Old Feb 04, 2004, 08:27 PM
Kyle2baseball is offline
Find More Posts by Kyle2baseball
Heli Maniac
Kissimmee Fl.
Joined Jun 2003
How do you tell how many amps you can pull out of a li-poly battery?
I was wounder how to find out how to see how many amps can be pulled out of a battery.
Kyle2baseball is offline Find More Posts by Kyle2baseball
Old Feb 04, 2004, 08:58 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If you really have to abuse a pack until it explodes in your face, put a Whattmeter in line, connect a Hacker C50 Acro with a 22" prop on it, then, while dutifully recording the amps-in, wait for the fireworks.
Otherwise: Read the manufacturer's recommendations for maximum discharge and follow them!
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 04, 2004, 11:54 PM
Awakened is offline
Find More Posts by Awakened
Nimble with Gimbals
San Diego, CA
Joined Apr 2003
1. Determine "C" rating on pack or cells in question.
2. Determine capacity of said pack or cell.
3. Multiply C times capacity.
Example:
Kokam 1500 cells are rated at 8C. 8 times 1500 equals 12 amps so you would prop/gear for 12A at wide open throttle.
Simple, huh?
Awakened is offline Find More Posts by Awakened
Discussion How many amps does a Maba pull? chicken hawk Off-road Cars 4 Aug 22, 2007 08:47 AM
How many amps can you put in TP 1320mah 3 cell ? Satkunas Batteries and Chargers 4 Jun 11, 2005 08:50 PM
How Many Amps Have You Put Your GWS 5 Amp ESC Through putt_13 Power Systems 11 Dec 19, 2002 01:49 PM
How Many Amps Will This Pull? OCModels Power Systems 5 Sep 12, 2001 05:06 PM
How many amps can I pull from Sanyo 1400 ae's? slowflyer Power Systems 9 Jun 01, 2001 12:30 AM
