Closed Thread
This thread is privately moderated by eirlink, who may elect to delete unwanted replies.
Old Aug 31, 2013, 04:27 PM
eirlink's Avatar
Ireland
Joined Mar 2013
Data
Dji Naza Error Codes
Error Codes and how to fix them
LED Sequence = Red Green Orange
This is also known as the Acc Y ERROR - ERR{26}
The Fix:
This type of error is caused by the NAZA being subjected to a crash or a gross hard G knock.
To fix this remove the NAZA from theairframe ; disconnect the naza wiring - apply a sharp G force to it (tapping it once briskly against a table top) - re-install and check the result.
Heres a list of other error codes....
CFG-ERR
Configuration error, this may cause by firmware upgrade from old version. or abnormal Tx calibration. Re-calibrate your transmitter, and power cycle your controller and check all of the parameters.
VOL-LOW [4]
Voltage low
SN-ERR
Your S/N is not available, Please contact our support!
VOL-LOW[6]
Voltage low
IMU-ERR
IMU ERROR,Please contact dealer or DJI for repair.
X1-ERR
Youíve chose parameters tuning by X1/X2 channel with Tx Knob, but no signal detected on X1/X2 input channel, or Tx didnít powered on.
X2-ERR
PMU-ERR
Please check the connection among battery, MC and PMU.
RX-ERR
Please may sure you select the right receiver type in the RC page or check the receiver connection, after that power cycle your controller to take effect.
COMPASS-ERR
Compass data is abnormal, please restart your Controller, if you still get this error, please contact the agent.
ERROR [25]
IMU initialization failure, may caused by crash. Please contact dealer or DJI for repair.
ERROR [26]
Please perform Advanced Calibration.
ERROR [27]
GPS not calibrated, or magnetic field interference. Please calibrate GPS again in good conditions.
eirlink is offline Find More Posts by eirlink
Closed Thread
Discussion TBS Disco + DJI Naza V2 - Red Yellow light error Toffe87 Multirotor Talk 9 Mar 18, 2014 02:15 PM
Discussion DJI Naza-M Assistant Software Error Code List DJI INNOVATIONS Multirotor Talk 0 Feb 22, 2013 05:28 AM
Build Log DJI F550 NAZA ARF COMPLETE BUILD and DJI NAZA ASSISTANT w/ TX CALIBRATION >VIDEOS< patrick21x Multirotor Talk 11 Nov 30, 2012 07:13 PM
Discussion dji naza error code vol low 4 homersainty Multirotor Talk 1 Jul 22, 2012 09:04 AM
Help! DJI Naza f550 RX Error help please! volcomsnows2k Multirotor Talk 7 Mar 28, 2012 01:32 AM
