Old Jul 28, 2013, 02:05 AM
Jab69 is offline
Find More Posts by Jab69
Jab69's Avatar
South Africa, GP, Alberton
Joined Sep 2009
Templates for foam cutting
Hi
What material do you guys use to make templates from.
Jannie
Jab69 is offline Find More Posts by Jab69
Old Jul 28, 2013, 02:50 AM
OutcastZeroOne is offline
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
I use doubled up poster board, thick art board. On thin parts I will spread a thin amount of superglue to stiffen up the board. I've used my cardboard/artboard templates multiple times and they hold up great.
Some guys are able to get scraps of formica from cabinetry shops. Others also use thin metal or wood.
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Old Jul 28, 2013, 08:44 AM
Jab69 is offline
Jab69's Avatar
Joined Sep 2009
Hi
I also find using cardboard is far more handy and easier to use.Cheaper and when needed to redesign sections of the plan one just copies the existing template and draw the mod on the new copy and cut out.I also find that I can use that template 2-3 times with good results.
Old Jul 28, 2013, 10:09 AM
dr.E is offline
Find More Posts by dr.E
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
Go to your local pizza place and ask for some unfolded pizza boxes..... Make sure you order a pizza though and then get the freebie boxes.......
dr.E is offline Find More Posts by dr.E
Old Jul 28, 2013, 10:39 AM
Joined May 2005
the cardboard I use is not the curagated stuff. it is hard pressed, flat cardboard. The official name is Architectural Chip Board.
Old Jul 28, 2013, 01:03 PM
TimOBrien is offline
Find More Posts by TimOBrien
Palm City, FL
Joined Dec 2000
For a lot of smaller parts I save and use old cereal boxes.
TimOBrien is offline Find More Posts by TimOBrien
Old Jul 28, 2013, 02:35 PM
Frank Rys is offline
Find More Posts by Frank Rys
Frank Rys's Avatar
Monson,MA
Joined Mar 2000
Plain old paper..
Frank Rys is offline Find More Posts by Frank Rys
Old Jul 28, 2013, 05:16 PM
CarlN is offline
Find More Posts by CarlN
Canada, BC, Vancouver
Joined Nov 2012
For something a bit more durable I use lite-ply with thin copper foil wrapped around the perimeter. You can get sticky backed thin copper foil from stained glass stores in 7/16 or so widths, works perfect for a template that you will want to use again becaise it prevents burn in from the hot wire. I haven't done it, but you could wrap the same foil around cardboard or poster board for something quicker, but I like the lite ply. The foil works really well, highly recommended.
CarlN is offline Find More Posts by CarlN
Old Jul 28, 2013, 06:16 PM
Zagadka is offline
Find More Posts by Zagadka
Liverpool, UK
Joined Aug 2004
I pretty much always use 0.5mm aluminium sheet. Really easy to cut with just a pair of scissors and with a sanded edge smooth and durable to guide a wire. My current project though I bought some 1mm sheet that was just really cheap on ebay. Certainly durable but not quite as easy to work with!
Kev
Zagadka is offline Find More Posts by Zagadka
Old Jul 28, 2013, 11:02 PM
Jab69 is offline
Jab69's Avatar
Joined Sep 2009
Hi Kev
How easy is it to cut the aluminium sheeting.Is it easy to cut small radiuses or do you need a small tin snips which has a radius on the cutting section?
Jannie
Old Jul 29, 2013, 04:59 AM
zetland76 is offline
Find More Posts by zetland76
zetland76's Avatar
Ilkley, UK
Joined Apr 2007
I bought some birch veneer from a woodwork supplier at a very reasonable price. I glue my printed template to it and cut them out with a Stanley knife. Sand the edges. Pin them to the foam with dressmakers pins, then hot-wire to cut the wing blanks.
I have tried most other materials, but the hot-wire seems more prone to snag.
Although the copper foil round the template edge also worked well for me.
zetland76 is offline Find More Posts by zetland76
Old Jul 29, 2013, 07:12 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use Formica for the templates. The edges need to be absolutely smooth to keep the wire from hanging up. If it stops at all it will leave a notch in the foam. I end up using 600 water paper for the finish. I tried metal templates but found the aluminum absorbed the heat from the wire and cooled it enough so that it would leave a rough finish at the template end of the foam.
Gord
flypaper 2 is online now Find More Posts by flypaper 2
Old Jul 29, 2013, 07:25 AM
Jab69 is offline
Jab69's Avatar
Joined Sep 2009
Hi
Why I use the cardboard is that it is easy enough to cut with a normal scissors.I've tried formica(the type which comes on kitchen tops) but it is so damn hard to cut. And when one wants to cut all those mods to suit your shape, cardboard is the easiest.
Old Jul 29, 2013, 01:12 PM
T_om is online now
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
Gord
Which is why I glue a cardboard "standoff" to the side against the foam. No problem.
Tom
T_om is online now Find More Posts by T_om
Old Jul 29, 2013, 05:27 PM
swede-rcgroups is offline
Find More Posts by swede-rcgroups
United States, IA, Grinnell
Joined Mar 2005
omit comment
swede-rcgroups is offline Find More Posts by swede-rcgroups
Question templates for core cutting steeg Slope 3 Jan 27, 2013 05:49 PM
Question Copper Tape for Foam Cutting Templates AirBorne_AZ Flying Wings 12 Sep 12, 2006 11:27 AM
fuselage template for foam cutting SCOTTA1 The Builders Workshop 1 Nov 27, 2005 08:17 PM
Foam Cutting Template Material For Sale Mark Miller Aircraft - Sailplanes (FS/W) 11 Jul 10, 2004 06:53 PM
