metal to form the threads. If we thread this rod with a 2-56 die, the thread size would be cut to .072 instead of .086". This would be a loose fit and not as strong. It looks like to cut your own threads you would need a .086" rod diameter.
This chart: http://www.engineersedge.com/screw_threads_chart.htm
does show a minor diameter of .0635". Does that mean that threading the .072" rod with a 2-56 die is plenty good for strength? Has anyone done this and had a rod pull out?
Do the metric rods have the same problem?
Does anyone know the thread pitch of 1.3mm rod and where a die can be purchased? Will the rod diameter be too small to cut the threads to the proper diameter like the #2 rod?
I have some Hobby King unthreaded rod that measures .058" diameter. Best I can measure, could be .0582? What die would be used to cut threads for this rod? Are there any ball links that would fit this?
9Mach is offline Find More Posts by 9Mach
Old Sep 02, 2013, 12:05 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
BA Outer
Diameter[1]:7, 16 Threads
per inch Threads
per mm Tap drill
0 0.2362 in / 6.0 mm 25.38 1 5.1 mm / 7 gauge
1 0.2087 in / 5.3 mm 28.25 1.112 4.5 mm / 16 gauge
2 0.1850 in / 4.7 mm 31.35 1.234 4.0 mm / 21 gauge
3 0.1614 in / 4.1 mm 34.84 1.372 3.4 mm
4 0.1417 in / 3.6 mm 38.46 1.514 3.0 mm
5 0.1260 in / 3.2 mm 43.10 1.697 2.65 mm / 37 gauge
6 0.1102 in / 2.8 mm 47.85 1.884 2.3 mm
7 0.0984 in / 2.5 mm 52.91 2.083 2.05 mm / 46 gauge
8 0.0866 in / 2.2 mm 59.17 2.330 1.8 mm
9 0.0748 in / 1.9 mm 64.94 2.557 1.55 mm
10 0.0669 in / 1.7 mm 72.46 2.853 1.4 mm / 54 gauge
11 0.0591 in / 1.5 mm 81.97 3.227 1.2 mm
12 0.0512 in / 1.3 mm 90.91 3.579 1.05 mm
Stuart A is offline Find More Posts by Stuart A
Old Sep 02, 2013, 12:09 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
I don't think 1.3 mm die is standard size.1.2/1.4 are.BA is metric based.
Old Sep 03, 2013, 07:07 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I've been cutting my own 2-56 and 4-40 threads for 20 years and never had a thread skip or strip. Always back up a metal clevis with a nut and lock washer.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Sep 03, 2013, 07:31 AM
9Mach is offline
Joined Jan 2013
What size rods do you use?
Old Sep 03, 2013, 07:43 AM
edwin1 is offline
Joined Sep 2003
Dont know right off the top of my head. They are leftover cuttings from pre threaded rod. There are two types, one is very hard and cannot cut threads into it, the other is soft enough to cut threads yet hard enough to use as pushrods.
Edwin
The hard ones are shiney, the softer ones are a dull grey.
Old Sep 03, 2013, 11:17 AM
9Mach is offline
Joined Jan 2013
I am guessing the shiney ones are stainless steel. Can you measure them sometime and post back when you have a chance?
Old Sep 03, 2013, 01:16 PM
edwin1 is offline
Joined Sep 2003
Dull grey;
2-56 is .073
4-40 is .092
Shiney steel (pre cut threaded ends);
2-56 is .073
4-40 is ??? I didnt have any in my parts bin.
When I need both ends threaded on the shiney steel, I use the solder on threaded ends. Soldered correctly, they wont come off.
Edwin
Old Sep 03, 2013, 09:11 PM
9Mach is offline
Joined Jan 2013
Thanks!
Discussion Pull Spring vs Pull Pull vs Push Rod for rudder elevator hog2soar Hand Launch 113 Mar 05, 2013 06:07 AM
Sold PZ Sukhoi Wing + Tail Set + Push rods scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 17, 2013 06:38 PM
Yippee! .8mm (1/32") shrink wrap for micro push rods glenn2626 Scratchbuilt Indoor and Micro Models 1 Jan 14, 2013 11:26 PM
Discussion Push-pull rods gimbal to belt driven. DYORD Multirotor Electronics 0 Jan 08, 2013 12:17 AM
Help! My push rods arent working in my champ can someone help me. joeIII Electric Plane Talk 5 Jan 04, 2013 07:12 PM
