Old Aug 20, 2013, 07:45 AM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
FnBL - Franken Brushless
Post 1- Index
Adapting cheap, light mini frame components for brushless quads.
An extension of Massive Overkill's Frankenquad concept to brushless
This post will be updated with new info and links regularly.
Please share your ideas and adaptations!!!
First build here... (Post 2 Below)
http://www.rcgroups.com/forums/showp...87&postcount=2
V929 Frame components
Lemon Flip - RX FC - New how-to to come.
Plush 6A ESCs BLHeli 9.2
C1404 3100kV motors
Gemfan 5030 props
Nanotech 2S 450mAh
AUW = 112.14 grams
FnBL Round Two (3 min 39 sec)
Soma is offline Find More Posts by Soma
Old Aug 20, 2013, 07:46 AM
Soma is offline
Joined Sep 2012
V929 C1404 3000KV Build
5x V929 Centre Frame
4x V929 Carbon Boom
C1404 3100kV motors - Thanks to MotoMoto
Gemfan 5030 props
Nanotech 2S 450mAh - Bit small but uber light. 3:30min flight time flown hard. 2S 950mAh are next to try.
AUW = 112.14 grams
Build Process...
Frame
Stock V929 centre frame
Cut down
Centre frame how-to vid
FnBL V929 Centre (1 min 22 sec)
Motor mount from V929 centre frame
Motor mount how-to vid
FnBL Motor Mount (2 min 23 sec)
V929 carbon boom
Bare frame
All 6.6 grams, plus 4.4 grams of motor mounts = 11 gram frame
Motor Prep
Motor shaft (prop saver) screws were loctited. I have never received a motor with the shaft screws even tight, never mind thread locked. Other than the press fit of the shaft these are all that hold the motor together. There's a pic of how much grease comes off the threads with alcohol. I spray a tissue and then pinch the threads between fingernails and back out the screw with a driver, twice each screw. This helps loctite bond. Only a small amount of loctite is needed, but absolutely necessary.
Motor mount, 3 screws, 3 washers
Hobbyking size 2 washers???
Motors mounted
Motor assembly weight
3 Motors needed quite a lot of balancing. Dynamically balanced in hand, trial & error. Makes a massive difference!
ESCs
Significant weight is saved by removing the unused power wires
Flashed with BLHeli.  Thread here...
The ESCs are from my Dialfonzo nano. This is how quick BLHeli responds.
BLheli V9.2, Plush 6A, C10 2900kV, 2S (0 min 17 sec)
Do not forget the heatshrink!
Wish I had lighter stuff 1.68g for 3 pieces
Laid out ready to solder
Good ol' wooden-peg-in-a-vice trick. Don't forget to flip 2 wires for clockwise motors.
Shrink the heat shrink
Tidy the motor wires and ESC wires down the side
Lemon-Flip FC-RX
How to build a Lemon-Flip will have a detailed how-to blog post soon.
Till then here is the original two posts...
http://www.rcgroups.com/forums/showp...&postcount=445
http://www.rcgroups.com/forums/showp...&postcount=538
Parma servo tape
FC mounted and soldered
77.17g dry weight
AUW
Under
Under plus lipo
Multiwii Settings
Soon to come. Basically stock + rates - expo
Flying Vids...
Franken Brushless (2 min 4 sec)
Soma is offline
Joined Sep 2012
Multistar 1704 1900KV Build
*** Under Construction *** Next build - To be updated
*** UPDATE 2013-08-24 ***
Here's some pics of the Multistar 1704's fitting the HK q-Bot micro (3mm) frame and the U817/U818 (4mm) frame. Also testing the HQ Prop 7x4's...
http://www.rcgroups.com/forums/showt...874705&page=25
The 1704 X-Mount fits the q-Bot micro frame FC mounts perfectly. It can be secured with screws, these are V929 screws which would need a washer. Bigger screws should fit fine if drilled. They can be cable tied for a no screw solution. Need to weigh each to see which is lighter.
X-Mount on q-Bot micro frame.
X-mount on U817/U818 frame. Held in place by the FC mounts and also there are markings on the frame at the exact points to screw the X-Mount. It can also be cable tied.
I will be persuing the HQ Prop 7x4 props on the 1704's with 2S 1000mAh lipos. Should be a nice setup. Hopefully on the 4mm frame.
HK Multistar 1704 1900KV Motors
Blog Post here...
http://www.rcgroups.com/forums/showthread.php?t=1972924
V959 frame
HK F-6A flashed SimonK
Lemon-Flip FC-RX
Thanks to Daryoon for posting in the above thread regarding HK qBot Micro centre frames, otherwise I would not have known about them
http://www.rcgroups.com/forums/showp...&postcount=161
In progress... using HK Q-Bot micro centre frames as motor +mounts.
They mount well, I just wonder how strong they'll be in a crash. There's no much material around the arm to brace them. They are made of carbon reinforced nylon and are strong.
Cut the lipo cage off.
Mark 12.4mm
Good protection for the motors.
M2 x 6mm screws.
Old Aug 20, 2013, 07:47 AM
Soma is offline
Joined Sep 2012
ZMR / RCX 1804 Build
*** Under Construction *** To be updated.
ZMR / RCX 1804 Motors
HiModel 6x4.5 Props
3S 850mAh
HK 10A NFET ESC BLHeli
Lemon-Flip RX-FC
And another option I'll be following.
UDI U817 / U818 Centre frame from Banggood.
For 4mm CF tubes.
Soma is offline
Joined Sep 2012
V262 Frame Build
If they ever list spare parts
Old Aug 20, 2013, 08:06 AM
vpsporb is offline
Find More Posts by vpsporb
Canada, ON, Ottawa
Joined Dec 2011
What?
vpsporb is offline Find More Posts by vpsporb
Old Aug 20, 2013, 08:15 AM
vpsporb is offline
Canada, ON, Ottawa
Joined Dec 2011
Dude!
I just watched your part deux video... and I am dumbfounded, befuddled and stupified by the hummingbird like performance! and the fact that the frame held-up to the G's! seeing the pics I thought naw!, but damned if it dint. Oh and great flying btw!
I really really have to learn how to flash the wee 6A ESCs and join-in on the Fun.
Great stuff, and really clean and neat builds.
Old Aug 20, 2013, 08:27 AM
Soma is offline
Joined Sep 2012
Originally Posted by vpsporb View Post
Dude!
Thanks mate!!! I've enjoyed your flying on very numerous occasions too
I was sceptical the frame would have too much flex, but because its so light it holds up great! Stock mQX is about 70g? AUW this isn't that much more at 112.
The next build (1704's) may well be too heavy for the 3mm arms, but I will try anyway Then buy some 4mm carbon tube.
Old Aug 20, 2013, 10:32 AM
bangkomit is offline
Find More Posts by bangkomit
Hubsan X4 - H36 - V911
bangkomit's Avatar
Indonesia, Jakarta
Joined Oct 2012
Very nice and tidy job, Soma! Love the way you fly, i just only can imagine i wish i could fly like the way you are!
bangkomit is offline Find More Posts by bangkomit
Old Aug 20, 2013, 11:12 AM
Rust is offline
Find More Posts by Rust
Rust's Avatar
Bulgaria, Sofija-Grad, Sofia
Joined Apr 2013
Another great thread my friend - pinned!
Don't know when I'm doing this kind of project ... but I'll certainly try it
Rust is offline Find More Posts by Rust
Old Aug 20, 2013, 03:14 PM
Rust is offline
Rust's Avatar
Joined Apr 2013
FnBL round 2 .... I'll need to overclock my brain's processor to keep up with the speed of that thing! You're a really good pilot
Old Aug 20, 2013, 06:25 PM
Soma is offline
Joined Sep 2012
Thanks guys! Most fun I've had flying a quad so far
Was planning to build the next one today but have been called to work
Argh well, gotta go! Happy Flying!
Old Aug 20, 2013, 08:03 PM
Tom Korn is online now
Find More Posts by Tom Korn
Aerospace Machinist
Casselberry, Florida
Joined Dec 2002
Wow! This is what I was waiting for.
A small brushless Quad that shreds.
Wonderful flying, Soma.
Thank you.
Tom Korn is online now Find More Posts by Tom Korn
Old Aug 20, 2013, 09:59 PM
vastsky is offline
Find More Posts by vastsky
Professional amature
Canada, BC, Kamloops
Joined Oct 2011
Hey Soma - Great stuff!
Do the ZMR / RCX 1804 2400Kv motors run 3S? I could not find any info on them.
vastsky is offline Find More Posts by vastsky
Old Aug 20, 2013, 11:28 PM
Soma is offline
Joined Sep 2012
Thank you.
Cheers mate! Oh yes it shreds... My nerves mostly Would you believe I've been trying to find a way to do this for about 9 months? And it was staring me in the face the whole time! I always thought the results would be good, but just how good took me by surprise!
Are you thinking of building something similar? There's a few different ideas to come in the next 2 builds.
Yes Sir! They do indeed. Most of the talk on these motors is on this thread....
http://www.rcgroups.com/forums/showt...9#post25897943
Wolfmetalfab has been pushing them well beyond their limits. Talk goes back quite a few pages. He also has info on his blog post. Antslake has had great reports of them too. I've only bench tested but they seem very good.
They may hold up under 6x4.5 props on 3S if the quad is very light. If not it will require 5030's or 5x4.5 triples. They also need at least 10A ESC's it seems.
The motors are from myrcmart.com
Anti-Clockwise (spinning) (Clockwise prop thread)
http://www.myrcmart.com/zmr-1804-240...se-p-6280.html
Clockwise (spinning) (Anticlockwise prop thread)
http://www.myrcmart.com/zmr-1804-240...se-p-6281.html
Cheers all!
Discussion Olypic II is under construction now Texas Buzzard Sailplane Talk 16 Aug 10, 2014 01:54 PM
Video Quad filming roller coaster under construction Brian_ Multirotor Talk 1 Mar 04, 2013 02:19 PM
Gallery 1/8 Corsair under construction. RedWaco Your Plane Photos 0 Feb 08, 2003 08:30 AM
Gallery Bantam Bipe under construction Andy W Your Plane Photos 0 Aug 28, 2002 04:01 PM
