Old Aug 22, 2013, 01:47 PM
TMO is offline
TMO
Find More Posts by TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
New Product
ZTW Spider Series Multi-rotor ESC's Now Available
Hi Everybody,
Sorry to come barging in here with some spammy sounding post, but I think alot of you guys are really going to be interested in this. I'm Tim from Quantum Hobby, and we sell ZTW ESC's (among other things ).
Anyway, ZTW has come up with a pretty nice controller just for the MR crowd called the Spider Series. SimonK, opto-coupled, no bec, 400Hz internal, accepting PWM input up to 600Hz. Not really groundbreaking as far as the feature set- but wait- check out the price! $13.5 for a 30A Opto MR controller? Basically ZTW is giving you everything you need, and nothing you don't, and passing the savings on.
Here's a link: http://www.quantumhobby.com/ZTW-Spid...-ESC-s/726.htm
Anyway, thought you guys might like to know. If this announcement post is unwanted, let me know and I'll take it down. I hate spam too, but I've been around these boards a long time, and in this case, I thought this would be news of particular interest to this forum.
-Tim
TMO is offline Find More Posts by TMO
Old Oct 29, 2013, 12:33 PM
shady17 is offline
Find More Posts by shady17
Joined Nov 2012
Hello,
Is boot loader enabled, so future firmware ubdates can be achieved by a USB linker?
J
shady17 is offline Find More Posts by shady17
Old Nov 01, 2013, 02:08 PM
dfruehwald is offline
Find More Posts by dfruehwald
WZ9V, AMA 409852
United States, VA, Alexandria
Joined Jan 2007
Are they NFET or P/NFET circuits?
Do they use an external oscillator for stability?
dfruehwald is offline Find More Posts by dfruehwald
Old Nov 06, 2013, 11:52 AM
TMO is offline
TMO
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
In response to the questions in previous posts:
1) No, the boot loader is not enabled- they are non-programmable. If you like simonK, then you're good.
2) The Spider uses NFET circuit
3) Yes, they use an external oscillator, See pic- faint red circle.
-Tim
Old Nov 06, 2013, 11:59 AM
WZ9V, AMA 409852
Joined Jan 2007
Cool. Bootloader would be nice since it allows for easy updates to newer versions of SimonK firmware to address compatibility with some motors or to reverse the direction without having to swap wires (for those who solder rather than use bullet connectors)
-Tim
Old Nov 08, 2013, 04:41 AM
BrandXPD is offline
Find More Posts by BrandXPD
BrandXPD's Avatar
United States, WA, Olympia
Joined Mar 2013
If it had bullets soldered to the board I'd buy them.
BrandXPD is offline Find More Posts by BrandXPD
Old Nov 24, 2013, 05:50 PM
jeey is offline
Find More Posts by jeey
Norway, Sør-Trøndelag, Trondheim
Joined May 2013
So since these use simonk, what branch are they based on ?
jeey is offline Find More Posts by jeey
Old Nov 27, 2013, 10:27 AM
EuroBeat is offline
Find More Posts by EuroBeat
Joined May 2013
From what i know it uses the TP N-Fet firmware of SimonK.
EuroBeat is offline Find More Posts by EuroBeat
Old Mar 16, 2014, 11:00 AM
GhostMaster is offline
Find More Posts by GhostMaster
Portugal
Joined Feb 2012
Any other reviews of this ESC?
They are at a nice priced and can handle 6S...
ZTW Spider Series 20A OPTO 9.68$: http://j.mp/1gCvzoK
GhostMaster is offline Find More Posts by GhostMaster
Reply With Quote  (Disabled)
Old Mar 16, 2014, 11:03 AM
jeey is offline
Joined May 2013
sync issus on 6s motors (old simonK code), and it resulted in burned 3 esc.
Cheap = cheap
Old Mar 22, 2014, 09:00 AM
carlnoki is offline
Find More Posts by carlnoki
carlnoki's Avatar
United States, VA, Woodbridge
Joined Dec 2010
I use the 30A version on my new 450 quad and really like them alot.
I run 3S on mine tho.
They are in the prop blast so never a cooling problem at all.
I would use them again. :-)
carlnoki is offline Find More Posts by carlnoki
Old Apr 14, 2015, 01:38 PM
zestyzsauce is offline
Find More Posts by zestyzsauce
When in doubt throttle out
zestyzsauce's Avatar
United States, KY, Louisville
Joined Nov 2012
I know this is an old thread, but I plan on flashing these with BLHeli to try and get oneshot out of them.
--Z
zestyzsauce is offline Find More Posts by zestyzsauce
Old Apr 17, 2015, 06:06 AM
Maveric1985 is offline
Find More Posts by Maveric1985
Australia, QLD, Wishart
Joined Feb 2015
--Z
Let me know how you go. I'm waiting on a response from my supplier to see if it's capable.
Maveric1985 is offline Find More Posts by Maveric1985
Old Apr 19, 2015, 07:30 PM
FlagstaffMike is offline
Find More Posts by FlagstaffMike
Joined Mar 2015
Take a look on quadrysteria, from what I understand oneshot125 is in version 13 of BlHeli
Go to quadrysteria here
FlagstaffMike is offline Find More Posts by FlagstaffMike
Old Apr 22, 2015, 12:04 PM
chrisbarth is offline
Find More Posts by chrisbarth
Master Prop Breaker
United States, MD, Huntingtown
Joined Oct 2006
Old post but these use bs-nfet if you flash the 20a,30a, and 40a , not sure about the 12a. Dont want anyone smoking them.
Easiest to use a HK atmel socket with a usbasp and kkflashtool or blhelisuite to flash with . Make to include a bootloader when you flash so in the future you can use the signal lead to change parm. or flash something else.
I used the ztw spider 30a flashed with latest simonk with compwm enabled which supposedly enables oneshot125. With oneshot125 enabled on a CC3D , the difference was very noticeable and positive, actually huge difference. . Super smooth, faster descents, higher PID's without low or full throttle oscillations. ESC,s and motors never got hot even running full throttle straight up and fly bys with 5s lipos, Sunnysky 2216 1100kv motors with graupner 10x5 props. I've even tried 6s on the same setup but with 9x4.5 APC mr but power was to insane for me to fly LOS, out of sight in a second! FPV would be probably be awesome though.
Havent tried BLheli because Im satisfied with the latest simonk right now, but I see no reason it shouldn't work fine with blheli oneshot125. From what I have gathered these ESC,s are the same as Blueseries opto which are made by ZTW also.
Edit: Good news and will save a bunch of work. Looks like the new versions have the bootloader enabled! Thanks for that info Flagstaffmike. Wonder if its on the label or you just have to hook up a usb linker to find out?
chrisbarth is offline Find More Posts by chrisbarth
New Product NEW Gecko Series ESCs from ZTW available soon! Garret H Power Systems 41 Oct 05, 2015 08:26 PM
New Product Next Level Multi-Rotor Frame Kits Now Available! Innov8tive Multirotor Talk 2687 Jun 22, 2015 10:48 PM
Discussion Anyone using T-Motor 40A esc's on multi-rotor? phil222 Multirotor Electronics 0 May 11, 2013 08:58 AM
Sold Complete Blueskyrc X-Rotor Spider kit with Motors, Carbon Fiber Booms, ESC's and More ckalkhof Aircraft - Electric - Multirotor (FS/W) 4 Mar 16, 2013 12:48 PM
Bunch of new 20A/30A Turnigy multi-rotor ESC's anixs Non R/C Items (FS/W) 16 Feb 22, 2013 05:23 PM
