Old Nov 20, 2013, 05:02 AM
kha is offline
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Originally Posted by grunff View Post
Can you please send me a link to your blog. I would like to see taranis schematic.
Have a nice day.
Schematic is so simple that one can figure pretty much everything needed from opentx code alone.
:-D
kha is offline Find More Posts by kha
Old Nov 20, 2013, 05:12 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
You could figure out what the inputs and outputs are from the source, but there is a lot more to a schematic than that.
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 20, 2013, 05:14 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
^^^ ... and is under NDA, sorry
Do you intend to clone a Chinese product ?
renatoa is offline Find More Posts by renatoa
Old Nov 20, 2013, 05:20 AM
pmackenzie's Avatar
Joined Dec 2002
Schematic needs to be put out there for hacking purposes.
Anyone wanting to clone the radio would find it a trivial task to figure it out anyway, so the NDA makes no sense
Old Nov 21, 2013, 12:37 PM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
Originally Posted by MrFixit View Post
Is the Taranis safe in this area, or do I have to add somme sort of protection (Diode or zener diode)?
Trainer input has a 100 Ohm series resistor, with a diode to VCC.This goes directly to the CPU output pin, and thropugh a transistor buffer to the CPU input pin.
Positive should not be a problem (at least for the Taranis, maybe not so much for the slave radio).
Negative might not be very healthy, would need to check if the CPU is OK with negative voltages on Hi-Z configured pins.
Same for a hacker, nothing a pair of eyes and a continuity tester won't find out
Kilrah is offline Find More Posts by Kilrah
Old Nov 21, 2013, 06:55 PM
pmackenzie's Avatar
Joined Dec 2002
What about a lazy hacker ?
Details of things like how the audio circuit is powered for example could help in figuring out how to address the noise.
This is a hack thread, but the lack of schematics is keeping the number of hacks way down.
No haptic yet for example, something a lot of guys would probably want to add.
Old Nov 21, 2013, 08:11 PM
ChristianGeek is offline
Find More Posts by ChristianGeek
ChristianGeek's Avatar
United States, CA, Carlsbad
Joined Sep 2013
FrSky Taranis hardware hacks
A couple of questions regarding the module bay pins:
1. I'm only measuring 2.3V between voltage and ground...does that seem right?
2. Does anyone know what the high/low range is for the PPM and S.PORT pins (I don't have easy access to a logic analyzer).
Thanks.
ChristianGeek is offline Find More Posts by ChristianGeek
Old Nov 22, 2013, 07:58 AM
Kilrah is offline
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
PPM is battery voltage through 10k. SPORT would accept up to 5V I reckon.
2.3V likely suggests you have external module turned OFF, and as such supply is off as well.
http://openrcforums.com/forum/viewto...p=63998#p63982
The devs don't hang out on RCG much.
Old Nov 22, 2013, 03:20 PM
svjerk is offline
Find More Posts by svjerk
Joined Mar 2013
New Power Switch Board
Aloft now stocks the new power switch board capable to charge 2000mAH.
What's the difference between the new and the old?
Can old one be modified (replacing voltage divider resistors?) to handle 2000mAH cells?
svjerk is offline Find More Posts by svjerk
Old Nov 23, 2013, 04:43 PM
Thorvald is online now
Find More Posts by Thorvald
Canada, ON, Innisfil
Joined Aug 2010
I just did the swap tonight and it's a totally new PCB with some extra components. It's so cheap, I'd just buy the replacement switch.
Cheers
Tim
Thorvald is online now Find More Posts by Thorvald
Old Nov 23, 2013, 05:09 PM
Joined Aug 2010
I think my next hack will be to install a removable antenna on the Taranis, so I can use the antenna from the External Tx module and simply screw it on and off.
http://www.alofthobbies.com/2db-module-antenna.html
Old Nov 23, 2013, 09:08 PM
Khosravi is offline
Find More Posts by Khosravi
Chris Khosravi - KK4LJH
Khosravi's Avatar
United States, GA, Marietta
Joined Jul 2004
That was the first modification I did with my Taranis:
Khosravi is offline Find More Posts by Khosravi
Old Nov 23, 2013, 10:20 PM
Joined Aug 2010
Awesome! Can you provide any details on how you did it?
Did you manage to find a connector that fit snug in the throat of the old antenna mount or did you have to glue it in and futz with it? (I assume its an SMA correct?)
That looks perfect!
Old Nov 24, 2013, 04:53 PM
bobf is offline
Find More Posts by bobf
Sparky "Electrics Rule"
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
First thing I did to my Taranis today was swap the momentary with the 2 way switch on the other side. Didn't feel like soldering in any wires, so here is how it can be done.
1) open radio
2) remove the nuts holding the two switches in place.
3) remove the switches and unplug the connectors from each.
4) plug the switches in to the opposite side.
5) re-install them. Keep the connectors facing left as before to get the correct switching directions.
Now to keep the programming the same: (Momentary switch has some special applications in opentx)
6)Carefully unplug connector from P8 on the RF daughter board (top one on the right side) pulling on alternate ends seems to be the best way to remove it.
7) Swap the two wires shown, first from the left with third from the right.
(Use the tip of an xacto, small jewellers screwdriver to hold up the plastic tab while pulling on the wire) Make sure they are in all the way and the right way up when you re-install them.
8) plug back in the connector. Support the free end of the PCB while rocking it in end to end as you did when removing it. Make sure it is fully seated.
Done.
Ultimately i will replace the momentary with a SPDT ON-OFF-Momentary switch, that will probably require some soldering.
While I had it open I used a bit of hot melt to fasten the wires to the switches to keep them away from the gimbals. My throttle was hanging up on them a bit.
Sounds simple enough. Frsky should do that on all mode 2 radios. Got love the Taranis.
bobf is offline Find More Posts by bobf
Old Nov 24, 2013, 05:25 PM
dang is offline
Find More Posts by dang
USA, WA, Olympia
Joined Jan 2001
Very cool. Thanks Kilrah.
dang is offline Find More Posts by dang
New Product FrSky Taranis - 16 Channels, Full Telemetry, RSSI Rotozuk Radios 49765 Yesterday 11:41 PM
Question FrSky Taranis - assimilating web info mcshaz Radios 10 Sep 10, 2015 02:34 PM
Discussion is the FrSky Taranis next step after Turnigy 9X 9Ch tormodnt Radios 3 Nov 30, 2014 06:58 PM
Wanted FrSky Hack module, Flydream Hack or JR module Fentonflyers Aircraft - General - Radio Equipment (FS/W) 5 May 28, 2014 12:33 AM
