Espritmodel.com Heli Air
Old Feb 06, 2004, 11:45 PM
Cogito Ergo Sum
Joined Dec 2003
Someone give me a valid reason why this won't work, seems too easy
My thread on power supplies got kinda off the track I was looking for, but check this out...I just ordered a Triton charger today (yes from the sponsors Mr. Andy W.) and I do not have a 5 amp power supply, I have a 3 amp I use for my Hobbico MKII. This power supply I was looking at is $22.88, 5 amps..tell me what you think.
http://www.bills2way.com/equip/ps7.html
http://www.bills2way.com/equip/images/large_ps7kx.jpg
or for $41.88
http://www.bills2way.com/equip/ps12.html
How can I Power two chargers with one supply since it only has one hookup??? can I run heavy gauge wire and "pig tail" it into two?? or is that dangerous??
Ronald Dobbs is offline Find More Posts by Ronald Dobbs
Old Feb 07, 2004, 12:34 AM
Dreamin' in 3D
Blackhawk3D's Avatar
Lodi/San Luis Obispo
Joined Oct 2003
Sorry about your other thread, that was my fault. I don't know about that one, but i have heard that this one is good. www.ramboy.com/cosel.htm
Blackhawk3D is offline Find More Posts by Blackhawk3D
Old Feb 07, 2004, 12:38 AM
Joined Dec 2003
cosel is a better choice, cheaper and higher current rating.
wacko is offline Find More Posts by wacko
Old Feb 07, 2004, 07:16 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
5A is not enough. Go with what they suggest above (although I can't stand those exposed A/C connectors!0..
I prefer the RadioShack 20-25A switched units - when on sale..
..a
Old Feb 07, 2004, 07:44 AM
Cogito Ergo Sum
Joined Dec 2003
what about my pigtail question
Old Feb 07, 2004, 07:51 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
With those power supplies, I wouldn't be running more than one anyway.
With a good power supply, however, you can make up an adapter, whatever works for you. I have 4mm "banana" plugs on all of my chargers, and made up an adapter with several 4mm female connectors that mount directly to the power supply output.
..a
Old Feb 07, 2004, 02:05 PM
Cogito Ergo Sum
Joined Dec 2003
So I bought the Triton charger because my Hobbico charger only does up to 8 cells and I am running a 9 cell GP 3300 pack. The triton charges at 5 amp max.....does my pack need to be charged at more than 5 amps to get the batteries optimal performance. My plane flies so fast right now and everyone says I am not even gettting it charged fully. what am I doing right or wrong?? was the triton the wrong choice?
Old Feb 07, 2004, 06:28 PM
Berks, England
Joined Jun 2001
The Triton is probably the right choice.
The thing is that although the Triton puts 5A out into the battery, it will pull more then 5A in from the power supply. It needs a higher input current to boost the output voltage up.
Stuart
stuartaw is offline Find More Posts by stuartaw
Old Feb 07, 2004, 08:04 PM
Cogito Ergo Sum
Joined Dec 2003
oh ok, makes sense. the triton will require more. so how many amps would I charge the 9 cell GP 3300 mah pack at??? will the triton auto-detect. charging at 1C is 3.3amps right??? or would I just charge it at 1 amp.
Old Feb 07, 2004, 08:05 PM
Cogito Ergo Sum
Joined Dec 2003
by the way, thanks for responding to all my questions, this transitions from gas has been an EXTREME learning curve but I am getting there. poor Andy W. has responded to all my questions....I appreciate that.
Old Feb 07, 2004, 11:01 PM
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Wierd...Ronald I have 2 Tritons and I run both of them with one of the Cosels from RAMBOY. (I have 3 just in case.) I've found that the secret to being able to fly a lot is not more battery packs but more chargers. Probably buy the Astro Lipo charger next.
Looks like we're traveling down the same path. Don't tell me you just bought a Groove!
feathermerchant is offline Find More Posts by feathermerchant
Old Feb 08, 2004, 01:18 AM
Cogito Ergo Sum
Joined Dec 2003
I have a bid in now on a 25 amp radio shack power supply. If i do not get that I might go with the cosel one. Is it pretty simple to get it up and running? can I run multiple power leads from it? The radio shack one is only one single lead so I would have to make some kind of adapter so I can run multi chargers.
Old Feb 08, 2004, 07:23 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Someone explained that you need more current in than out - this is true for more than about 7 cells (as 8 or more requires >12V out)..
Also, note that very few power supplies will deliver 12V at rated current. Most will drop significantly as they get close. So if you buy, say, a 10A power supply, it may trigger low voltage warnings (which often terminate the charge cycle) on your charger at around 7A..
That's why a nice beefy 20 or 25A unit is best for larger packs of high capacity cells. For the parkflyers, however, the small ones do work just fine..
..a
..a
Old Feb 08, 2004, 07:33 AM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
In vs out:
Say a 12cell GP3300 pack is charging, the voltage on avg. = 1,4V/cell. 10cells = 16.8V
Charged at 1C = 3.3A
Power needed is 16.8V x 3.3A = 55.44VA
Then the powersupply under this load maintain a output voltage of 13.5V:
55.44VA / 13.5V = 4.1A drawn from the supply. (on avg.)
Then say a 20cell GP3300 pack running at 5A:
20cells x 1.4Vavg = 28V
28V x 5A = 140VA
140VA / 13.5V = 10.37A
Haldor is offline Find More Posts by Haldor
Old Feb 08, 2004, 07:47 AM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
The Ramboy works wonderfully on my Triton. Never an issue.
$$ is right - you will be fine with it...
mike
pda4you is online now Find More Posts by pda4you
GWS tell me why 2 Park HPX and 2 small Naros won't work steve ypsi mi GWS (Grand Wing Servo) 25 Nov 05, 2005 09:21 PM
Can someone give me a hand with this cowl (see pic) ontheweekend The Builders Workshop 13 Jan 19, 2005 03:40 PM
Tell me why this wouldn't work... EDF 75 sukhoi26mx Parkflyers 45 Feb 23, 2003 07:57 AM
Okay, Tell me why this isn't a good idea... lrsudog Life, The Universe, and Politics 29 Jan 22, 2003 09:01 AM
ESC WON'T WORK? RICH S Power Systems 7 May 17, 2001 09:15 AM
