Old Aug 23, 2013, 07:00 PM
Hammer Head is offline
Find More Posts by Hammer Head
the journey is the reward
Hammer Head's Avatar
Canada
Joined Apr 2002
HK: Micro Tiger Moth 480mm
Just got this today.
http://www.hobbyking.com/hobbyking/s...rvos_PNF_.html
Will be assembling over the next few days during my stay-cation.
On a search here I could not find much, so I figured I would post the assembly etc...
Here are the first few pics.
Not EPO for sure. Kinda like GWS fuselage foam but thicker, especially the wings and control surfaces, and the wings are not just simple flat foam sheets like the beloved GWS PTM.
A quick parts fit and it looks ok. The lower wing is setup to slot in, and it fits pretty flush in the saddle. Will need to trim the horizontal stabilizer insert nubs to get a better fit. The vertical stab/rudder will need some trimming to get full throw clearance.
The instructions are one page, as pictured.
Lead was also included.
Overall not bad on first inspection.
This is going to be fun.
Hammer Head is offline Find More Posts by Hammer Head
Old Aug 24, 2013, 09:22 AM
Canada
Joined Apr 2002
Sorry Gents, this should have been posted into Micro RTF, I have asked for it to be moved.
Old Aug 24, 2013, 04:00 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Doesn't seem to be ready to fly mate I wouldn't worry.
RNAF is offline Find More Posts by RNAF
Old Aug 25, 2013, 10:58 AM
Canada
Joined Apr 2002
Beyond the screws to mount the motor being to large in diameter, this plane's going together very well.
Just enough room for the smallest Hitec receiver I have.
I have included shots of the components provided with this plane.
Been a pretty tight fit so far but just enough room even with the dubro hardware I used for the push rods/servo arms.
I built in a little down and right thrust when mounting the motor.
Old Aug 26, 2013, 09:45 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Nice looking build.
Any idea what the BL motor is specified as? Is it the C10-2000kv, or some such? What propeller size is recommended?
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Aug 26, 2013, 12:51 PM
Canada
Joined Apr 2002
Hey CorvetteC5
Appears to be the same motor as the HK BAT, which I have as well. Also same prop for both.
Motor: C10 2900kv
Prop: 4 x 2.5
http://www.hobbyking.com/hobbyking/s...lusMotor_.html
Build went well. Tight fit with the RX I have, but just enough space so no binding etc.
I elected to use small screws to attach the cowl as pictured.
The cowl with the provided weight added comes in at: 22.5g
The smallest battery I have is a Rhino 2s 360 20C 22.5g
All up weight: 152g (HK indicate120g)
Even with this, and the battery mounted underneath, still very tail heavy at the recommend CG, which is truly not defined other than a dot on the upper wing as pictured in the instructions.
With the battery mounted underneath (I had no place else to put it) CG is reached at about 45% back from the leading edge (at 30%, tail heavy as noted).
So having to mount the battery underneath, as pictured, helps reduce the extra weight needed to get the CG forward a bit more.
Could be interesting to see how the maiden goes as setup, but will look at adding a little more weight to get CG to about 35% from the leading edge.
Old Aug 28, 2013, 11:24 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Sigh IMO the price is aggressive to begin with and with shipping likely surprisingly expensive.
The ridiculous (unacceptable?) weight /balance issues pretty well say ; 'Avoid'
The HK turnigy /nano tech battery 360 is 1/2 the size and weights 17gms.. cheap at ~3$ too, but unlikely to be useful, given the lead ingot required to; not balance it
Thanks for posting though... it is all good information.
Bare is offline Find More Posts by Bare
Old Aug 28, 2013, 12:28 PM
Canada
Joined Apr 2002
Fully concur Bare.
Flies like a brick with all the weight required to balance. To get CG the plane now weighs almost 160g and it still appears tail heavy. Good luck flying it slow, or indoors.
After today's second round of '" flights", and two props/broken cowl, and bent motor shaft , I am decommissioning this plane...circular bin, lesson learned....I hope.
So this is a plane I can not endorse, not worth the money.
Old Aug 29, 2013, 05:23 PM
deadduck is online now
Find More Posts by deadduck
Manila Ninoy Intl, Philippines
Joined Nov 2001
Lighten the tail
Changing the tail to Depron should reduce the amount of lead required to balance?
deadduck is online now Find More Posts by deadduck
Old Sep 22, 2013, 10:29 PM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Hmm, I was interested until I heard the cg issues, thanks for the heads-up. I wish HK would do more quality control, I guess they should leave the micros to Durafly.
rotagen is offline Find More Posts by rotagen
Discussion HK (CMP?) Tiger Moth 50'' aftica Scale ARF/RTF 6 Jun 23, 2015 05:27 PM
Article Flyzone Micro Tiger Moth Tx-R tailskid2 Micro Ready-to-Fly 8 Jul 30, 2013 02:50 PM
Discussion Hobby king micro moth 480mm scousethief Micro Ready-to-Fly 2 Feb 06, 2013 04:58 PM
Micro Moth - RFFS100 Tiger Moth Chris3D Scratchbuilt Indoor and Micro Models 56 Dec 13, 2002 06:57 AM
