Old Sep 01, 2013, 02:31 AM
tomcor is offline
Find More Posts by tomcor
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
Mini-HowTo
Blade Nano Qx led headlight Mod
I just added a headlight to my QX. Used a white surface mount led from a 3520 size led strip light. It is powered off the flight battery.
There are 2 solder point on the FC board as shown in the pictures. The red wire from the board goes to the positive lead on the led. Blue wire is negative is soldered to the negative point on the led. I didn't use a resistor at all. I trimmed the led strip with scissors to make it smaller. The led strip has adhesive backing to stick the led to the front beam.
The red positive solder point is on the very edge corner of the board. The blue negative point is right next to the negative battery lead.
I used insulated thin magnet wire to make the connections.
Makes a nice bright headlight and very little weight.
Description:
Description:
Description:
tomcor is offline Find More Posts by tomcor
Old Sep 14, 2013, 04:21 PM
groan is offline
Find More Posts by groan
dead sexy
groan's Avatar
Canada, ON, Ottawa
Joined Nov 2006
Attachment 6068529
Attachment 6068531
Attachment 6068532
Any loss in flight time? Now I get about 6.5 minutes with no mods using stock everything. TX included.
groan is offline Find More Posts by groan
Old Sep 19, 2013, 05:48 AM
tomcor is offline
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
I don,t see any loss of flight time. Flys 5-6 mins on eflite 150's.
Old Sep 19, 2013, 05:58 AM
groan is offline
dead sexy
groan's Avatar
Canada, ON, Ottawa
Joined Nov 2006
Great, are the lights readily available?
Old Oct 02, 2013, 07:41 PM
poiyt is offline
Find More Posts by poiyt
United States, GA, Newnan
Joined Aug 2010
nQX LIGHTS!!
Attachment 6068529
Attachment 6068531
Attachment 6068532
Tomcor this is BRILLIANT (excuse the pun!!!)
Seriously, I'l like to get an nQX, but even my Hubsan had 2 blue led 'eyes'...so the nQX gotta have some light somewhere!!
Thx 4 the pix they'll b my soldering guide
poiyt is offline Find More Posts by poiyt
Old Oct 08, 2013, 02:27 AM
tomcor is offline
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
I am just using one led from a set of led strip lights. You can use any surface mount led to do this and just glue it on the beam. The headlight is really bright without a resistor. You can add a smd resistor around 150 ohm to make it not so bright.
Old Oct 15, 2013, 06:46 AM
mphsjeep is offline
Find More Posts by mphsjeep
mphsjeep's Avatar
United States, TN, Memphis
Joined Dec 2004
Perfect.......my NQX is on the way and this mod is bumped to the top of my "ToDo" list....which is a ton more important than my "Honeydo" list(in my mind)....
Thanks for the pics...will also be my guide
mphsjeep is offline Find More Posts by mphsjeep
Old Oct 22, 2013, 02:11 AM
zeek_911 is offline
Find More Posts by zeek_911
Venting Invent
United States, MO, Springfield
Joined Dec 2006
Clean and simple. Now for a brake light!!!
zeek_911 is offline Find More Posts by zeek_911
Old Nov 02, 2013, 11:07 AM
mphsjeep is offline
mphsjeep's Avatar
Joined Dec 2004
I went straight to the wires...pic attached. Thanks for idea!!!!!!!!
Old Nov 03, 2013, 08:24 PM
daheat43 is offline
Find More Posts by daheat43
United States, CO, Golden
Joined Sep 2011
Very cool! Thanks for the idea and the pics!
daheat43 is offline Find More Posts by daheat43
Old Dec 10, 2013, 03:40 AM
LMahesa is offline
Find More Posts by LMahesa
Ia! Ia! Cthulhu Fhtagn!
LMahesa's Avatar
Indonesia, Jakarta
Joined Jul 2013
Nice, thanks for that. Why those two points, vs the battery connection points?
LMahesa is offline Find More Posts by LMahesa
Old Jan 26, 2014, 06:58 AM
muidaq is offline
Find More Posts by muidaq
USA, OH, Westerville
Joined Aug 2007
Thanks for posting this. It helped me get rid of extra connectors and wire in the sf designs kit, which got me about 30 seconds more flight time. I'm guessing resistance more than weight, but not sure.
Why not the battery connection points? It's covered in a glob of goo.
muidaq is offline Find More Posts by muidaq
Old Mar 13, 2015, 07:20 AM
RaymondM is offline
Find More Posts by RaymondM
Multirotor Promotor
RaymondM's Avatar
United States, MI, Cadillac
Joined Apr 2011
Nice Job thanks!
RaymondM is offline Find More Posts by RaymondM
New Product NEW Blade Nano QX RCaDDiCT! Mini Multirotors 8090 Today 09:17 AM
News Blade Helis: Nano QX Tip and Tricks awagar Multirotor Talk 34 Apr 10, 2015 12:03 PM
Sold Blade Nano QX RTF. vacahtu Aircraft - Electric - Multirotor (FS/W) 4 Jun 27, 2013 03:29 PM
Sold Blade Nano QX RTF. vacahtu Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jun 25, 2013 10:52 PM
Sold Blade Nano QX RTF. vacahtu Aircraft - General - Miscellaneous (FS/W) 0 Jun 25, 2013 07:58 PM
