Old Feb 07, 2004, 09:34 AM
Gil Weiss is offline
Find More Posts by Gil Weiss
Gil Weiss's Avatar
Bensalem, PA.
Joined Sep 2001
Filip 400 RG Settings question
I am looking for recommendations on how much right thrust and down thrust I should build into this model. I am using an Aveox 27/13/3 with a 4:1 GB and a 12x6 folder.
I also could use recommendations on spoileron settings.
Thanks, Gil
Gil Weiss is offline Find More Posts by Gil Weiss
Old Feb 07, 2004, 10:53 AM
down_shift is offline
Find More Posts by down_shift
down_shift's Avatar
United States, VA, Leesburg
Joined Feb 2003
re: the spoilers, assuming you have the t-tail version, you can go as high as you want and the Filip will not exhibit any pitch changes. Start with a 1/2-inch or more, but be prepared to pull back on the stick to flatten out the sudden drop in altitude.
re: thrust, a few degrees down right should be fine. Isn't the nose already cut with the offset?
With that 4.3:1 GB and the /3 turn, you could use a MUCH bigger prop. Suggest starting with a 13x7 (assuming your batteries can handle over ~22 amps).
down_shift is offline Find More Posts by down_shift
Old Feb 07, 2004, 01:07 PM
Gil Weiss's Avatar
Bensalem, PA.
Joined Sep 2001
Thanks for the reply and inforamation. It is a T tail and tge fear box is a 4.3:1 (sorry). This set up is from Northeast Sail Planes and comes with an 8 cell KAN 1050 NIMH pack. I have several other 8 and 9 cell KAN packs so I hope they work out OK. There is not much room for Batteries in the fuse as it is fairly thin. I plan on putting the elevator servo in the tail.
The nose actually shows someleft thrust and literally no down thrust. There is no mention of the correct offset in the instructions or in the many posts on this model here which is why I ask. I'm figuring on maybe 2 degrees down and 2 right?
Thanks, Gil
Old Feb 07, 2004, 02:09 PM
down_shift's Avatar
Joined Feb 2003
If the nose is precut, then you will be fine. Simply glue in the firewall at the same angle. Use a 1/8-inch spacer for the firewall and stand fuse on the nose. This way it will be glued in at the correct angle and leave a small clearance for the GB screw heads and the spinner will be flush.
The Filip has TONS of room for batteries. You can even fit in a 9-cell pack of FAUP. Like you said, the key is to mount the elevator servo in the fin and mount the rudder servo behind the rear wing mount. Use the factory supplied servo mount as the battery mount. Put a piece of veloco on the mount and a piece in the rear of the fuse. Be sure to slide in the battery before glueing in the mount. Leave room to mount the ESC below the mount.
Good luck.
Old Feb 07, 2004, 02:13 PM
down_shift's Avatar
Joined Feb 2003
Here is a pic.
Pic of servo tray used as the front battery mount
Old Feb 12, 2004, 07:23 PM
MailOrderGuy is offline
Find More Posts by MailOrderGuy
Sir Buildsalot
MailOrderGuy's Avatar
Stockbridge, GA
Joined Nov 2002
Can you shown a pic of this installation please
Are you using an FAUP pack, if so what configuration?
Do you need a heavier pack in the nose to offset the servos in the tail?
MailOrderGuy is offline Find More Posts by MailOrderGuy
Old Feb 13, 2004, 07:22 AM
down_shift's Avatar
Joined Feb 2003
Sure. Will post some pictures this evening
I used 9-cell packs of 4/5AUP and 4/5FAUP. Both were configured in 3 end-to-end rows of 3 with the 3rd row in the "valley" of the bottom 2 rows. You can also fit in any 8-cell pack w/ the end-to-end configuration. No need to move up to the FAUPs w/ your motor, but you should use them if going over 28 amps or so.
Do you need a heavier pack in the nose to offset the servos in the tail? [/B]
Nope. Only use one servo in the tail. The MPi-50HP is an great elevator servo and it is small enough to fit into the fin. Cut the servo arm so it is narrower than the servo itself and the whole assy will fit w/in the fin for a clean installation. Okay to use the thin wire elevator pushrod supplied w/ the kit, but cut it down so it is ~ 2-inches long. Use a z-bend at the servo and a 90-degree bend (that is ~ 1/2-inch long) for the elevator control horn. When fitting in the balsa cap for the fin, cut a small notch at the top. This will support the elevator pushrod. Also make sure the elevator control horn is cut down so it is only 1/8-inch high only leaving the hole exposed at the same elevation as the bottom of the elevator. I'll post a pic later today.
Old Feb 13, 2004, 07:11 PM
jaywatay is offline
Find More Posts by jaywatay
electron liberator
jaywatay's Avatar
United States, GA, Suwanee
Joined Mar 2003
What servos would you guys recommend for the filip 400RG? Does it need the HS-81MG's for the ailerons and elevator? I was planning on using something fairly small for the rudder like one of the small Cirrus servos or an HS-55.
jaywatay is offline Find More Posts by jaywatay
Old Feb 13, 2004, 07:29 PM
down_shift's Avatar
Joined Feb 2003
use a pair of HS-85MG servos for the ailerons. Spend the extra few bucks over the 81 as they superior to them. The Mpi-50HP is great for the elevator (if installed in the fin) and anything tiny, old, and cheap for the rudder. HS-55 would be tossing money away unless you have one laying around.
Old Feb 14, 2004, 07:25 AM
flyingdogtwo is offline
Find More Posts by flyingdogtwo
.Denver, Co.
Joined Feb 2003
A shelf for the battery gives you lots of room, too.
flyingdogtwo is offline Find More Posts by flyingdogtwo
Old Feb 14, 2004, 07:36 AM
down_shift's Avatar
Joined Feb 2003
Servos in the factory shelf works w/ a smaller pack, say 8 Kans, which limits you to <20 amp motors. But moving up to >25 amp motors and C or 4/5A size cells, stick the servos in the rear of the fuse. It is a must.
Old Feb 14, 2004, 07:51 AM
down_shift's Avatar
Joined Feb 2003
Filip Rudder Servo
Profile a piece of balsa to match the fuse contour and epoxy it in for a servo mounting point. The goop the servo on its side as far back as you can go, but first remember to install the pushrod w/ the z-bend on the control horn:
Old Feb 14, 2004, 07:55 AM
down_shift's Avatar
Joined Feb 2003
Filip Elevator Servo
Goop it in the fin as high as it can go. Keep the pushrod short and square to the servo output shaft and arm:
Old Feb 14, 2004, 08:03 AM
down_shift's Avatar
Joined Feb 2003
Filip Elevator Servo Location
The servo is located here:
Old Feb 14, 2004, 08:07 AM
down_shift's Avatar
Joined Feb 2003
Filip Elevator Control Horn
Cut it down so it is tiny nub. Cut a matching slot in the elevator. No need to cut all the way through the elevator. Med CA works fine.
Discussion Filip 400 RG question ckh High Performance 2 Jul 16, 2007 04:29 PM
Filip 400 RG First Reactions SPasierb Electric Sailplanes 26 Jan 28, 2005 03:16 PM
absolute fleet thinng the goods. sr xmodels x 610, filip 400 rg, more filips, astro snowfallonme Aircraft - Sailplanes (FS/W) 2 Mar 14, 2004 11:14 PM
FS: filip 400 rg. V/T tail. NIKE astro, jeti, sokol, graupner. snowfallonme Aircraft - Sailplanes (FS/W) 0 Mar 13, 2004 01:38 PM
wtb: filip 400 rg snowfallonme Aircraft - Sailplanes (FS/W) 0 Jan 05, 2004 12:15 PM
