Old Feb 09, 2004, 09:20 AM
tdr1919 is offline
Find More Posts by tdr1919
Long Island NY
Joined Jan 2004
ECO 16 collective setup
I have a ECO 8 conversion to a 16 with the Mega 30/3.
I am using a JR 8103 transmitter. I am a beginner just off
the training gear hovering tail in only.
The heli seems to be balanced out, but the but is very sensitive to the slightest breeze where it will gain altitude quickly and then
drop down. I am not sure my throttle and pich curves are set properly.
I believe the main rotor blades are around +6 deg. at mid throttle
and the motor is at 85% at mid throttle.
compared to my VE the main rotor appears to be slower than that of the voyager (sound only, I do not have a tach.)
any ideas?
TomR
tdr1919 is offline Find More Posts by tdr1919
Old Feb 09, 2004, 12:13 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
>>is very sensitive to the slightest breeze where it will gain altitude quickly and then<<
That is normal since you have a long rotor blade. That translate into a much lighter disc loading.
and the motor is at 85% at mid throttle.<<
That sounds about right.
any ideas?<<
The longer the rotor blade the slow it turns before lifting off.
You can soften the hovering sensitivity by going back to an ECO 8 with shorter blades and shorter boom.
Part of learning to fly an RC helicopter is to use the collective to anticipate the wind.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Feb 09, 2004, 12:24 PM
tdr1919 is offline
Long Island NY
Joined Jan 2004
SeismicCWave, thanks for the reply, I guess it's all summed up with the age old phrase "practice, practice and more practice"!
Tom R
Discussion Eco 16 Gallery, build and setup data Gadget01 Electric Heli Talk 9 Jun 04, 2007 12:37 PM
Need Eco-8 and Eco-16 Setup Recommendations mattweisz Electric Heli Talk 2 Oct 17, 2004 08:53 AM
(FS) Eco-8 full setup. blt4ice Aircraft - Electric - Airplanes (FS/W) 5 Sep 12, 2001 05:54 PM
ECO 16 ? RC Man Electric Heli Talk 11 Jun 26, 2001 12:20 AM
ECO 16 SJ Electric Heli Talk 3 Jun 08, 2001 06:52 PM
