Old Jul 29, 2013, 12:35 AM
Boofhead is offline
Find More Posts by Boofhead
That will simply buff out
Boofhead's Avatar
Australia, NSW, Kareela
Joined Jul 2001
XRP 14 Blade 70mm Fan Unit
Just saw this released on the X-Flight web site - I wonder how this will compare with the 10 and 12 blade 70mm units?
http://www.x-flight.com.hk/?sp=&p=6&...w=&lang=en&ev=
Boofhead is offline Find More Posts by Boofhead
Old Jul 29, 2013, 09:06 AM
SLATYE is offline
Find More Posts by SLATYE
Joined May 2010
I was just thinking about getting a 12-blade one for the Vampire. Now I've ordered both the 12-blade and 14-blade ones. I wonder where the limit is - will we be seeing 20-blade 70mm fans before too long?
SLATYE is offline Find More Posts by SLATYE
Old Jul 29, 2013, 09:41 AM
WeMoTec is offline
Find More Posts by WeMoTec
Willich / Germany
Joined Nov 1998
I would say the limit is under 10.
Oliver
WeMoTec is offline Find More Posts by WeMoTec
Old Jul 29, 2013, 10:49 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
14 blade thrust to watt claims look nice...worth trying
erh7771 is online now Find More Posts by erh7771
Old Jul 29, 2013, 04:03 PM
Air-Jon is offline
Find More Posts by Air-Jon
world's slowest builder
Air-Jon's Avatar
CA
Joined Oct 2006
I bet the efficiency is down form the 10 blade which sounds good enough to me. For applications where a person wants a scale looking fan like an airliner or an A-10...this would be great! Those type of planes can take the efficiency hit. This would look so good on those Wingrider B737s.
Air-Jon is offline Find More Posts by Air-Jon
Old Jul 29, 2013, 05:18 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
efficiency down, wooooshhhh up. what people will buy! lol am I reading that correctly? $16 bucks for a fan?
Static Thrust: 1250g ( 2lbs ) 48A the efficiency would exponentially decrease after this mid range peak number. just my hunch..
stoneenforcer is offline Find More Posts by stoneenforcer
Old Jul 29, 2013, 06:58 PM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
...we will see. The 12 blade was not too bad from what people said...so maybe the 14 blade will just be another bump down. I mostly worry about the shaft adapter quality with these fans. I guess there are aftermarket adapters that will probably work with this rotor as it looks similiar to the 10 and 12 blade rotor adapter style.
Old Jul 29, 2013, 07:01 PM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
...of course you only see the rotor when the plane is static...so i guess it is not really worth losing the performance for me. i think i will wait for the other high-blade count 70mm fan coming out soon.
Old Jul 29, 2013, 07:39 PM
Joined Nov 2005
4.5lbs thrust peak > 4lbs of settled ~ 1100 watts 30usd shipped for the 10 blade and an L2855 2300kv ... worth waiting on ..The 12 blade 70mm settled numbers are even better
Turnigy L2855-2300kv - 5S - CS 10 Blade Test (2 min 11 sec)
Some CP motors Proper ducting brings out the performance, plenty of vids to attest to
No need to pay 2 - 3 times more for 1 to 2% increase in performance with the 10 and 12 blades and proper ducting
The shaft adapters on the v3s balance out of the box, 3 - 4 clock turns
What one gets with the 2 - 3 times more in cost with some rotors is the increase in max RPMs and therefore increase eflux and some others attributes
We'll see, they've had a miss before...mostly hits
Old Jul 29, 2013, 09:10 PM
FireHawx is offline
Find More Posts by FireHawx
FireHawx
FireHawx's Avatar
United States, NV, Reno
Joined Oct 2011
Is XRP a whole nother fan or is it another ChangeSun? I love my 12B so I may get the 14 till I find a good application. Maybe a BL32/6S/14B??!!
FireHawx is offline Find More Posts by FireHawx
Old Jul 29, 2013, 11:03 PM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
XRP not another ChangeSun
http://www.windrider.com.hk/product.asp?id=170
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Jul 30, 2013, 06:36 AM
FireHawx is offline
FireHawx
FireHawx's Avatar
Joined Oct 2011
So what is the difference between the two fan?
Old Jul 30, 2013, 07:35 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
More balance and sound.
Ming Lou
Site Sponsor
Old Jul 30, 2013, 08:55 AM
FireHawx is offline
FireHawx
FireHawx's Avatar
Joined Oct 2011
Is the rotor as rigid as the CS fans?. So they are somewhat balanced? What about the collets, are the made "true".
Old Jul 30, 2013, 11:49 AM
LukeDaUke is offline
Find More Posts by LukeDaUke
LukeDaUke's Avatar
Joined Feb 2010
Ming Lou
Ming, the XRP 70mm 14 blades EDF unit are pre balanced?
LukeDaUke is offline Find More Posts by LukeDaUke
Discussion High Performance 70mm fan units skyzking Electric Ducted Fan Jet Talk 97 Dec 28, 2015 02:07 AM
Sold 2 70mm fan units and ESCs Beancounter Aircraft - Electric - Jets (FS/W) 1 Apr 30, 2013 01:39 AM
Sold 70mm EDF Fan units. Two for $14 shipped! The Don Aircraft - Electric - Jets (FS/W) 19 Mar 19, 2013 09:39 PM
Sold 2 x 70mm Fan units + 3 x Freewing Motors alfajet Aircraft - Electric - Jets (FS/W) 3 Feb 25, 2013 03:08 AM
