Klimek Tug Boat
Klimek Tug Boat 1/20th Scale Frame Kit and Plans
Clyde Puffer 1/20th Scale AutoCAD Plan Set and Frame Kit Plans
From John-Tom:
Accurate aligned frames are the foundation for a high quality plank on frame model. Save hundreds of hours of time when making a plank on frame boat or ship model by starting with accurately machine cut frames.
Buying a ready cut frame kit is very expensive. Use our files with your chosen CNC workshop and have your frame kit cut for the fraction of the cost.
Costs can be kept to an absolute minimum by making your own choice of basswood or hardwood ply to a laser cutting shop or CNC milling shop, using the Files from John-Tom and just pay for the machining time if you do not own a CNC mini Mill or laser set up. Cut out the middle man and make the best saving and still end up with top quality frame sets for a fraction of the price charged by model boat companies and people selling plank on frame kits for model boats and ships.
Here is a nice tug brought to you by John Tomlinson.
RC Tug Boat Plans - 1/20th Scale Plank on Frame Build (9 min 43 sec)
Dimensions
  • Model Length : 833mm (32.8")
  • Model Beam : 222mm (8.75")
  • Height to top of Cabin : 286.5mm (11.3")
Plywood Sheet Dimensions
  • 600x350mm at 4.5mm thickness (24" x 14" at 3/16th" thickness) - 4 Sheets Required (Frames and Deck)
  • 600x350mm at 4.5mm thickness (24" x 14" at 3/32nd" thickness) - 2 Sheets Required (Cabin)
  • 600x350mm at 4.5mm thickness (24" x 14" at 1/8" thickness) - 2.5 Sheets Required (Planking)
Learn more here.
Old Aug 15, 2013, 11:43 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Nice looking tug boat And just the right size.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Aug 15, 2013, 07:01 PM
KIWINB is offline
Find More Posts by KIWINB
Auckland New Zealand
Joined Sep 2010
Great work, nice to see another Klimek, mine at 588mm long is here:- http://www.rcgroups.com/forums/showthread.php?t=1430890
I got detail plans from here:- http://freeshipplans.blogspot.com/20...1_archive.html Note, there are some slight errors in the plan sizes so they don't match up when joined. I altered the print scale to correct these.
Lots of other boat plans on this site.
KIWINB is offline Find More Posts by KIWINB
Last edited by KIWINB; Aug 15, 2013 at 08:02 PM. Reason: Added the freeshipplans website.
Discussion 580mm (23") Tug KLIMEK construction KIWINB Scale Boats 22 May 21, 2013 07:48 AM
For Sale Billing Boats Banckert RC Tug Boat #516 Just-in-skin Boats (FS/W) 1 Apr 06, 2013 03:28 PM
Sold 1975 Saito Cervia Steam Engine Powered Tug Boat $650 modlflr Boats (FS/W) 1 Mar 29, 2013 08:38 PM
Discussion My tug boat needs another motor control chocolatehaule Scale Boats 8 Mar 03, 2013 05:34 PM
For Sale Artr rc radio control savannah harbor tug boat tugboat ship wjdid Boats (FS/W) 0 Feb 24, 2013 08:55 AM
