Old Feb 12, 2004, 11:10 AM
Rackey is offline
Find More Posts by Rackey
Rackey's Avatar
Savannah, Ga
Joined Apr 2002
Can I charge my deep cycle battery at the same time I am using my triton?
I have a deep cycle marine battery that I use for charging my NiMh batteries with my triton charger. Between flying sessions I charge the deep cycle PB battery using a standard auto battery charger. Can I hook up the auto charger to the deep cycle and at the same time use my triton?
It seems to me that I could charge the deep cycle and use the triton at the same time because I use my car battery for the triton while the engine is running and the alternator is charging the battery in the car. Before I give it a try, just want to make sure. Thanks,
Rackey is offline Find More Posts by Rackey
Old Feb 12, 2004, 11:25 AM
rkramer is offline
Find More Posts by rkramer
Frequent flyer
Grand Forks, ND
Joined Aug 2002
should be fine. occassionally a charger might put out really noisy power that could confuse the charger, the batt should absorb most of that but watch the triton for signs of false peaks and such for the first couple packs.
rkramer is offline Find More Posts by rkramer
Old Feb 12, 2004, 12:49 PM
uscra112 is offline
Find More Posts by uscra112
Mid-Michigan
Joined Aug 2002
I do it all the time, but not with a Triton. Shouldn't cause you any trouble. The battery itself will dampen out any spikiness that the charger is putting out.
uscra112 is offline Find More Posts by uscra112
Old Feb 12, 2004, 03:46 PM
bzzboy is offline
Find More Posts by bzzboy
Portland, OR metro area
Joined Aug 2003
The only issue i've had charging my car battery (not in a vehicle- just a heavy duty automotive battery) while using the Triton is that if i charge it at 10 amps while using the Triton, the Triton will fault for "input voltage error". Probably too high due to the high input current to the auto battery. May be a unique situation relating to my battery/charger...
Charging at 2 amps, however, i've never had an issue.
bzzboy is offline Find More Posts by bzzboy
Old Feb 13, 2004, 11:32 AM
MAKODS is offline
Find More Posts by MAKODS
N.Y.
Joined Jan 2003
I charge my deep cycle at 10amps while charging packs with my Triton and have had no problems.
MAKODS is offline Find More Posts by MAKODS
Old Feb 13, 2004, 12:55 PM
rkramer is offline
Frequent flyer
Grand Forks, ND
Joined Aug 2002
it is possible the charger is leaking high frequency AC at higher voltage out when charging at 10 amps, the triton sees that as high input voltage, while a dc DMV may not see it.
anyway, original poster... give it a try, see if it works. your chance of damaging anything is very small.
Question Can I charge my 35Ah Gel cell at 6Ah or even 12Ah??? tommyt Batteries and Chargers 8 Jan 26, 2015 05:52 PM
Can you fly two RC planes at the same time? ghoti Electric Plane Talk 28 Feb 09, 2011 02:08 PM
can I run two battery packs on one plane, at the same time? e-sailpilot86 Power Systems 8 Mar 08, 2008 07:36 PM
Discussion Can I use a Wired & Wireless Router at the same time? mrebman Life, The Universe, and Politics 14 Dec 19, 2006 10:38 AM
Looking for a charger that can charge more than one battery pack at a time thor4944 Batteries and Chargers 10 May 02, 2003 01:05 PM
