Old Aug 17, 2013, 08:14 PM
Trdxfilms is offline
Find More Posts by Trdxfilms
Joined Aug 2013
Question
What's range on DX7S
I want to get the DX7S. I wana get the one that comes with the receiver (AR8000) also with the GPS modula that comes with it (DSMS) . I want to know the rang of it. I'm not changing anything on it.
Trdxfilms is offline Find More Posts by Trdxfilms
Old Aug 17, 2013, 09:35 PM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
There's no simple answer to such a question, as review of this thread will show.
http://fpvlab.com/forums/showthread....-range-testing
It boils down to plenty for normal visual flying. If you are planning an FPV application things are more complicated.
Daedalus66 is online now Find More Posts by Daedalus66
Old Aug 17, 2013, 10:21 PM
Joined Aug 2013
Yes am flying FPV. But before I buy a new controller, I want to know the range on it
Old Aug 17, 2013, 10:31 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
As I said, and as the thread I referred to shows, there is no simple answer to that question. Transmitters don't have range specifications, just power and antenna gain.
The various Spektrum transmitters (DX7s, DX8, etc.) all have a similar power output that is essentially at the maximum legally permitted. And DX7s and DX8 use similar standard low gain antennas to minimize directionality for normal use.
It is possible for FPV use to add a highly directional antenna that increase the radiated power in certain directions at the expense of others.
Otherwise, what determines ranges is at the receiver end of the link. The receiver itself is an important factor, but so is the installation and whether there is a video transmitter that interferes with reception.
I suggest you go to the FPV forums for a discussion of how the DX7s/DX8 performs in combination with the AR8000 in various FPV applications. The general view seems to be that it can be used but is not ideal for FPV.
Old Aug 18, 2013, 10:24 AM
rajazo is offline
Find More Posts by rajazo
rajazo's Avatar
Chile
Joined Jul 2010
for FPV get a Module based transmiter because they have the capabilities of use any transmition protocol (actual and futures), from standard range 2ghz to UHF long range... if you already have DSM rx the natural choice are JR... if not and you are low in budget get a Hitec Aurora or the new Frsky Taranis
rajazo is offline Find More Posts by rajazo
Old Aug 18, 2013, 10:32 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
It should get you 5,280' 0.0"
Of course your results will differ based in outside influences.
1320fastback is offline Find More Posts by 1320fastback
Old Aug 18, 2013, 12:48 PM
Joined Aug 2013
What do you mean by 5,280
Old Aug 18, 2013, 12:58 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
that would be a mile....
Old Aug 18, 2013, 01:06 PM
Joined Aug 2013
Your saying the DX7S will get me that far?
Old Aug 18, 2013, 01:16 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
http://www.jrradios.com/Content/PDF/Challenge_AD_4.pdf
Different radio, but same technology at the same power level.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Aug 18, 2013, 03:37 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
One would certainly hope so. Modern 2.4 technology should give at least a mile under reasonable circumstances. But how much more depends on a whole series of variables, such as the receiver being used, the installation, the antennas, what type of video transmitter is on board the model, etc.
Old Aug 18, 2013, 04:01 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
I am saying further. Others have said (testing the DX7) on GROUND tests they got 2.2 miles.
YMMV.
pda4you is offline
pda4you's Avatar
Joined May 2002
+1 - you are the master of your domain.
Old Sep 09, 2013, 12:28 PM
CptnInsanity is offline
Find More Posts by CptnInsanity
FlyingBear
United States, CA, Sunnyvale
Joined Apr 2012
I flew 1.5 miles yesterday with a DX7S on my Bixler 2. My video TX and AR8000 are within a couple inches of each other. I think I could get even more range by moving them further apart.
https://www.youtube.com/watch?v=DSfbXQTYs7c
Setup
- Bixler 2
- DX7S
- Spektrum AR8000 with satellite receiver installed on the tail
- Eagletree OSD Pro with Guardian Stabilization, located near CG
- Immersion 5.8ghz 600mW TX, mounted to cockpit vertical wall. TX antenna pointing up
- Fatshark Attitude with built in receiver
- Spironet Circular Polarized Antennas (Cloverleaf and Skew Planar Combo)
- ESC mounted on top of fuselage, near motor
CptnInsanity is offline Find More Posts by CptnInsanity
Old Sep 09, 2013, 04:09 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Thanks for letting us know.
Help! Range Check Poor on Spektrum DX6i, what's wrong? Indetrucks Radios 31 Jun 01, 2015 01:42 PM
Discussion xg8 users, what's you range in range check? heybritishguy Radios 1 Jun 11, 2013 05:16 PM
Discussion DX7s Range issues vs. old DX7 pestrada Radios 6 May 06, 2013 08:19 AM
Discussion What,s the range on the ezuhf ozzimadman FPV Talk 1 Jan 15, 2012 12:45 PM
Discussion What reasonably priced Tx/Rx's have really good range, and what is really good range? Dan_K Electric Plane Talk 12 Oct 23, 2008 10:18 AM
