Old Feb 11, 2004, 09:20 PM
asjeep is offline
Find More Posts by asjeep
Joined Jan 2004
Question
anybody have any experience with these chargers?
I will be running a zagi, brushless aveox motor with 40a esc, 9.6v 1950 mah batteries
any idea how fast it will charge?
thanks
http://www2.towerhobbies.com/cgi-bin...?&I=LXCLD5&P=0
FEATURES: AC/DC convenience is great for use at home or at the track
Peak charges 1-8 NiCd or NiMH cells.
Peak charge current adjustable from 0.1 to 5 amps (3 amps with AC)
Two-line, 16-character LCD display for easy programming and data
display
Displays battery voltage, peak detection mV, charge time, current,
and capacity
Adjustable peak detection sensitivity or "threshold" from 3mV-20mV,
to custom match the charger to specific batteries
Automatic charge mode changes if specific setting are not pre-set
Selectable TRICKLE charge rates - 0, 100mA, 200mA
Displays errors for improper input voltage, poor battery connections,
and reverse polarity on the output
Store pre-set charge parameters in memory for 10 battery types
Multiple sound cues and melodie
Microprocessor controlled intelligence and reliability
Solid State reverse polarity and short circuit protection on
input and output
INCLUDES: One charger
One Battery Lead (Kyosho Connector)
One Instruction Packet
REQUIRES: Power Source
SPECS: Inout Voltage: 110V AC 60 Hz, 11-15V DC
Cell Types: NiCd and NiMH
Cell Count: 1-8
Peak Charge Rate: 0.1- 5.0 A (3.0 A with AC power source)
Charge rate increments: 0.1 A (100mA)
Fast charge termination: zero delta peak ( 3 - 20mV/Cell)
TRICKLE charge rates: 0, 100mA, 200mA Selectable
Output connectors: spring-loaded terminals
Case Size: 5"x3.4"x5.5" (127x86x140mm)
Weight: 2.94 lb (1335g)
COMMENTS: None
asjeep is offline Find More Posts by asjeep
Old Feb 12, 2004, 11:01 AM
asjeep is offline
Joined Jan 2004
anyone?
Old Feb 12, 2004, 12:52 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Sure - charge at 1C, it will take 1 hour, charge at 2C, it will take 1/2hr. 1C = 2A, 2C=4A
Before putting money into a NiCd/NiMH charger, consider that LiPo's need a charger that has Lipo parameters, like a Triton. Just a thought in case you decide to use lipo's in a couple of months or a year....you might think about getting a charger that does those and lipo's
hoppy
hoppy is offline Find More Posts by hoppy
Old Feb 12, 2004, 12:54 PM
sawitt is offline
Find More Posts by sawitt
United States, CA, Brea
Joined Dec 2000
I don't have this charger so I have no experience with it, but assuming it is a fairly good charger the more important point is what kind of batteries are they.
Most NiCd can be recharged at 3C, which is 5.85A for these batteries. So on DC power the charger will charge 5A max, which is within the range of safe recharging for those batteries. So 1.95AH divided by 5A yields 0.39 hours, or 23 minutes. That is most optimistic as it assumes a constant 5A recharge rate, and most chargers don't supply this all the time depending upon their charging programming and it does not account for electrical losses. So my estimate would be about a half an hour. On AC power the charger is only providing 3A, so the recharge time would be longer.
Most NiMH batteries can be recharged at 1C, so it will take an hour to recharge the battery if you set the charger's charge current to 1C (1.95A), which is the safe thing to do.
sawitt is offline Find More Posts by sawitt
Old Feb 12, 2004, 12:59 PM
asjeep is offline
Joined Jan 2004
thanks for the responses...
i bouth a nihm pack, but more than likely i will be buying some nicd's too
Has anybody had any experience with these... papasmurf 3D Flying 7 Sep 26, 2005 04:35 AM
anybody have any experience with OS film? may-day Scratchbuilt Indoor and Micro Models 5 May 28, 2005 08:36 AM
Does anybody have any experience with the Mega 16/25/xx series Masterpiece Power Systems 14 Oct 30, 2003 11:04 AM
Any experience with these solar cells? yb2normal Power Systems 9 Mar 15, 2002 07:37 AM
Has anybody had any experience with Hobby Club? tempest411 Vendor Talk 6 Feb 21, 2002 09:06 AM
