Old Aug 03, 2013, 06:44 AM
mongdex is offline
Find More Posts by mongdex
If it flies, I like it.
Thailand, Sing Buri, In Buri
Joined May 2012
Gasoline/4 stroke helicopters?
Hi,
Are there any gasoline or four stroke heli copter engines up for sale?
Thanks.
mongdex is offline Find More Posts by mongdex
Old Aug 03, 2013, 11:03 AM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
You mean, "are there any of those in production currently"
Or is your question "does anybody have (a used) one for sale"?
Answer to first question: Vario of Germany has a SkyFox version suitable for a 27 cc OS Boxer twin.
That is a glow engine, but fourstroke.
They also had, in the grey past, a SkyFox suitable for an OS 15 cc single cylinder fourstroke glow engine.
Other than those I do not know of helicopters specifically designed for fourstroke engines.
Gassers however, are plenty and diverse.
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Aug 03, 2013, 11:36 AM
mongdex is offline
Joined May 2012
sorry for the vague question.
I did mean are there any in production. More interested in gassers tho. Anymore info is greatly appreciated.
Thanks!
Old Aug 03, 2013, 12:31 PM
The Netherlands
Joined Nov 2009
To my knowledge, there are currently no 4-stroke gasser helicopters in production.
But that does not mean a thing, as my knowledge is by far not including every make and model, so I hope somebody else can answer your question more conclusively
Brgds, Bert
Old Aug 03, 2013, 07:20 PM
mongdex is offline
Joined May 2012
How about 2 stroke gasoline and four stroke glow?
Thanks.
Old Aug 04, 2013, 08:36 AM
The Netherlands
Joined Nov 2009
Four stroke glow, I allready told you.
Gasolien 2-stroke, there are literally too many manufacturers that make good examples of these, to mention them all.
Virtually all leading brands have helicopters in heir program, either directly suitable for 2-stroke gasoline, or for which a conversion kit is availlable.
Nowadays, OS even has a 15 cc gasser engine based on a glow design, suitable to use in most 90 size Nitro heli's. As far as I know, this engine is a good runner.
I know of at least one case of someone fitting an NGH 17 cc gasser in a 90 size heli ( I was not really impressed by the running behaviour, but OK) and several people have converted glow engines to run on gasoline, with varying degrees of succes.
There are many helicpters, designed to run a Zenoah, and most of them are good.
So I'd say: Surf the WWW, and take your pick!
Brgds, Bert
Old Aug 04, 2013, 08:45 AM
mongdex is offline
Joined May 2012
Thanks alot
The gas engines - are they specifically made for helis? or are they plane engines with adaptors?
Old Aug 04, 2013, 10:48 AM
keris is offline
Find More Posts by keris
keris's Avatar
Malaysia, Perak, Taiping
Joined Jan 2012
OS GT15 Gasoline
OS has come out with gasoline engine it fit most of 90 size heli...this is on trex700
keris is offline Find More Posts by keris
Old Aug 05, 2013, 12:04 AM
mongdex is offline
Joined May 2012
Old Aug 05, 2013, 02:47 PM
Chophop is online now
Find More Posts by Chophop
What Tough Luck Is This ?
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
These gassers are supposedly bugs worked out and ready for "Fill and Fly". Century Radikal heli's.
http://www.centuryheli.com/products/....htm?pageid=86
Chophop is online now Find More Posts by Chophop
Old Aug 05, 2013, 06:31 PM
The Netherlands
Joined Nov 2009
Originally Posted by mongdex View Post
Thanks alot
The OS GT 15 is specifically designed for helicopter use.
The NGH is a plane engine, you have to make it fit a helicopter yourself (but what I have seen, I would not want to go that way).
The Zenoah's, well they are still the same modified weedwhacker motors you will also find in big scale cars and other big models, but they do a good job in helicopters as well.
The ones you can buy through Vario in Germany are expensive, but they are balanced better, and they have a non-standard carb that is optimised for "constant RPM/variable load", the operational condition that in the RC domain is exclusively found in helicopters. They are in this version optimised for 10-11 kRPM.
IMHO they are very much worth the extra money, especially if you plan to fly big scalers.
Brgds, Bert
Old Aug 05, 2013, 06:38 PM
mongdex is offline
Joined May 2012
Well, I guess I'll go the OS or possibly the NGH route. Just want a gas heli to fly around and maybe 3d.
Thanks.
Old Aug 05, 2013, 06:46 PM
The Netherlands
Joined Nov 2009
Better forget the NGH.... apart from being Chinese (which is not exactly a guarantee for consistent quality) the cooling (finned area) is not calculated/designed for helicopter use, and because you have to modify the shaft to accept a flywheel and clutch the engine as a package becomes too long, and the carb is absolutely not suitable for the heavy load changes that occur in 3D.
And I doubt, it even comes close to the power needed.
For you the OS is the only way, if you want a "glow style" helicopter.
Otherwise you have to go the Century-route.
Brgds, Bert
Old Aug 05, 2013, 06:55 PM
mongdex is offline
Joined May 2012
Yea. So OS.
Century is out of the question. Just dont feel like spending that much on it since I wont be flying scale.
Old Aug 05, 2013, 09:21 PM
Chophop's Avatar
Joined Sep 2006
Oh sorry mondex, you asked for engines. I goof now and then.
Sold Valach VM 120 B2-4T 4-Stroke Gasoline engine ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 2 Aug 06, 2012 10:39 PM
Discussion Petrol/Gasoline 4 stroke Quorneng Engines 1 Jan 28, 2011 06:06 PM
Discussion Conversion to gasoline :Saito 56 4-stroke Texas Buzzard Engines 14 Nov 28, 2008 08:58 AM
Cool 72" 4-Stroke gasoline boat!!!! boat_builder Racing Boats - Internal Combustion 3 Nov 21, 2008 10:55 PM
Discussion UAV engine, 50cc, 4-stroke, gasoline mattom Engines 18 Nov 11, 2008 09:15 AM
