Feb 03, 2004, 11:35 PM
United States, VA, Clintwood
Joined Nov 2002
Here is a photo of the printout I paste on the balsa. Also in the photo is the tool I use to drill the 6mm hole. It is the key to making these gearboxes. I had tried drilling with drill bits but this tool works better. The tool is a 6mm motor which has been sharpened and magnet removed. Then a nozzle from a butane lighter is inserted in the shaft hole then soldered. A brass tube could be used in place of the nozzle it just happened to fit. The nozzle fits in my hand twist drill. I then score the edges of the can with either a needle file, corrundum , quartz, or some material that is harder than the metal can. The scoring allows the can to remove wood as it is pressed/turned in. You may have to file down your score marks a bit-if after you drill a hole, a 6mm motor does not fit "kind of tight". After the 6mm hole is driled I start the hole for the thrust bearing with a needle file. Then drill with progressively larger size bits till I get a good press fit with my thrust bearing outer tube. The press fit can not be too tight or the balsa will split. It is ok if the press fit is not really tight or if the hole is not perfectly true.
After I get both holes drilled I cut out the gearbox to a cam type shape. You can make your gearbox any shape you want, square may be better for mounting I prefer the cam shape fro some reason. I then sand the thing down starting with 150 ending with 600 grit.
Note: You may want to skip this coating step and make the rest of the parts and test the fit first. Ecspedially if you deviate from any of the sizes.
I then coat the thing heavily on the outside and inside the holes with thinned Duco. You can use any nitro cellulose glue that can be thinned with acetone. Ambroid is another glue that could be used there are probably others. I guess thick nitrate dope could also be used. This gives the balsa more strength. It is like making it plastic.
You could probably make 2 of these with thinner balsa and put one in front and one in back sort of like the gearboxes on microplane solutions website.
Now you can make the thrust bearing and shaft while the duco is drying. I use .031" music wire for the shaft about 1" long. Cut the music wire to length then round off or bevel the ends about 1/32". Make sure the shaft is straight and true by rolling it on a peice of glass or flat surface.
The 23t spur gear will need an adapter for the .031" shaft. I used wire insulation (Thanks for the idea David Dewitt). once you find insulation that will allow a tight fit for the spur gear you can slide the spur gear so the back is about 15/16" from the front of the shaft, then cut and remove the extra wire insulation.
The aluminum tube is about 15/32" long and 3/32"OD and 1/16" ID, this fits the 1/16" brass bushings.
For the brass bushings start out with a length of 1/16" OD brass tubing. insert some scrap .031" music wire then place your hobby knife like you are going to cut it into - about 1/16" from edge. Roll the brass tube keeping the knife straight and applying pressure. It is good to not use much pressure at first till you have scored the tube straight-all the way around. After you have scored the tube straight you have a guide then can apply more pressure. This process is like cutting insulation without cutting wire.
The scrap music wire keeps the brass tubing ID from compressing while cutting. You may get a flange on one end so it may be a good idea to file each end off before starting a new bushing. I usually dont or only file it down a little - as it makes for a really tight press fit in the aluminum tube. Now that you have 2 bushings 1/16" wide insert them in either end of the aluminum tube.
Now cut some washers from some slick tubing. I usually use the red spray tubes. The same method can be used as cutting the bushings. A sharp thin blade helps to get thin washers. You will want an extremely as thin as you can get washer for the back as well as a spacer washer that goes between the spur gear and front bushing. The front spacer should be from 1/32" to 3/64" depending on how much insulation you leave on. This spacer keeps the spur gear from slipping off the pinion while the motor is idle.
A spare pinion can be cut in half and the teeth sanded or cut down to be used as a lock washer. If you don't have spare pinions then 1/16" tubing can be squeezed or glued on.
OK now you have your thrust bearing and shaft ready to go. Have a motor with wires soldered on and pinion pressed on ready.
The wires are tricky to solder make sure that you solder the wires on quick as too much heat can deform the plastic cap and misallign the brushes making the motor run poorly.
Now put the spacer washer on from the back , slide it up to the spur gear.
After the duco dries good about 5-15 minutes depending on how much is used I recoat the holes and apply a bit of glue to the motor and aluminum tube. Then I press in the motor and aluminum tube into the appropriate holes. Put the shaft in from the front and put on the back washer and the lock washer. You can now adjust the straightness of the tube and motor as well as adjust the meshing a bit. It will take a while for the glue to set so you have a little while for adjustment. You could even have a prop on the shaft, a power source and current meter hooked up to the motor to find the best mesh.
Now you should have a working lightweight gearbox ready. It is a whole lot easier to do than say.
Billy
