Old Feb 07, 2004, 03:10 AM
TNboy is offline
Find More Posts by TNboy
User registered
TNboy's Avatar
Melbourne Australia
Joined Jan 2004
Ammeter Circuit Diagram
Gday has anyone seen a circuit diagram somewhere on the Net for a high current in-series ammeter, or similar
TNboy is offline Find More Posts by TNboy
Old Feb 07, 2004, 03:28 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Most analog ammeters are just a shunt (calibrated piece of wire/metal) with a millivoltmeter connected across it. No circuit diagram really required.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Feb 07, 2004, 08:17 AM
Chippie is offline
Find More Posts by Chippie
North East England UK
Joined Jan 2003
If its a digital readout you're after, the ICL7106 lcd driver from Harris is pretty good, with a fsd of 200mV, you can make up your own shunts to range the reading you want.......
Chippie is offline Find More Posts by Chippie
Old Feb 07, 2004, 06:31 PM
TNboy is offline
User registered
TNboy's Avatar
Melbourne Australia
Joined Jan 2004
Thanks for that, confirmed what i was thinking, just thought maybe some one has work a more elegant way
thanks
Old Feb 08, 2004, 07:38 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Not sure what you're looking for, but there's no more elegant way than a simple voltmeter across a shunt..
..a
Old Feb 08, 2004, 06:05 PM
pullin-gs is offline
Find More Posts by pullin-gs
Arlington,VA USA
Joined Jan 2001
My recipie for an amp-meter and it's shunt:
http://www.rcgroups.com/forums/showt...ighlight=shunt
This one is good up to 30, or with the "X2" switch on, 60 amps.
Looking to upgrade to an "X4" soon. Iwill need to use some kind of heavy plug at these levels though.
Pullin'
pullin-gs is offline Find More Posts by pullin-gs
Old Feb 08, 2004, 09:28 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Nice to see, 'g..
I like the analog meter.. stops people getting so worked up about why motocalc shows 14.3A, but you measure 14.7..
..a
Old Feb 09, 2004, 08:57 AM
Talon Driver is offline
Find More Posts by Talon Driver
OK, Who's Flying The Jet?
Talon Driver's Avatar
Albuquerque, NM
Joined Apr 2002
No Money Required Amp Meter
Here is an entry on how to convert your generic analog multi-meter to a higher current amp meter: http://www.rcgroups.com/forums/showt...t=50+amp+meter
Cheers,
Chuck
aka
Talon Driver
Talon Driver is offline Find More Posts by Talon Driver
Old Feb 09, 2004, 10:38 AM
BobFlyer is offline
Find More Posts by BobFlyer
Panama City Beach, FL.
Joined Aug 2002
Ampmeter/Photo details/shunt
Here is a link to a previous topic on Ampmeters, I use a homebrew shunt that was easy to make..See page 2 of this link.
Photo's and connections..close up details.
http://www.rcgroups.com/forums/showt...5&pagenumber=2
It is very accurate, took about an hour to build from surplus parts I had available...short piece of wire, and something to mout the connections to, I used a dual fuse holder I had in my junk box.
Regards Bob.
P.s. I used a 1147 car bulb as a load to calibrate it against a know load...
BobFlyer is offline Find More Posts by BobFlyer
Old Feb 09, 2004, 11:47 AM
stefanv is offline
Find More Posts by stefanv
MotoCalc Developer
stefanv's Avatar
Moorefield, Ontario, Canada
Joined Mar 2001
Originally posted by Andy W
Nice to see, 'g..
..a
Hey, now there's an idea. An analog version of MotoCalc. The various tables MotoCalc produces could be full of little pictures of voltmeters, ammeters, etc.
Stefan
stefanv is offline Find More Posts by stefanv
Old Feb 09, 2004, 12:36 PM
foo is offline
foo
Find More Posts by foo
foo
Monroe, Louisiana, United States
Joined Aug 2003
I got a car amp meter that reads 0-60 plus and minus that I use inline.It's cal.in 5 amp steps.
foo is offline Find More Posts by foo
Old Feb 09, 2004, 05:59 PM
Foxy is offline
Find More Posts by Foxy
Joined Nov 2001
Another option.
http://www1.jaycar.com.au/productVie...=&SUBCATID=265
Adam
Foxy is offline Find More Posts by Foxy
Old Feb 10, 2004, 10:11 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Here’s some info on making a simple “shunt”; the picture below shows my shunt which I can plug into the fuse holder, allowing me to check the amps without disturbing my wiring:
“Use a 15 cm length of solid 14 gauge wire (e.g. from power cable for house wiring) and strip the ends leaving exactly 12.5cm of insulation in the middle. Solder thin wires at the edge of the insulation, which are to be connected to the voltage input on your multimeter.
When making a current measurement all you have to do is include the 14 gauge wire in series with your circuit and read the number of millivolts across it.
One millivolt equates to 1 amp because the shunt you have made will be very close to 1 milliohm.”
Here’s another shunt idea: http://www.marcee.org/Articles/AMPMeter.html , it comes from our electric web site where many other useful articles and tips can be found: www.marcee.org
Other advantages of my installation: affords maximum safety as power is only applied to ESC prior to take-off/taxi, RX/servos can be checked w/o power on ESC, packs can be charged/peaked pre-flight without removing pack, and pack voltage can be checked (eve under load) via charging connector.
jrb is offline Find More Posts by jrb
Old Feb 10, 2004, 10:22 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
I propose to use a 1,5kOhm in series and a 100uF in parallel to the Voltmeter input (200mV range). It is a simple low pass filter, it is necessary because the pulsed current otherwise makes the measurement innaccurate. (I mesured as high error as 15%)
mmormota is offline Find More Posts by mmormota
Old Feb 10, 2004, 10:33 AM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
A drawing:
Futaba TX RF Module Circuit Diagram? AndyOne Radios 6 Mar 21, 2005 05:34 AM
Circuit Diagram for zapper wanted..? pylonman Batteries and Chargers 4 Jan 24, 2003 05:26 AM
ESC for 4 x 400, plans or circuit diagram robertusher Foamies (Kits) 15 Sep 26, 2002 09:55 AM
ESC Plans or circuit diagram ???? robertusher Parkflyers 3 Sep 11, 2002 06:41 PM
question about circuit diagram?? raythomas Power Systems 13 Mar 04, 2002 07:45 AM
