How I Cut and Strip Wire
An Easy All-In-One Tool For Cutting and Stripping Wire
Cutting and Stripping Wire Doesn't Have to be a Pain
If you've been in this hobby for any length of time, you've probably had to cut some wire and learn to solder at some point. There are lots of ways to cut and strip wire. I've seen people use a hobby knife, wire strippers, scissors, even their thumbnails, but I've come to love and use the side cutters as my preferred tool.
Side cutters are super handy, they can clip the ends of zip ties, cut heat shrink, and best of all, they do a great job of cutting and stripping wire. I'm not talking about large heavy duty side cutters, I'm talking about small hobby grade versions.
When cutting wire, it's really simple, just figure out where you want the cut to be and snip away. I should caution you not to use these on hard music wire, or steel. Those can actually dent the cutters and nearly render them useless. We're talking about cutting relatively small diameter silicone wire used on speed controllers, motors, and batteries.
Stripping the wire is simple. Place the cutters on the wire with the flat side of the cutter facing out. I usually pinch the outer silicone sleeve a couple of times with the cutter all the way around the wire to weaken it and then squeeze lightly and lift off. The cutter digs into the silicone sleeve and then pulls away and rips it off, leaving the exposed wire behind. Just be careful not to squeeze the cutter too hard and cut into the wire. Practice a few times on some scrap wire to get the hang of it.
Now this isn't the only way to do it, and may not even be the best way, certainly wire strippers work great, but side cutters do the same job and more. They work for me and I've been doing this for a very long time. Feel free to reply and let us know your preferred tools and methods for cutting and stripping wire.
Old Aug 19, 2013, 08:48 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Is this some kind of Infomercial??
Cutting and stripping wire is Real Easy using just a Blade and one's thumbnail.
Bare is offline Find More Posts by Bare
Old Aug 20, 2013, 05:12 AM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
I use an exacto or box cutter,roll the wire on the blade then pull the insulation off. Most of the time i use side cutters to cut the wire,for thinner gauge wire that use's jst connectors etc i use scissors.
Get Real is offline Find More Posts by Get Real
Old Aug 20, 2013, 05:43 AM
Archades is offline
Find More Posts by Archades
Australia, QLD, Innisfail
Joined Apr 2013
auto wire strippers for me, works great
Archades is offline Find More Posts by Archades
Old Aug 20, 2013, 10:04 AM
Ron H is offline
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
I use tin snips.
Ron H is offline Find More Posts by Ron H
Old Aug 20, 2013, 02:15 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
I use a HOTWeezer.
Chumps
jtaylor996 is offline Find More Posts by jtaylor996
Old Aug 20, 2013, 08:15 PM
Tucci is online now
Find More Posts by Tucci
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
I like a meat cleaver to cut the wire. Then I douse the end in some flammable liquid, and burn the insulation off.
Tucci is online now Find More Posts by Tucci
Old Aug 20, 2013, 08:40 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
I just use whatever bladed object I happen to have immediately at hand. X-Acto is preferable, but my very small Swiss Army knife also works, as will my pocket folder, a snap knife, scissors, toenail clippers... I think it's more to do with the user than the tool in this case.
It's certainly started to seem that way.
Piece is online now Find More Posts by Piece
Old Aug 20, 2013, 09:34 PM
Registered Crasher
Joined Feb 2011
HOTweezers are thermal wire strippers. Like this:
Hakko FT-800 Thermal Wire Stripper (1 min 35 sec)
Old Aug 21, 2013, 09:32 PM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
As a Nasa Certified, USAF Electrician I prefer a razor blade and/or exacto....
However we do have a REALLY easy to use, brainless tool, check these out!
http://www.all-spec.com/products/110...FWQ6QgodigQALA
Many companies make a similar version, and all are pretty awesome, they hold, cut, strip then release the wire all in one motion.
You really do get spoiled!
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Aug 21, 2013, 09:36 PM
Ron H is offline
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Got those, and they are good. But I'm much faster with the tin snips.
Old Aug 21, 2013, 10:01 PM
Joined Nov 2010
Really? When I have a big wiring job (I mean aircraft wiring harnesses with 30-200+ wires) they are awesome... If it is just a few then the razor is preferred...
Not really sure how you can beat that style of stripper, they are crazy fast!
Old Aug 22, 2013, 12:22 PM
Registered Crasher
Joined Feb 2011
Have you never used a thermal wire stripper? Easily as fast, and won't cut or nick the wire itself...
Old Aug 24, 2013, 05:29 PM
Northern Flier is offline
Find More Posts by Northern Flier
Northern Flier's Avatar
Joined Sep 2012
That's e exact tool I use. Klein is awesome.
Northern Flier is offline Find More Posts by Northern Flier
Old Aug 26, 2013, 08:45 AM
Archades is offline
Joined Apr 2013
The HOTWeezer is the best thing I've seen all week!
Discussion How Do You Throttle Calibrate an ESC with Red Wire Cut daskim Multirotor Electronics 1 Jan 14, 2013 01:05 PM
Help! Quick q: how do you cut carbon strips? DaveTheKiwi The Builders Workshop 11 Nov 11, 2012 06:07 AM
Discussion how do I strip the wires before soldering JustinONE Electric Motor Design and Construction 10 Nov 14, 2008 01:35 PM
Discussion How to strip magnet wire Rex A Lott Electric Motor Design and Construction 18 Sep 05, 2007 02:23 PM
Discussion How to Cut a 45 degree strip? surjer Beginner Training Area (Aircraft-Electric) 6 Aug 28, 2007 12:41 PM
