Old Aug 10, 2013, 05:02 AM
dazzo is offline
Find More Posts by dazzo
Joined Aug 2012
switching from lipo to nimh
Hi,ive recently bought a perkasa boat that runs on four 7.2 lipos and brushless motor,i want to change this to two 9.6 nimh batteries would i need to do anything to the speed controller,ive tried it and all that works is the rudder and sounds like a fan on the speed controller,thanks in advance for any advice.
dazzo is offline Find More Posts by dazzo
Old Aug 10, 2013, 06:56 AM
boater_dave is online now
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
Four 7.2 lipos? How are they connected?
Dave
boater_dave is online now Find More Posts by boater_dave
Old Aug 10, 2013, 08:13 AM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
Dazzo- if the 4 LI-POís are connected in series you will be running on 14.4 volts of power. If you connect the two NI-MH batteries in series you will be running 19.2 volts of power. First find out what your speed controls top voltage is rated at. Second you may have to re-program you speed control for the correct cut off voltage for discharge on the different batteries.
You may also have to reprogram the speed controlís throttle settings in order for the speed control top see neutral, full power ahead, and reverse.
frankg is online now Find More Posts by frankg
Old Aug 10, 2013, 04:58 PM
Tollytime is offline
Find More Posts by Tollytime
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
Let's see your setup first.
What size batteries do you have?
Tollytime is offline Find More Posts by Tollytime
Old Aug 10, 2013, 10:06 PM
tbarjohn is offline
Find More Posts by tbarjohn
tbarjohn's Avatar
aurora, il.
Joined Aug 2009
I have never messed with Li-po's but I think if you have 4, 7.2 volt Li-po's in series that would be 28.8 volts?
John R.
tbarjohn is offline Find More Posts by tbarjohn
Old Aug 10, 2013, 10:18 PM
Joined Dec 2004
I am sorry to say that I miss spoke about the voltage thinking in terms of 4 LI-PO cells at a LI-PO cell rating of 3.6 volts per cell. When I re-read the first post I see now you had four 7.2 volt LI-PO batteries which is 8C or 28.8 volts. Running two NI-MH battery packs of 9.6 volts (8 cells) you would be running at about 2/3rd the power of the LI-PO batteries at full speed.
Old Aug 12, 2013, 04:15 AM
dazzo is offline
Joined Aug 2012
Thanks,dont mind a loss of power as its a bit too fast,will get a pic later as im fairly new to rc and have no idea how to re set it
Old Aug 12, 2013, 02:08 PM
dazzo is offline
Joined Aug 2012
hi,the speed controller is a Hobbywing rtr version 2-4s lipo 3A@5.75v super bec
Old Aug 12, 2013, 02:13 PM
dazzo is offline
Joined Aug 2012
Old Aug 12, 2013, 06:55 PM
Big Boats Rule!
Wisconsin
Joined Jun 2007
If the new nimh pack voltage is far below the cutoff voltage currently set in the esc it will never run. The esc thinks you have a dead pack. You may need to reprogram the esc to turn off the low voltage cutoff, or at least set it to a voltage that works for your new pack.
Dave
Old Aug 13, 2013, 03:27 AM
dazzo is offline
Joined Aug 2012
Thanks Dave,how would i reprogram it?
Old Aug 13, 2013, 12:48 PM
Big Boats Rule!
Wisconsin
Joined Jun 2007
Most esc's have a setup button(s) somewhere, and there is a sequence to be followed to make any user setting changes. The instructions would be very helpful here. If there is no button, or connection port of any kind, then chances are that you cannot make any changes and would be stuck with the recommended battery configuration.
Dave
Old Aug 14, 2013, 05:04 PM
dazzo is offline
Joined Aug 2012
Thanks Dave,so if i change the speed controller to a regular one would i also need to change the motor as well?
Old Aug 14, 2013, 06:46 PM
Big Boats Rule!
Wisconsin
Joined Jun 2007
The motor and esc are only related in that the esc must be able to deliver the correct volts and amps to the motor. You should be able to replace the esc with another of similar capabilities. But that doesn't help you in this situation. The motor was chosen to run at a certain voltage for a reason. If you are going to swap out a battery for another of very different voltage, you must consider the prop, esc and power supply as a system. All the components must work together to get the job done. And to get the same job done, a system working at half the volts will require double the amps (ohms law).
Now, looking at your original post it appears that you are trying to swap a nimh pack for a lipo pack. Is there a deeper reason for this?
Dave
Old Aug 15, 2013, 01:58 AM
dazzo is offline
Joined Aug 2012
Thanks Dave,the main reason for changing is that i dont really want lipos in the house,heard horror stories etc,ive got nimhs in my other boats.
Question Switching my Nicd over to Nimh for my servos and receiver FmrMarine Engines 63 May 31, 2013 11:39 PM
Discussion How do lipo chargers know when to switch from CC to CV? cloud_9 Batteries and Chargers 24 Apr 26, 2013 02:08 PM
Discussion switch from NiMh to LiPo SparkyLawnDart Batteries and Chargers 8 Jan 07, 2013 01:16 AM
Discussion Switching from NiMH to Lipos chuckaug Beginner Training Area (Aircraft-Electric) 8 Jun 11, 2008 10:49 PM
Thinking about switching from Lipo back to NIMH NiCD Hard Wiggles Batteries and Chargers 29 Oct 07, 2005 10:52 PM
