Old Feb 14, 2004, 06:38 PM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Progress is Being Made
Most of the framing is done now, and the power system mounts are all in place. The stuffing boxes are installed in the hull and it's time to start sealing things up
P. Tritle is offline Find More Posts by P. Tritle
Old Feb 14, 2004, 06:43 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
A bit of head scratcing!!
Unfortunately, this boat doesn't lend itself well to equipment access, so I solved the problem on one hand by adding a hatch on top of the forward cabin, while creating another problem on the other.
As it turns out, the original hatch was too long and ended up with the aft end under the windshield frame. So, the opening needed to be moved up a bit and the hatch cover shortened to match. By doing that, access to the motors and ESC was too tight to be practical, so a large section of the hull frame was removed. Photos of the finished wquipment bay will be coming shortly.
Old Feb 15, 2004, 02:11 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The new Equipment Hatch
I got the hatch reshaped and removed an adequate amount of the hull frame to access all the running gears easily.
Old Feb 15, 2004, 02:16 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Now that that's done, it looks like framing is complete. Now, it's time to concentrate on the sealing and finishing. I think I'll stay with my usual method sealing on this type model of 6 coats of Nitrate dope and prime with automotive acrylic primer. Color coates will be acrylic lacquer and Chroma base colors with a final coat of floor varnish over the whole thing.
PAT
Old Feb 17, 2004, 02:39 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Painting has begun
The base color went on the boat today. Will be masking and painting the hull bottom tommorrow, then we're down to the details!
PAT
Old Feb 18, 2004, 12:38 PM
Tachikaze is online now
Find More Posts by Tachikaze
太刀風
Tachikaze's Avatar
United States, OR, Eugene
Joined Jan 2003
Pat,
I am pleased to see that you are running direct drive rather than a large amp drawing motor with a gear box.
Have you started the skiff yet?
Tachikaze is online now Find More Posts by Tachikaze
Old Feb 18, 2004, 12:58 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Tach, I haven't started the skiff yet, but it sure would seem like the wrong way to run without it.
I got the power system hooked up this AM, I wired the twin S-280's in series using the Graupner C-rotating props. On 6 2400 cells I think it will still be grossly overpowered, but at cruise power should run for about a month!!!
I finished the paint work this morning and have been working on the details since. Keep a sharp eye out, more photos are coming.
PAT
Old Feb 19, 2004, 08:43 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
More Deck Details
Progress continues with the addition of the aft deck details. The control console is pretty well together with only a few finishing touches still needed.
Old Feb 19, 2004, 08:46 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Railings!
The railings and canopy frame are the biggest part of detailing the aft deck. With all that in place it's down to the benches and chairs.
Old Feb 19, 2004, 05:26 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The "Vrolijkheid" is ready to run
After a full day of finishing and detailing, the model is reary to run.
Old Feb 19, 2004, 05:28 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Another angle
Here she is from the front
Old Feb 19, 2004, 05:30 PM
Neil Morse is online now
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
Magnificent! Somehow, I stumbled over here from the airplane area, and I have to say that Pat's boats are every bit as nice as his planes. What a beauty.
Neil
Neil Morse is online now Find More Posts by Neil Morse
Old Feb 19, 2004, 05:32 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Some of the finer points
A reasonable amount of cabin detail was added --- up to the point where practicality overtakes the desire to keep going. I opted to leave the canopy off for now so not to hide of the deck detail.
Old Feb 19, 2004, 05:36 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
More details
The rear bench is removeable allowing access to the rudder servo and linkage.
Before the first run I'll drop the model in the bathtub for a final ballast and ballance. I'm guessing a bit of weight will be required at the transom, so will hide that under the bench too.
Old Feb 19, 2004, 05:42 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Niel, Thanks for the kind words. I accidentally started building boats in high school but didn't get seriouse until just a few years ago. It's a great sideline to airplanes when it's too breezy to fly the lightweights! I also find boat building a bunch more challenging then airplanes, so when the mood strikes for a more "seriouse" project, boats are where I always end up.
PAT
