Old Sep 02, 2013, 07:43 PM
flybrain is offline
Find More Posts by flybrain
Canada, AB, Edmonton
Joined Jul 2013
MXS R Maiden Video (7 min 27 sec)
flybrain is offline Find More Posts by flybrain
Old Oct 05, 2013, 04:25 PM
okybs is offline
Find More Posts by okybs
Joined Oct 2009
The center of gravity of the airplane as set out in a schedule?
okybs is offline Find More Posts by okybs
Old Oct 07, 2013, 11:47 PM
flybrain is offline
Joined Jul 2013
c of g
Yes I used c of g point from the manual which was 100mm from leading edge at fuselage. This at least seemed to be a good starting point. Just to update this plane took quite a hard blow nose first and came away with very little damage. A cracked cowling and wheel pant and broken rudder when plane flipped over on it's back. Cause was radio went into failsafe so It went to idle and unfortunatly just made it to the landing field instead of going down in tall grass just short of field. Need to change antenna location and fix up some medal on metal control wires on choke and throttle. Will fly again just have not had time to repair yet. For as hard as it hit it came away quite well so these are fairly well built models. Live and learn on things that will cause radio interference. Just seemed odd to go as many flights as it did before failsafe kicked in, although I had just changed choke rod and went from nylon clevis to 90 degree bend witha quick link. That might be all it took?
Old Nov 03, 2013, 11:05 AM
MarLi is offline
Find More Posts by MarLi
United States, IN
Joined Jun 2011
... sorry, it was not right posting on someone else build log.
MarLi is offline Find More Posts by MarLi
Old Dec 01, 2013, 05:52 AM
MarLi is offline
United States, IN
Joined Jun 2011
flybrain are you still there ?
How is your plane coming ?
Mine after maiden with the 2S 91 I decided to go gas and I am waiting on a DLE-20RA from tower. Should be not so difficult to refit.
cheers,
MarLi
Old Dec 18, 2013, 04:25 PM
flybrain is offline
Joined Jul 2013
MarLi sorry My old computer finally crapped out so I didn't have one for a while. Anyway I am not familiar with which make of model you have there or what wingspan etc. but on my plane at a 65" wingspan seemed to handle a 30cc quite well. I balanced only using battery and where I placed radio equipment. also I used stock cg from plans. On maiden actually needed down trim and still seemed to like to float on landings. After a small incident when my radio went into failsafe I have made repairs and this plane really does fly quite well and I am happy with the way it turned out. I think if I would have used my 20cc it would also have had more than enough power with a little bit of weight saving. Either way would have been fine.
Old Dec 23, 2013, 03:52 AM
SLoViper is offline
Find More Posts by SLoViper
Canada, BC, Cranbrook
Joined May 2013
I just received mxsr form hobbyhobby but there wasnt any pushrods included only for ailerons. Was is the same with yours? I will set it up for a saito 125 since i have one laying around. What servos are you using in yours? I am thinking about savox sc 0252 mg.
Could you please tell me what size cf tube did you buy?
SLoViper is offline Find More Posts by SLoViper
Old Dec 24, 2013, 12:45 AM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
The push rods are in the tail wheel bag if it was like mine. Regardless, they were to long and just made my own. Putting a saito FG-21 in mine.
gewiens is offline Find More Posts by gewiens
Old Dec 27, 2013, 01:14 AM
SLoViper is offline
Joined May 2013
How do you think is should mount the engine since the manual isnt that clear.
Old Dec 27, 2013, 02:16 AM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
Mounting my fg 21 sideways with head to the right. 125 is basically the same as mine in a nitro version. Using the existing aluminum tube on my bird because I know I won't stress it out with extreme flying.
Old Dec 28, 2013, 01:01 AM
SLoViper is offline
Joined May 2013
I will use the same tube as i wont be doing any extreme aerobatics with it. Are you using the tank that came with it or are you putting something else in. I am thinking of putting a dubro 16oz.
Old Dec 28, 2013, 01:22 AM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
Ha. Yep. I'm using the dubro tank also. Tried putting a gasoline plug in the original tank and it just pulls out.
Old Dec 30, 2013, 11:55 PM
SLoViper is offline
Joined May 2013
How did you bolt the tail gear? The bolts that were included wuth mine were too big and i snapped the blind nut out trying to screw them in. I found the pushrods for the ailerons but there were none included for the tail section.
Old Dec 31, 2013, 12:09 AM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
I used the supplied screws for my tail wheel without a problem. You had no rods in the fuse at all? Mine were in the fuse in place out of the box.
Discussion Seagull MXS-R 91-120 wing tube bending. Nitro2Burn Fuel Plane Talk 37 May 08, 2015 07:30 PM
Discussion Seagull MXS-R aerophilia Glow to Electric Conversions 44 May 30, 2014 06:05 PM
Discussion Aerobeez 88" 30% MXS-R Electric Version jonathan7x70 3D Flying 1 Jan 14, 2013 12:06 PM
Question DLE 30 what for this fuel Tank for on DLE 30 Johnsmith122 Engines 5 Jan 09, 2013 03:18 PM
New Product Seagull Mini MXS-R Park Flyer pdansalvish Parkflyers 3 Dec 28, 2012 03:33 PM
