RC4WD - July Product releases
11 new items
Variety of upgrade parts for either improving a vehicle’s scale appearance, performance or even a means to transport it.
Hilux 4WD Emblem Set for Mojave and Hilux Body
Product Specifications:
  • Made from stainless steel
  • Thickness is .4mm
  • Easy to finish
Product Number: Z-S0930
Retail Price:$10.99
MSRP: $7.99
Mickey Thompson Classic Lock 1.9" Internal Beadlock Wheel
These are the all new Licensed Classic Beadlock Wheels. These have been officially licensed by the Mickey Thompson tire and wheel company and are only available from RC4WD and our dealers.
  • CNC machined aluminum internal beadlock design
  • Wheel size: 1.9"
  • OD: 1.9in (53mm)
  • Width: 1.05in (26.7mm)
  • Back spacing: 13.0mm
  • Each weight: 2.5oz (71g)
  • Fits standard 12mm hex
  • Scale wheel nut cover with MT logo
  • Uses scale hex head bolts for realistic look
  • Unmatched detail
Part Number: Z-W0007
Product Retail Price:$159.99
MSRP: $129.99
BigDog 1/8 Dual Axle Scale Car/Truck Trailer
This is the new 1/8 car or truck hauler. Larger bed for the bigger hauls. Perfect for towing around your rig to events or showing it off. Dual axles for extra towing capacity. Features full working leaf springs.
  • Handmade tube trailer chassis
  • Billet aluminum wheels
  • 1.55 Dirt grabber tires
  • Steel leaf spring
  • Working lift jack
  • Steel tool box for battery and light switch
  • Working lights
  • Easy clip hitch mount
  • Two steel ramps
  • Ramp holders
  • Length: 25.59in (650mm)
  • Width: 14.84in (377mm)
  • Height: 4.33in (110mm)
  • Whitebone inspired design
Product Number: Z-H0004
Retail Price:$289.99
MSRP: $239.99
6pc 6" Heat Shrink Assortment
RC4WD brand heat shrink to cover those troublesome electrical connects to prevent shorts.
  • Length: 2.5mm x 153mm - 3/32 x 6" inch
  • Length: 3.5mm x 153mm - 1/8 x 6" inch
  • Combined Weight: 0.38oz / 11g
Product Number: Z-S0942
Retail Price:$4.99
MSRP: $2.99
Red Tie Down Strap with Metal Latch
  • Metal bBuckle
  • Black anodized
  • Tough red strapping
  • Length: 15.7in / 400mm
  • Width: 0.13in / 3.5mm
Product Number: Z-S0929
Retail Price:$11.99
MSRP: $8.99
Black Tie Down Strap with Metal Latch
  • Metal buckle
  • Black anodized
  • Tough black strapping
Product Number: Z-S0925
Retail Price:$11.99
MSRP: $8.99
RC4WD Extreme Duty XVD Axles for Axial / AX10 / Honcho / Dingo / Rubicon Axles (Scorpion, SCX10)
Completely redesigned from the ground up to allow extreme steering angles and built to handle heavy power. Made for the Axial AX10 Series of axles used under the SCX10 truck series.
  • CNC machined super hardened steel
  • Heat treated
  • All new design
  • Easy installation
  • 50 degree steering angle
  • Designed to fit Axial / AX10 / Honcho / Dingo/ Rubicon front axles
  • Extremely durable
Product Number: Z-S0902
Retail Price:$72.49
MSRP: $59.99
D44 C Hub for Wraith AR60 Axle
  • CNC machined
  • Black anodized smooth finish
  • Direct fit to AR60 steering axle
Product Number: Z-S0892
Retail Price:$42.49
MSRP: $34.99
Triton Transfer Case (1:1)
This is the all new Triton Transfer Case. Can be used in the Trail Finder 2 and Gelande 2. The scale detail is unmatched. The cast case provides good looks and the super strong gears inside allow you to have the strength you need on the trail.
  • 1/1 gearing
  • 32 pitch gears
  • Hardened steel gears
  • Cast casing
  • Wide gears
  • 8 bearing design
  • Has same mounting as our popular Killer and Hammer transfer case
  • Weight: 2.7oz / 77g
Product Number: Z-U0029
Retail Price:$92.49
MSRP: $74.99
RC4WD Gelande Spare Tire Cover fits 1.55, 1.7 and 1.9 This is a black elastic tire covering with the RC4WD Gelande embroidered into the face. Makes a great tire cover for your new Gelande, or any truck build. Dress up that spare.
  • Black elastic material
  • Fits most sized tires under 4.78" / 121mm
  • OD: 4.10in / 104.3mm
  • Width: 1.65in / 42mm
Product Number: Z-S0931
Retail Price:$12.99
MSRP: $9.99
Aluminum Front Shock Mount for Vaterra Twin Hammer
  • Heavy-duty CNC machined
  • Smooth anodized finish
  • Corrosion resistant
  • Maintains OEM fit
Product Number: Z-S0904
Retail Price:$22.99
MSRP: $19.99
Visit the site for more info on RC4WD products and see the thousands of other products they carry!
There are no posts
Sold RC4WD Pulling Tires cdaniel13 Cars - Trucks and Parts (FS/W) 0 Mar 17, 2013 02:03 PM
Sold RC4WD R2 Disco trans w/ SCX10 skid plate greedyg76 Cars - Trucks and Parts (FS/W) 0 Mar 13, 2013 11:42 PM
News RC4WD Trail Finder 2 Scale Truck Build Terry Car Talk 0 Mar 05, 2013 08:24 AM
Discussion 4th of July products added Stamp Car Talk 0 Jul 03, 2009 08:06 PM
July Sale at Smooth Air Electric Flight Products Morb Vendor Talk 0 Jul 02, 2005 09:22 AM
