Make Your Own Scale Wire Lobster Traps
Learn how to make wire lobster traps for your scale boat!
Here is a great "how-to" by RCGroups.com user Sound Sailer:
Some time ago I offered to email this info to the limited number of folks interested, and did so. The question arose again today on how to make the wire traps I have on my model "Claws" so here tis. The materiel I used is 1/4" hardware cloth which is a wire screening with square openings. Should be available at most home center or hardware stores. I got mine at HD. In real life wire traps come in a few different sizes but I chose the 3'x2'x15" size and was making 1:12 scale.
I made a paper template like the photo below and then laid it on the hardware cloth and cut it out. You can use tin snips, diagonals, heavy scissors or any other tool you might have that will cut the wire. before cutting decide how you want to fasten the folded edges together. You could do that with separate small wire or monofilament tied or woven through the joints or else when you make the cut of the pattern leave nubs where indicated to fold over as fasteners. After cutting out the wire T shape make folds where indicated first folding the 3 long folds up to form a sort of square tube and then folding the ends up to make a box. Bending against a straight edge such as a metal ruler where the bend will go helps make a nicer bend. Fasten the ends together using either methods discussed and then cut out an opening on the left side of one of the 15" high sides you can also make the escapes on the opposite end of the trap which are the red painted areas in the photo.
Traps made this way are good enough to the eye for boats that are run RC often. A real trap would have a netted divider separating the trap into a parlor and the kitchen and you could add that if so inclined as well as a netting at the entrance, a top opening and weights if you really want to go scale or making a display model. You would want to add those details before fastening the folded sides. I did not go that far and it is obvious to onlookers that they are lobster traps without having all the details. Hope you all find this informative and helpful.
Edited to add that the reason for making the template rather than just cutting out the wire is that you most likely are going to make several traps rather than just one so the template saves time measuring out each pattern. Bill
I'll throw in a bonus detail tip for you lobster boat builders. A small diameter yellow shrink wrap tube cut into slices make good claw bands.:cool:
Old Aug 28, 2013, 05:34 PM
louie R/C NUT is offline
Find More Posts by louie R/C NUT
no such thing as to many boats
louie R/C NUT's Avatar
United States, NY, New York
Joined May 2010
Cool Bill thanks for the info .
louie R/C NUT is offline Find More Posts by louie R/C NUT
Old Aug 28, 2013, 06:26 PM
Band1 is offline
Find More Posts by Band1
Band1's Avatar
United States, NY, Queens County
Joined Oct 2011
They sure look good Bill, you and Steve have the best lobster traps in the fleet !
Band1 is offline Find More Posts by Band1
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Nice!
Kmot is offline Find More Posts by Kmot
Old Aug 28, 2013, 07:16 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Attsa Nice Work !
Tim B. is offline Find More Posts by Tim B.
Old Aug 28, 2013, 07:23 PM
STONECRAB is offline
Find More Posts by STONECRAB
Crackin' Claws
STONECRAB's Avatar
United States, FL, Oviedo
Joined Oct 2012
Thanks, Bill.
Got to make some of those.
STONECRAB is offline Find More Posts by STONECRAB
Old Aug 28, 2013, 07:26 PM
Bob SF is offline
Find More Posts by Bob SF
Bob SF's Avatar
USA, CA, San Francisco
Joined Aug 2003
Hi Bill,
Thanks for sharing! I'll be making some soon. Very cool idea.
Bob SF
Bob SF is offline Find More Posts by Bob SF
Old Aug 28, 2013, 07:41 PM
chum444 is offline
Find More Posts by chum444
lots of water; some of it thin
chum444's Avatar
United States, MA, Woods Hole
Joined Aug 2012
Finest kind...Ayuuh!
chum444 is offline Find More Posts by chum444
Old Aug 28, 2013, 08:14 PM
sound sailor is offline
Find More Posts by sound sailor
Plures Naves Quam Mentes
sound sailor's Avatar
United States, NY, Westchester
Joined Jul 2011
Wanted to show my wood traps so you get the idea of the netting. Not sure if you can see the net divided the parlor and kitchen. I do know you can't see them in the photo but I painted small wood blocks with brick red to represent the weights. The netting, which you could use in either the wire or wood, is from one of those bath louffa things. It is stretchy so you can sort of shape it or make the openings larger.
After opening the photo once you can click on it two more times to get a larger photo and see the netting better.
Bill
sound sailor is offline Find More Posts by sound sailor
Old Aug 28, 2013, 08:19 PM
needabiggerboat is offline
Find More Posts by needabiggerboat
needabiggerboat's Avatar
Joined Feb 2012
Very nice Bill There is just one thing missing Bill, and that would be the tip cup! Thank you for sharing with us!
Doug
needabiggerboat is offline Find More Posts by needabiggerboat
Old Aug 28, 2013, 08:20 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Thank's for reposing, as they look great! I printed it this time. Charlie
CaptCB is offline Find More Posts by CaptCB
Old Aug 28, 2013, 08:29 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Yes, thanks for this, Bill- these can be the most tedious part of a crab boat but a most important detail- your process produces great results
Aerominded is offline Find More Posts by Aerominded
Old Aug 28, 2013, 10:05 PM
DDWILLIE is offline
Find More Posts by DDWILLIE
United States, MA, Haverhill
Joined Aug 2011
Been "a lookin" for a nice, simple sketch or plan for traps for sometime and this sure fits the bill. Traps are what make the boat! I am attaching a pic of my scratch built 30" lobster boat that I will be building the traps for. I would have posted more pics, but for some reason I could only attach 1. They have changed the attachment procedure since I last posted pics and I haven't figured it out yet. Thanks a lot for sharing.:
DDWILLIE
DDWILLIE is offline Find More Posts by DDWILLIE
Old Aug 29, 2013, 01:36 AM
jerryj98501 is offline
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
Thanks for the repost. This time I have printed it off and have it in two places, the most important on the rear deck of my lobster boat. Nice tutorial. Jerryj98501
jerryj98501 is offline Find More Posts by jerryj98501
Old Aug 29, 2013, 06:38 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Here is a wooden trap I had to make for a boat built.
Trap is about 1 1/2" long
Jerome Morris is offline Find More Posts by Jerome Morris
Sold Ace R/C Noise Trap & Pulse Amplifier Set Rosster Aircraft - General - Radio Equipment (FS/W) 0 Jan 20, 2013 02:35 PM
Discussion Lobster Traps SPLIT DECISION Dock Talk 2 Oct 19, 2011 04:32 AM
For Sale Jomar Glitch trap/noise trap NIP megawatt Aircraft - General - Radio Equipment (FS/W) 0 Aug 04, 2007 05:25 PM
Number 4 wire trap by Navy 1 Tim Jonas Life, The Universe, and Politics 87 Aug 14, 2003 04:31 AM
Ferrite Beads, Noise Traps, Wire Gage green66 Radios 9 Mar 09, 2003 04:47 PM
