Old Dec 06, 2001, 02:19 PM
Yoyodyne is offline
Find More Posts by Yoyodyne
Goodlettsville, TN, USA
Joined Jan 2001
Top Flight Cessna 182 Skylane Gold Edition?
I'm looking for a nice winter project, and my LHS has one of these on the shelf. I'd like a big electric plane that can handle those windy days that my Partenavia and Eco 8 heli can't, and with the optional cockpit kit the Skylane would make a nice looking bird. It doesn't have to be able to scream around the sky, but on the other hand I don't want to have to listen to all those rude comments by the gas guys, either. I'd like at least 10 minutes of decent flying time on a charge. A geared brushless setup is probably the way to go,and I am open for suggestions on which motor,prop,and cell count/type. The box says an 81" wingspan and a flying weight of 10-12 pounds, I'm not too sure on the wingloading. Any suggestions?
Yoyodyne is offline Find More Posts by Yoyodyne
Old Dec 06, 2001, 09:36 PM
PaulBrad is offline
Find More Posts by PaulBrad
PaulBrad's Avatar
Independence, KY and Brandon, MS
Joined Jun 2000
I have to confess to having this project under construction. It has been that way for four years. Some how I steped into a small field with a Speed 400 model and haven't been able to leave. I do plan on finishing my Top Flite 182 one of these days. It is completely framed up. When I started the project it was intended to be powered with a Saito .91 four stroke. As a result I do need to re-do the front end to accomodate the electric power plant.
I have an Aveox 1412/3Y and a Modelair Tech 3:1 H-1000 belt drive for the power system. I am planning on using 20 cells. My weight estimates and calculations suggest a total flying weight of 11 pounds. Ecalc indicates the model will fly nicely on that set up. I just need to get off the dime and get the model finished. It is a nice kit and I made no modifications to lighten up the airframe. Mine so far is fairly light for being a glow powered model. Hopefully, my weight estimates will prove to be accurate.
If you do purchase the kit, you will enjoy building this big bird.
Paul Bradley
PaulBrad is offline Find More Posts by PaulBrad
Old Jul 29, 2008, 01:04 AM
jaruwan is offline
Find More Posts by jaruwan
Joined Mar 2008
I am building the Gold Addition Cessna right now. The wood is heavy or pithy. I have talked with Top Flight and they say they don't have a problem. Sorry to say I am disappointed in the kit and it may become a hanger queen after all the work I put into it. I built one about ten years ago and didn't have any problems. I also have a Top Flight P-40 Warhawk and I have looked over the wood in it and I believe I am going to have to replace half of the sheet wood. The Cessna wing itself seems to build heavy but straight (the only good thing I can say about it). The balsa blocks for the Fowler flap setup had to be replaced because they were so soft drilling the holes was a pain. The balsa actually wound around the drill bit. I don't know if I got a kit that was made on Friday when everyone was going home or not. But I would look at it very carefully before I spent 180 bucks. I have a Super Tigre .75 in it and if it doesn't become a 82 inch wide truck I will be very surprised. I'm not a newbe in building... I started building planes when I was 13 and I'm 60 now. Been around the block a few times.
jaruwan is offline Find More Posts by jaruwan
Old Jul 29, 2008, 11:48 AM
jaruwan is offline
Joined Mar 2008
Guess I should have looked at the dates.... Sorry.
Discussion Top-flite Cessna 182 Skylane jmaurin Fuel Plane Talk 6 Aug 09, 2010 09:39 AM
Discussion Cessna 182 Skylane Maiden Flight! scareintheair Parkflyers 0 Jun 08, 2007 12:11 PM
Top Flite Cessna 182 Skylane Kit 1/5 scale Peter Khor Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2003 12:34 AM
Top Flite Cessna 182 King Kong Scale Kit/Scratch Built 10 Aug 10, 2003 11:33 PM
FS Top Flite Cessna 182 Skylane Kit Art Newland Aircraft - Electric - Airplanes (FS/W) 4 Aug 09, 2003 05:50 PM
