Tamiya TB-04 PRO Chassis Kit
The successor to the popular TB-03
Get ready to race with the new TB-04 Pro touring car chassis from Tamiya!
OVERVIEW
The TB-04 PRO chassis is the successor to the TB-03, and this race circuit touring car inherits its efficient shaft-driven 4WD system with a newly developed, horizontally-positioned motor placement design. The chassis features a number of newly-designed parts and provides a blend of speed and handling that R/C racers are sure to enjoy at their local track.
The TB-04 shares the same double wishbone, independent suspension parts as seen on the TB-03, TA-05 Version II and TRF 416/417 series of proven chassis designs.
The TB-04 Pro measures 190mm in width and it will accommodate any of Tamiya’s replica and fully licensed Touring and Sports Car body sets.
KEY FEATURES
  • This is a limited edition 1/10 scale R/C model assembly kit. Standard base kit to be releases soon after.
  • Newly-designed transmission case helps to provide increased stability during acceleration.
  • The main chassis frame has a low center of gravity while offering minimized contact with the track surface.
  • Oil-filled and sealed gear differentials (front and rear).
  • New differential gear features 40T ring gears and 16T bevel gears for excellent transmission.
  • It uses a long steering tie-rod system refined on the TRF417 chassis.
  • Newly-designed battery holder provides simple and secure attachment.
  • AMB transponder can be accessed from the chassis underside.
  • Users can choose between inboard and outboard front suspension. Inboard front suspension allows the use of low profile body sets.
  • Features a new motor guard to protect the motor from impacts.
  • Employs short oil dampers for touring cars to enable lower ground clearance, while maintaining suspension stroke.
QUICK SPECS
Scale 1/10
Kit or RTRKit
Drivetrain 4WD, shaft driven
Diffs Gear
Shocks Oil-filled, coil over
Item number84339
Street price$361.99
Availability September '13
In conjunction with the release of the new TB-04 chassis platform, Tamiya will also be release new Hop-Up-Options to go with it.
84360 TB-04 PRO Titanium Screw Set
Availability: September
MSRP: $88.00
This titanium screw set for the new TB-04 PRO chassis kit contains screws which, when fitted to the chassis, achieve a weight reduction of 22 grams.
Set Contents
  • 3×6mm Titanium Hex Screws x 3
  • 3×8mm Titanium Hex Screws x 8
  • 3×10mm Titanium Hex Screws x 28
  • 3×15mm Titanium Hex Screw x 6
  • 3×8mm Titanium Hex Countersunk Screws x 30
  • 3×10mm Titanium Hex Countersunk Screws x 17
  • Compatible with TB-04 PRO chassis.
54520 TB-04 Aluminum Motor Adapter
MSRP: $17.50
This is an aluminum motor adapter for the TB-04 shaft-drive, touring car chassis platform. Fitting it not only provides a more secure motor attachment, it also has a heat-sink effect which allows the motor to cool more easily.
Features
  • Replaces kit-standard T5 and T7 parts.
  • Compatible with TB-04 and TB-04 PRO touring car chassis models.
54521 TB-04 Front One-Way Set (40T)
MSRP: $65.00
This is a front one-way set designed to be used with the TB-04 shaft-drive, touring car chassis platform. It cancels the brake function of the front wheels and provides sharper handling. Not only that, it also allows improved acceleration when compared with a ball differential.
Features
  • Includes 2mm pins and O-rings which can be used to provide a direct differential unit set-up.
54522 TB-04 Aluminum Ball Differential Set (40T)
MSRP: $57.00
This is a ball differential unit for the TB-04 touring car chassis platform. Fitting this aluminum ball differential to your TB-04 chassis model will provide it with more stable handling characteristics. It also has the durability to make it compatible with higher-power motors.
Features
  • Uses 12x 3/32-inch balls.
  • Includes TRF417 V5 pin protector.
54523 TB-04 Carbon Damper Stay (Front)
Availability: September MSRP: $23.50
This is a carbon plate front damper mount for the TB-04 4WD touring car chassis. It is lightweight and more rigid compared to the fiber reinforced plastic piece included in the kit. The stiffer shock tower will result in the dampers working more precisely as there is less flex and deflection.
Features
  • This damper stay is for use with short dampers only.
  • Made from 3.5mm thick carbon fiber plate, this stay ensures solid damper attachment.
  • Features 8 attachment holes to enable a wide variety of settings.
  • Compatible with TB-04 and TB-04 PRO cars fitted with short dampers.
54524 TB-04 Carbon Damper Stay (Rear)
MSRP: $25.00
This is a carbon plate rear damper mount for the TB-04 4WD touring car chassis. It is lightweight and more rigid compared to the fiber reinforced plastic piece included in the kit. The stiffer shock tower will result in the dampers working more precisely as there is less flex and deflection.
Features
Visit the site for more information on Tamiya products!
There are no posts
For Sale NIB! Smoking Deal $300 Tamiya TB-03 VDS Drift Spec Chassis pn # 84205 FNW Cars - Cars and Parts (FS/W) 4 Jan 25, 2013 04:00 PM
Sold Tamiya F103R3 Chassis Kit # 58156 + George Jure Cars - Cars and Parts (FS/W) 0 Nov 23, 2012 12:40 AM
Sold Tamiya F103R3 Chassis Kit # 58156 + George Jure Cars - Cars and Parts (FS/W) 1 Nov 23, 2012 12:37 AM
For Sale NIB! Smoking Deal $300 Tamiya TB-03 VDS Drift Spec Chassis pn # 84205 FNW Cars - Trucks and Parts (FS/W) 0 Nov 13, 2012 02:44 PM
Wanted Tamiya CC-01 Chassis or Full Kit nieb15 Cars - Cars and Parts (FS/W) 0 Jan 10, 2010 10:09 PM
