Old Jul 31, 2013, 01:22 PM
theghosttanker is offline
Find More Posts by theghosttanker
United States, NY, Lewiston
Joined Apr 2011
Help!
Flap programming with ATX RDS8000
I'm trying to figure out how to set up flaps and crow for a 6-channel (Victory) sailplane on an Airtronics RDS8000. Normally, flaps go on channel 6 but I had to plug my second aileron servo in there, leaving me to plug my flaps (two servos on a Y harness) into throttle. Does this mean I can't use the 3-position flaps feature, on the "flap" switch? I want to be able to set 3 flap positions....slightly reflexed up, straight, and slightly down, on the flap switch, and then use the throttle stick to get flaps and crow for landings. The radio manual says something about the throttle stick controlling flaps and crow in the "landing mode", but other than that it's not much help. How are you guys setting up your programs on this radio?
theghosttanker is offline Find More Posts by theghosttanker
Old Aug 02, 2013, 04:22 AM
Pippin is offline
Find More Posts by Pippin
Joined Sep 2002
http://www.rcheliguy.com/global/airt...ne%20Setup.pdf
Pippin is offline Find More Posts by Pippin
Old Aug 02, 2013, 01:52 PM
Joined Apr 2011
very helpful, but not exactly what I want. I'm still having trouble getting flaps down without having ailerons crow....and I'm running my flaps on a y-harness.
Old Aug 02, 2013, 02:14 PM
jcabetas is offline
Find More Posts by jcabetas
Joined Oct 2012
I don't know the mixing capabilities of your radio. If the mixing are poor, or imposible to use as is the case with FPV-RTH, you can use a mixer.
In my case I have a EagleTree OSD that make imposible to use mixing with the autopilot, so I programmed a mixer with a miniarduino board (mixer). If you have programming experience is fairly easy to build. Other posibilities is to use a convencional mixer, although then you can't use the flaps for thermalling (well, depends on the mixing capabilities of your emitter)
jcabetas is offline Find More Posts by jcabetas
Old Aug 02, 2013, 06:03 PM
tom1968 is offline
Find More Posts by tom1968
Still circling in sink...
United States, MA, Grafton
Joined May 2006
Just guessing here based on my old RD6000, but here's a go:
1. Plug flaps into throttle channel
2, Per manual (p. 44?) , set flaps EPA to zero if you don't want aileron-flap coupling
3. either use throttle trim button to adjust flaps, or
3. physically exchange the 3-position flap switch and the 2-position gear switch, and mix gear to throttle
Maybe someone else can suggest something better
tom1968 is offline Find More Posts by tom1968
Discussion ATX SD 10G Program XavierG Hand Launch 4 Feb 14, 2013 07:56 AM
Discussion Atx 10G Programming for DLG Joe7 Hand Launch 11 Feb 09, 2013 10:54 AM
Discussion RDS8000 program for ailerons & flaps w/no Y's gstottrup Radios 1 Apr 15, 2012 12:42 PM
For Sale Custom TX screen protectors - DX7, Aurora 9, JR 9303, SD-10G, ATX RDS8000 Garret H Aircraft - General - Radio Equipment (FS/W) 56 Sep 01, 2011 10:10 PM
