Old Feb 06, 2004, 10:28 PM
daryl is offline
Find More Posts by daryl
Wow!My plane flies!
daryl's Avatar
Sarawak,Malaysia
Joined Sep 2003
GWS "turbo"
Hi,
Can GWS or other company make turbo for electric plane?
It requires 5 channel radio for the turbo?And need extra battery.
That will be more fun
daryl is offline Find More Posts by daryl
Old Feb 06, 2004, 11:05 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
What's turbo you are talking about?
GWS4CEO is offline Find More Posts by GWS4CEO
Old Feb 07, 2004, 12:07 AM
daryl is offline
Wow!My plane flies!
daryl's Avatar
Sarawak,Malaysia
Joined Sep 2003
You press the button and it will fly faster
Old Feb 07, 2004, 02:28 AM
Dax is offline
Dax
Find More Posts by Dax
Dax
There is no spoon
Dax's Avatar
Vancouver BC Canada
Joined Aug 2002
umm
Dax is offline Find More Posts by Dax
Old Feb 07, 2004, 04:40 AM
omega blood is offline
Find More Posts by omega blood
Will work for planes
omega blood's Avatar
Fullerton, California, United States
Joined Jan 2002
It's called a brushless motor.
omega blood is offline Find More Posts by omega blood
Old Feb 08, 2004, 09:52 PM
The Disturbed 1 is offline
Find More Posts by The Disturbed 1
Flying Fanatic & Lunatic
The Disturbed 1's Avatar
Sillicon Valley, California, USA
Joined Dec 2003
This would be more of your own setup. Use whatever electronics you so desire, and get it goin!
The Disturbed 1 is offline Find More Posts by The Disturbed 1
Old Feb 11, 2004, 07:19 AM
daryl is offline
Wow!My plane flies!
daryl's Avatar
Sarawak,Malaysia
Joined Sep 2003
http://www.qd-race.com/turbokit.html?dis_img=14
Old Feb 11, 2004, 01:27 PM
Peter Khor is offline
Find More Posts by Peter Khor
Peter Khor's Avatar
Mostly in Norman, OK
Joined May 2002
daryl ... thanks for the link, I had a good laugh Please don't be fooled by such products. I'll try to explain it as brief as possible. Basically the 2-5 relays switch in and out the output to the motor thru a ceremic resistor network; at 'low' speed the resistor takes up the current and turns it into heat, and passed less power to the motor (so all your battery capacity is used to heat up the resistors). At 'tubo' mode all resistors are bypassed and all the voltage is fed to the motor. Resistor controlled motors is something from 25 years ago.
So you want turbo mode on your GWS plane? Fly around with the throttle stick only push forward 1/2 way ... that's your 'normal' mode. To get into turbo mode, push the throttle stick all the way forward - wow, feel that turbo power! Basically the same principle, except that you don't waste all your battery on on heating up a bunch of resistors.
Remember if it's too good to be true ... it usually isn't.
Peter Khor is offline Find More Posts by Peter Khor
Old Feb 11, 2004, 08:42 PM
daryl is offline
Wow!My plane flies!
daryl's Avatar
Sarawak,Malaysia
Joined Sep 2003
Thanks for the info
Old Feb 12, 2004, 11:17 AM
nose_first is offline
Find More Posts by nose_first
nose_first's Avatar
Riverview, FL
Joined Dec 2002
maybe thats what Spinal Tap used to get their amps louder - 11 instead of 10
nose_first is offline Find More Posts by nose_first
Old Feb 12, 2004, 11:43 AM
ScYcS is offline
Find More Posts by ScYcS
Just fly the darn wing!!!
ScYcS's Avatar
Germany, NRW, Herford
Joined Oct 2003
nose
Great movie!!
ScYcS is offline Find More Posts by ScYcS
Discussion GWS Ag Flyer and GWS Turbo Bush plane? wmcneal GWS (Grand Wing Servo) 3 Apr 01, 2007 01:19 PM
