Old Sep 13, 2013, 08:44 AM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Hi nelsonlee, first of all thank you so much for entertaining me of this problem...
I have all the needed software and files for upgrade...ok here's how I did
1. download and install UP02 tools
2. download x350 upgrade files
3. open UP02 software and on com port 10 for the communication
4. confirm on device manager it is com port 10
5. plug in the UP02 adaptor to pc and x350 with
White - Blue
Red - Yellow
Black - Black
6. Click connect
7. connect battery fully charged
8. Got no x350 found...so no further step taken...
What else can I do?
I have ask the seller to contact walkera factory but till date no good news but asking me the same questions over and over again on example
1. have I connected to pc usb port?
2. have I connected the 3 colors plug to up02?
3. have I connected battery?
4. have I install the software?
5. have I downloaded the upgrade file?
etc...I don't know how others feel but I feeling just pure stupid just to repeating my answer to walkera sale person...
OnceAFly is offline Find More Posts by OnceAFly
Old Sep 13, 2013, 08:58 AM
djmorgan is offline
Find More Posts by djmorgan
djmorgan's Avatar
Australia, QLD, Gold Coast
Joined Aug 2013
Okay, The Walkera notes and normal windows driver operation behave in this manner.
You install the software which will also install the virtual serial driver.
You plug in the usb connection and a 'new hardware' advice will pop up (if you have done this a number of times it won't you'll have to uninstall and find the INF file to delete)
The new device will either install the driver or ask a location, I'm assuming it will be in the software folder, once the driver is installed you can continue.
Now I can't say the above will work as I have not done it I don't have the adapter yet, but it is the normal process for drivers and Windows OS.
David
djmorgan is offline Find More Posts by djmorgan
Old Sep 13, 2013, 09:09 AM
nelsonlee is offline
Find More Posts by nelsonlee
Malaysia
Joined Nov 2012
White - Blue
Red - Yellow
Black - Black
6. Click connect
What else can I do?
You did wrong!
After open UP02 program then connect the UP02 USB tools to your pc, and do not connect your QR X yet!
After get com port 10 for the communication and click connect from the UP02 program, and now only you get White - Blue,Red - Yellow,Black - Black connect to your QR X350 servo lead, then only now to connect the battery and wait the UP02 software to detect your QR X!
On my video is very clear instruction, sure you can do if you done watching that video!
nelsonlee is offline Find More Posts by nelsonlee
Old Sep 13, 2013, 09:13 AM
djmorgan is offline
djmorgan's Avatar
Joined Aug 2013
Guys just before bed I read the installation notes that come with the program, nobody has mentioned this step in the process
"5 The installation of UP02 program upgrade tool
5.1 Software installation
Run SerialAngel_V1.x_Setup.exe file: the Installation Shield Wizard will guide you to install
UP02 program upgrade tool applications on your computer. When the software is
successfully installed, click the “Finish” button.
5.2 UP02 driver installation
You can explore the driver package. The driver package files are located in your installed
path (C:\Program files\UP02 Program Upgrade Tool).
l According to your Windows platform, run the “Setup Driver” or the “Setup Driver x64”.
Start -> All Programs -> UP02 Program Upgrade Tool -> Setup Driver.
Or Start -> All Programs -> UP02 Program Upgrade Tool -> Setup Driver x64.
The Installation Shield Wizard will guide you to install UP02 driver on your computer.
Hope it helps
David
Old Sep 13, 2013, 09:31 AM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
I did try before belive it or not be it plug first or later...all kind of combo...nothing work...
Old Sep 13, 2013, 09:39 AM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
Hope it helps
David
Yes did that too
Old Sep 13, 2013, 09:44 AM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
Guys sorry for hijacking here with all these posts, I will end it here snice nothing can be done. Thanks again guys for helping.
Old Sep 13, 2013, 11:34 AM
TiggyWiggy is offline
Find More Posts by TiggyWiggy
United States, GA, Woodstock
Joined Aug 2013
Guys, does anyone know how to mix the FMOD and HOLD switches on a DEVO7E to simulate the 3-position MIX switch on the DEVO7? I have a DEVO7 coming for my X350 but already have the DEVO7E and just wondered if I could make it work for the MANUAL / POS HOLD / RTH functions with the two 2-position switches. I am a noob at switches and mixing.
TiggyWiggy is offline Find More Posts by TiggyWiggy
Old Sep 13, 2013, 11:58 AM
Topgoose is offline
Find More Posts by Topgoose
Almost right is always wrong..
United Kingdom, England, Nottingham
Joined Aug 2013
I've given up on the update too. Mines is ok on the original firmware so it is what it is.
Topgoose is offline Find More Posts by Topgoose
Old Sep 13, 2013, 12:15 PM
Ariete is offline
Find More Posts by Ariete
Madrid, Spain
Joined Oct 2009
You are absolutely right, this is a problem with the board not with the procedure. I soldered the servo plug and no matter what I do the program doesn't recognize the X350.
To be sure I just connected my SpaceWalker and it recognized it at first try, even if I disconnect it says so, I connect again and it shows. It doesn't matter the order in which you connect.
For the weekend I will close the X350 and go to fly.
I will send a message to walkera, lets see what they say.
Ariete is offline Find More Posts by Ariete
Old Sep 13, 2013, 02:52 PM
Flying Barry is offline
Find More Posts by Flying Barry
Australia, NSW, Sydney
Joined Jan 2007
White - Blue
Red - Yellow
Black - Black
6. Click connect
What else can I do?
That's you problem com10 port (too high) change it in the PC control panel - device manager to lets say com3 port. I have had this type of problem before.
How to here: http://www.sealevel.com/support/arti...e-Manager.html
Barry
Flying Barry is offline Find More Posts by Flying Barry
Old Sep 13, 2013, 04:10 PM
super trowel is offline
Find More Posts by super trowel
super trowel's Avatar
United Kingdom, Sidmouth
Joined Sep 2013
Is their anyway of doing this update via an ipad?
Or is it strictly PC?
super trowel is offline Find More Posts by super trowel
Old Sep 13, 2013, 04:18 PM
rabone is offline
Find More Posts by rabone
United Kingdom, England, North York
Joined Oct 2010
[quote=
rabone is offline Find More Posts by rabone
Old Sep 13, 2013, 04:19 PM
rabone is offline
Joined Oct 2010
ho my god
Old Sep 13, 2013, 07:44 PM
r0ll3r is offline
Find More Posts by r0ll3r
Australia, QLD, Brisbane
Joined Sep 2013
There's something very Trekkie about the Blade though.
r0ll3r is offline Find More Posts by r0ll3r
Discussion Walkera QR spacewalker & QR scorpion happy guy Multirotor Talk 5 Jun 22, 2014 12:12 AM
New Product New Space Cruiser Coming !!!---Walkera WIFI Quad QR W100 pics and assembly videos! DLY Micro Helis 28 May 07, 2014 10:46 PM
For Sale Walkera QR X400 w/TX5803, DV04 -- never flown bmw111 Aircraft - Electric - Multirotor (FS/W) 4 Jul 28, 2013 04:15 PM
Sold *Like New* Walkera QR Ladybird V1 Receiver (v1.1 firmware) flying toaster Aircraft - Electric - Multirotor (FS/W) 3 Mar 28, 2013 09:36 AM
New Product Walkera QR-Scorpion and QR-SpaceWalker hobbyclub Micro Helis 0 Jun 30, 2012 06:54 PM
