Old Jul 28, 2013, 03:11 PM
JohnRCox46 is offline
Find More Posts by JohnRCox46
United States, FL, Stuart
Joined Jul 2013
Question
Nose Wheel Steering with a V-Tail and Spektrum DX8
I want to set up a power plane with a V-Tail and would like to have nose wheel steering that works right. I plan to use a Spektrum DX-8.
I have thought that I might be able to set up my V-Tail and then mix rudder into something like an Aux channel to get the unmixed rudder on my stick.
Does anyone have any experience with this? Even better has anybody made it work?
JohnRCox46 is offline Find More Posts by JohnRCox46
Old Jul 28, 2013, 04:36 PM
freechip is online now
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
When you create a mix your are selecting an input (master) to a channel. (Slave)
Regardless if you have V tail enabled your mix is still just using the rudder stick as the input for the mix.
If it has retracts you could use the gear switch so that when the gear is retracted the nose wheel mix is off.
freechip is online now Find More Posts by freechip
Old Jul 28, 2013, 05:29 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Look at the eflite Bonzana online manual. It should explain it.
1320fastback is offline Find More Posts by 1320fastback
Old Jul 29, 2013, 12:33 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes.
Let's use AUX3 as an example. Go to the Switch Select screen and make sure that nothing is assigned to aux3 (normally it's the knob).
Now go to the Mix menu. Mix RUD > AX3 at 100%/100% and the switch set to On (default0.
Done.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jul 30, 2013, 09:29 PM
Joined Jul 2013
Thanks for your help! I feel a lot better about this next project.
Old Oct 14, 2013, 06:23 PM
Don Vanhook is offline
Find More Posts by Don Vanhook
Joined Dec 2009
Can the set up be the same on a spectrum DX7 ?
I have the fly fly f-100 and can't get the elevator and nose wheel to work properly. When I get the elevator (both sides) to work together, then the nose wheel turns the wrong way.
Don Vanhook is offline Find More Posts by Don Vanhook
Wanted Vladimir 2m Organic Nose Cone, V-tail Assy Thomasec Aircraft - Sailplanes (FS/W) 14 Jul 16, 2013 03:27 AM
Discussion Independent Nose Wheel Steering Servo? sundog Beginner Training Area (Fuel) 4 Mar 29, 2013 04:39 PM
Sold Robart 654 Nose Gear Strut with Steering Column $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 0 Jan 13, 2013 01:32 PM
Sold Futaba 3PK Radio with Spektrum module and metal steering wheel tittelba Cars - Cars and Parts (FS/W) 0 Feb 26, 2011 07:57 AM
Advice for take off of a tail dragger with steering wheel S55 Modeling Science 46 Jan 21, 2005 08:00 PM
