Old Jul 27, 2013, 03:06 AM
viperrepair is offline
Find More Posts by viperrepair
Joined Apr 2013
How to find your plane in an 8ft. high corn field
Lost my plane in a cornfield. Strapped my cell to my 1200mm Toprc fw190 and did three search flights. A grey blob appeared on the second movie for all of .03 seconds but it was the only grey blob in the whole field so I counted rows and paces to make a map and sure enough there she was. Took me ten minutes to find here safe and sound....batt was dead so its toast but she still fires up....you had to be there...took 3 days to do all the logistics bye the way. Guess I'm patting myself on the back here but also hope that this helps someone some day.
Thanks for listening.
viperrepair is offline Find More Posts by viperrepair
Old Jul 27, 2013, 04:20 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Glad it got it back.
If generally flying over corn fields, or tall crops, it may be worth doing a thread search on lost model locators. There are quite a few about now.
8ft tall corn ?, how long did it take the search party to find you ?
eflightray is offline Find More Posts by eflightray
Old Jul 27, 2013, 07:31 AM
Electrofish is offline
Find More Posts by Electrofish
United States, FL, Stuart
Joined Apr 2012
Cornfied stories:
My old club was on a grass field the size of a football field, the approch end abbutted a corn field, so you had to come in low and slow over the corn, before chopping the power. One day, I came in a little slow and stalled into the corn!!! Corn and model airplanes don't mix well - what a mess.
Story 2:
The farmer who farmed the cornfield didn't like model planes. He claimed we "ruined" his corn when searhing for planes. That was total BS. What he liked to do to break our chops was run over our well groomed field with his tracto,r leaving tire ruts.
One night, vandels, (none of us) did doughnuts with their cars all through his almost ready crop, destroying about 90% of it.
Talk about poetic justice.
Electrofish is offline Find More Posts by Electrofish
Old Jul 27, 2013, 07:46 AM
BigIron357 is offline
Find More Posts by BigIron357
25+ years of RC flying
BigIron357's Avatar
United States, FL
Joined Aug 2012
Over 20 years ago I was flying at a club with a large open area. Had my little 1/2A sized glow plane and when I launched it I accidentally turned off the receiver switch! The plane climbed out beautifully and headed straight toward the woods well over a 1/4 mile away... then started turning and looping before it dropped into the treetops. I noted the tallest tree next to where it went down.
A couple of days later I brought a compass with me to the field when no one else was there. Took a bearing on the tall tree and started walking a course and went across the field and all the way through the woods. Turned back around and took the reverse course and found my plane lying on the ground about 1/2 way back through the woods. It was essentially undamaged. Flew it the following weekend.
BigIron357 is offline Find More Posts by BigIron357
Old Jul 27, 2013, 08:10 AM
DustBen is offline
Find More Posts by DustBen
DustBen's Avatar
United States, AL, Birmingham
Joined Dec 2011
My solution would be to cut down the cornfield...
He shouldn't be growing that stuff near an RC field anyhow.
(Just Joking!)
DustBen is offline Find More Posts by DustBen
Old Jul 27, 2013, 08:18 AM
Tony K is offline
Find More Posts by Tony K
United States, MI, Monroe
Joined Jun 2009
Be respectful of the farmers crops, its his income. My cub had went down in a tall cornfield before I got the smarts to stay away from certain area's. It's possible to look around and not tare the crops up too bad. I took my controller in with me and on occasion work the controls, finally got myself close enough where I could here the servos working. If not for for the noise,, I don't think I'd have found it. Planes are hard to find in crops, and where ya think it went down is usually a bit off from where it actually is. Good Luck!
Tony K is offline Find More Posts by Tony K
Old Jul 27, 2013, 08:38 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Flying at Liepaja .... two brothers also .... one was 3D 'g and other had a beautiful scratch built early soviet job ... all depron moulded cowls etc. Beautiful job.
He's flying and it really did fly nice ... he then looped the model ... and we saw the LiPo falling to earth ... the model completed the loop ... and carried on gliding ....
He trotted of in general direction while I looked for his LiPo ... which was found in good condition ...
He returned about 1/2 later .... with a model in perfect condition ... but broken prop. He changed the prop ... popped another LiPo in ... and flew ...
The photo is AFTER and just before he flew again !!
Nigel
solentlife is online now Find More Posts by solentlife
Old Jul 27, 2013, 08:46 AM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
I had one lost in a corn field for 3 days, but finally lucked out and found it. We just worked across the rows at various intervals, but had probably been by it a dozen times before finding it. Aerial photo would not have helped as it was flat on the ground in 9' tall thick corn.
On your battery, mine was dead as they can get also and had melted down the motor, but I put the battery on charger set to nicad and brought it up to 10 volts or so if I remember right, then it would charge as a lipo and it came up perfectly and I'm still using it a year and half later without a glitch.
bobly is offline Find More Posts by bobly
Old Jul 27, 2013, 10:11 AM
ttabbal is online now
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
I would get a loud beeper. Then you could follow the sound. Some will start beeping if they don't see any change in servo inputs for a while.
I've also heard of people putting a streamer on the plane, which usually lays on top of the plants. Might not work as well on mature corn though.
ttabbal is online now Find More Posts by ttabbal
Old Jul 27, 2013, 10:27 AM
FLTRI is offline
Find More Posts by FLTRI
Der Schaum-Kriegsvogel Pilot
FLTRI's Avatar
United States, NV, Las Vegas
Joined Jan 2013
About the only crop we grow is sand and sagebrush, but this would probably be cheap insurance if I lived where green things actually grew out of the ground...
http://www.hobbyking.com/hobbyking/s...y_Buzzer_.html
FLTRI is offline Find More Posts by FLTRI
Old Jul 27, 2013, 10:43 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
My story from a few years ago: http://www.rcgroups.com/forums/showthread.php?t=897240
Finding downed planes is an adventure many times!
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jul 27, 2013, 11:40 AM
Helno is offline
Find More Posts by Helno
Canada, ON, Kincardine
Joined Feb 2009
The usual tool to find missing model airplanes in a cornfield is a combine.
Helno is offline Find More Posts by Helno
Old Jul 27, 2013, 12:04 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Like this?
hoppy is offline Find More Posts by hoppy
Old Jul 27, 2013, 02:58 PM
Joined Apr 2013
Exactly,I was very careful that's why After trying to hear the controls (plane was way farther out than I thought) and with the highway right there couldn't here a thing. My transmitter(and me) came out of there a new color.... green lol
But Yes I crouched through row after row so as not to hurt the corn. (Can you say leg cramps) Plus the owner lets me fly there as long as I shut the gate when I leave. So yes respect is important. This is why I did the recon flights so as to spend as little time in there as possible (Its not fun either) 80 paces up row by the white bush and over 22 rows to the right and there she was. I think I
will put up a vid of the section to see if you guys can see the plane hehe.
sighting from above (0 min 4 sec)
Old Jul 27, 2013, 03:00 PM
Joined Apr 2013
HAHA that's what I was thinking so I was up against a combine and I won
Discussion How to Find your Heli Windy Miller Micro Helis 7 May 16, 2013 12:13 PM
Discussion How Can You Tell If Your Sport Plane CG is Set Properly When In Flight? itsme2 Electric Plane Talk 18 Feb 16, 2013 09:58 PM
Discussion Ever lost your plane in a high tree? How lucky can these guys be? Grantham Kid Electric Plane Talk 5 Oct 29, 2012 10:21 PM
Discussion how to find out how high your rockets go? monboy10 Rocketry 7 Jan 27, 2009 10:26 AM
Gallery Corn fields in the outskirts of Coimbra joao Your Plane Photos 0 Apr 19, 2003 03:44 PM
