Old Aug 09, 2013, 12:11 PM
kinGm is offline
Find More Posts by kinGm
Joined Jun 2013
Help!
Turnigy AE-100A Brushless ESC doesnt work
Hello,
im german so sorry for my bad english.
Today i solder the Turnigy AE-100 ESC and the Turnigy 500 H3126 Brushless outrunner 1600KV together and tested it with a MX-16 Hott.
If the throttle stick is on bottom position and i connect the battery (tested with 3 and 4 cell lipo) the ESC flashes red and Beep Beep fast.
If the throttle stick is on top position and i connect the battery the ESC is in program mode. But if i put then the throttle stick to bottom postion to select a program, nothing happens.
Trouble shooting says:
"After power on, motor does not work, such an alert tone is emitted and the red LED flashes at the same time. "Beep-Beep-" (Every Beep-Beep- has a time interval of about 1 second)".
--> Input voltage is abnormal, too high or too low.
"After power on, motor does not work, such an alert tone is emitted; "Beep-Beep-" (Every Beep-Beep- has a time interval of about 0,25 second)".
--> The throttle stick is not in the bottom (lowest) position.
I think that the Beep Beep is every 0,25 sec. but the red LED also flash, so i dont know wheres the failure. its a mix of both
My batterys are ok (tested three) and the throttle stick is also ok because it works with an other ESC.
Please help.
kinGm is offline Find More Posts by kinGm
Old Aug 09, 2013, 04:31 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Does that ESC have it's own BEC ?
A lot of higher powered ESC's don't have a BEC but need a seperate one.
Sorry if you know this but it has caught people out before if they are used to smaller ESC;s with BEC built in.
sparklet is offline Find More Posts by sparklet
Old Aug 09, 2013, 05:31 PM
kinGm is offline
Joined Jun 2013
yes the ESC has a BEC.
For Sale Turnigy Super Brain 100A Brushless ESC hmlow0 FPV Equipment (FS/W) 0 Aug 05, 2013 08:57 AM
Sold Turnigy Super Brain 100A Brushless ESC hmlow0 FPV Equipment (FS/W) 1 Jul 01, 2013 09:53 AM
Sold NIP, Turnigy AE-45A brushless esc with SBEC 5-6V/4A Ranchhand Aircraft - Electric - Power Systems (FS/W) 2 Feb 10, 2013 08:15 AM
Help! Turnigy Delux ESC 100A wont work! Help! planebldr Power Systems 15 Mar 01, 2012 09:19 AM
Help! Turnigy Sentilon 100A HV ESC only works with 72 Mhz Rx's leider Power Systems 6 Jun 07, 2009 07:55 PM
