Old Aug 02, 2013, 04:13 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Taranis don't use pots, sensu stricto, they are angular rotation sensors, same used in Futaba radios, so next level are hall or other magnetic or optic sensors, as Jeti.
renatoa is offline Find More Posts by renatoa
Old Aug 02, 2013, 04:24 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
They are potentiometers (aka adjustable voltage divider; aka variable resistor, etc). Hence "pots". Angular rotation sensors on the other hand may or may not be potentiometers.
LittleMo is offline Find More Posts by LittleMo
Old Aug 02, 2013, 05:20 PM
renatoa is offline
Joined Sep 2007
Sure, the output is a variable voltage, but even a hall sensor produce a variable voltage output. Check this guy conversion:
http://openrcforums.com/forum/viewto...p=45405#p45394
Old Aug 02, 2013, 05:35 PM
AndreaMontefusco is offline
Find More Posts by AndreaMontefusco
AndreaMontefusco's Avatar
Italy, Lazio, Rome
Joined Dec 2006
Originally Posted by renatoa View Post
Sure, the output is a variable voltage, but even a hall sensor produce a variable ....
Not always, there are hall sensors that are true absolute encoders
http://www.ams.com/eng/Products/Magn...sition-Sensors
using such sensors, you need only an i2c in order to read the data.
even Allegro has some interesting product in its catalogue.
AndreaMontefusco is offline Find More Posts by AndreaMontefusco
Old Aug 02, 2013, 11:36 PM
TheAeronut is offline
Find More Posts by TheAeronut
12th Pursuit Squadron
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
The devices in the Taranis gimbal assemblies ARE potentiometers (a trace of resistive material with a movable contact element that traces along and can read the resistance or voltage along the reistive element) that are enhanced with amplifiers to increase the output signal response over a fraction of the potentiometer's full range.
Calling them 'angular rotation sensors' may be correct for their overall function but does not change the fact that the 'angular rotation sensors' used in the Taranis are potentiometers. There are other technologies that can be used for 'angular rotation sensors' such as hall effect sensors or various types if interruptor wheels capable of producing a direct digital representation of the sensor position, but none of these other technologies are used in Taranis. The potentiometer, op-amp enhanced or not is still the cheapest technology available and is used in all but a VERY FEW and VERY EXPENSIVE consumer/hobby radio control systems.
J.P.
TheAeronut is offline Find More Posts by TheAeronut
Old Aug 03, 2013, 12:14 AM
Coolpins is offline
Find More Posts by Coolpins
better at crashin than buildin
United States, TN, Luttrell
Joined Aug 2012
so we need to do a Hall effect upgrade
Coolpins is offline Find More Posts by Coolpins
Old Aug 03, 2013, 01:04 AM
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
I do find the hall effect mod interesting and may try it sometime, on some radio. Not likely on my Taranis any time soon though.
J.P.
Old Aug 03, 2013, 09:45 AM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
You would think someone would manufacturer an all-in-one Hall effect sensor in a small potentiometer-like package.
I wonder what happens to Hall senors in the presence of strong EMI or magnets. For example, if near a power station or when using rare earth magnet clips on the radio.
Old Aug 03, 2013, 09:50 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
There are lots of them, just google "hall effect potentiometer"
http://www.potentiometers.com/select_hall.cfm
Hall sensors will be affected by magnets, but you have to get them quite close to have any effect.
Magnetic fields drop off very fast, and typical AC feilds are much lower than those in close proximity to the magnet in the hall sensor.
Enclosing the sensor in a steel ring would be enough to shield it.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Aug 04, 2013, 12:55 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Poti change
The stick potis in the Taranis are perfectly fine and adequate for the job. I't just that they were put in an environment that was, how to put it, an unlucky design. If the mechanics don't center correctly, a better poti or hall sensor won't change a thing.
Speaking of potis, i changed the ones at the top of the TX near the switches. I got some ALPS (Japan) with a ratchet, so you feel 18 clicks at 180 rotation. I also used other knobs which are slightly bigger and grippier than the original ones.
Potis:
http://www.ebay.de/itm/15x-Raster-Po...-/300936522056
Knob:
http://www.conrad.de/ce/de/product/183662/
The left 2pos switch was changed for a pushbutton. I plan to make the TX read all telemetry values when I push it. A test worked fine.
Julez is offline Find More Posts by Julez
Old Aug 04, 2013, 01:02 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Internal antenna mod
Update: Do not perform this mod! I got RSSI warnings as near as 200m. Control was fine though, but normally RSSI warnings should not appear this near!
Update 2: I was told that I soldered the shielding to the other soldering pad the stock antenna was soldered too. If really the left pad was not connected to ground, but only the right one is, this would explain my fairly bad results.
On all my other radios, the antenna sits inside the case. So I did the same thing with my Taranis.
Before unsoldering the original antenna, I placed the RX in the garden shed and in the house some rooms away and noted the RSSI readings.
Then I unsoldered the original antenna.
At first I tried the flexible Quamum antenna from HobbyKing, but it got worse RSSI readings as the original one.
So I soldered on the original antenna and put it in front of the module bay.
Before, I got an RSSI of 37 for the garden shed, and 60 for the house.
Now I got 40 for the shed and 62 for the house.
So at least there's no harm done concerning range.
Old Aug 04, 2013, 01:05 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Eneloop battery for the Taranis
As I like both eneloop cells and long flight times, I made a new 8s battery for my Taranis.
I guess the pictures say it all.
Because people asked:
http://www.ebay.de/itm/1-x-Crimping-...item1c3541ddd3
These are the crimpers I use for the JST connectors. Crimpers for servo connectors won't work as they are too wide.
Old Aug 04, 2013, 01:08 PM
renatoa is offline
Joined Sep 2007
You are really hard to please
Old Aug 04, 2013, 01:12 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
So I soldered on the original antenna and but it in front of the module bay.
Did you test at various Tx orientations to make sure there are no unusual dead spots in the propagation?
Daedalus66 is offline Find More Posts by Daedalus66
Old Aug 04, 2013, 01:35 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
I know. I'm a perfectionist by heart. But this pays of in so far as that my stuff never fails.
Next thing to come will be a 3Pos switch for 3 audio volume levels.
Or can the software volume be assigned to a switch via software?
Not yet. But I have mounted TX antennas in much more cognested constellations, and it worked out fine.
But I still promise that I won't raise a stink should I encounter RF problems with my mod.
New Product FrSky Taranis - 16 Channels, Full Telemetry, RSSI Rotozuk Radios 46990 Today 06:53 AM
Question FrSky Taranis - assimilating web info mcshaz Radios 10 Sep 10, 2015 03:34 PM
Discussion is the FrSky Taranis next step after Turnigy 9X 9Ch tormodnt Radios 3 Nov 30, 2014 07:58 PM
Wanted FrSky Hack module, Flydream Hack or JR module Fentonflyers Aircraft - General - Radio Equipment (FS/W) 5 May 28, 2014 01:33 AM
