Old Aug 01, 2013, 09:38 PM
danrothwell is offline
Find More Posts by danrothwell
Joined Aug 2013
Blade Nano qx wont lift
My new blade nano qx will not lift off the ground. I am new to this hobby.
Please, any help appreciated.
Nano qx won't lift (0 min 25 sec)
I reset all the trim. The blade are on right side up and in the correct position as far as I can tell.
danrothwell is offline Find More Posts by danrothwell
Old Aug 02, 2013, 04:36 PM
dcom is offline
Find More Posts by dcom
United States, GA, Suwanee
Joined Aug 2008
Was the battery charged up completely?
Did you put it on a flat, level surface within a few seconds of connecting the battery?
What transmitter are you using?
I had the same problem a minute ago after I'd swapped the yellow for green props. Turns out I put them on the wrong motors. so maybe you need to swap them.
dcom is offline Find More Posts by dcom
Old Aug 02, 2013, 05:24 PM
jason4207 is offline
Find More Posts by jason4207
Eye to the sky!
jason4207's Avatar
United States, NC, Concord
Joined Dec 2012
Hold it your hand while giving throttle. Do all 4 props push air down?
jason4207 is offline Find More Posts by jason4207
Old Aug 02, 2013, 06:10 PM
Malzurog is offline
Find More Posts by Malzurog
Joined Aug 2013
BRAND new to this as well, but just in that short amount of time I learned that even the slightest damage to the props can cause enough issues to keep the little guy grounded. A trick i learned on the forum is to hold it upside down. Throttle up (In SAFE mode) just a little bit and slowly tilt the nano from side to side. The lowest engine should be the only one operating as it is trying to right itself. Doing this can help you find which engine or prop is giving you problems. It just sound SO different than the others. Anytime I have any problems, its the first thing that I do. I have always been able to determine which prop is giving me problems.
Malzurog is offline Find More Posts by Malzurog
Old Sep 11, 2013, 08:06 AM
LMahesa is offline
Find More Posts by LMahesa
Ia! Ia! Cthulhu Fhtagn!
LMahesa's Avatar
Indonesia, Jakarta
Joined Jul 2013
It is the props. I had this yesterday and figured out the problem - it's a fairly easy fix, actually.
The problem is that the 'weak' props have lost their pitch angle. Take a good prop, and hold it against something bright with one blade facing your eye. See the 'X' shape made by the two blades? Now look at your 'bad' prop. You'll find that the 'X' is much shallower.
To fix, simply grip the blades close to the hub, then twist them in the appropriate direction. Get it to match the 'good' prop as much as possible.
Don't bother twisting further for a deeper angle hoping for better lift - I tried that, and, while it flew, it vibrated like crazy and I overstressed the hub plastic.
While you're at it, make sure the curve at the tip of each blade is the same as that tends to flatten out with crashes. Do this AFTER smoothing out any nicks with your fingernails.
LMahesa is offline Find More Posts by LMahesa
Old Jan 08, 2015, 08:24 AM
train06 is online now
Find More Posts by train06
Hell-lee bent
train06's Avatar
United States, TX, Arlington
Joined Mar 2014
A little strand of hair wrapped around one or more shafts will also affect flight
train06 is online now Find More Posts by train06
