Old Jul 18, 2013, 02:14 PM
nelsonmay10 is offline
Find More Posts by nelsonmay10
United States, NC, Charlotte
Joined Jul 2006
adding ailerons to a hobby zone champ?
I posted this in the basics forum and didn't get any hits. I am going to post here to see if I get better results.
I keep trashing my big planes and want to go back to flying something I can't crash and destroy as much. I started out with a hobbyzone champ and decided to put ailerons on the wings. I used a servo and parts from a p-51 mustang micro.
I don't get as much if any turn with the ailerons. Is the because of the dihedral in the wing? If I take out the dihedral, will I get better aileron performance.
I hooked them up with pushed rods that attach to the linkage like I found in the micro mustang. Any better ideas on how to hook up ailerons off of that servo? I used piano wire and it is hard to trim, because the wire doesn't like to bend very well.
Cheers.
nelsonmay10 is online now Send a private message to nelsonmay10 Find More Posts by nelsonmay10
Edit/Delete Message
nelsonmay10 is offline Find More Posts by nelsonmay10
Old Jul 18, 2013, 02:33 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
It looks from the picture that the ailerons are fairly inboard of the wing, they will work much better if on the outer sections of the wing. Even then I doubt the micro servo has the power to successfully work ailerons on a Champ.
You would probably be better off determining why you keep trashing your big planes, and solving that problem.
If the big planes are totaled, (not repairable), then using the gear from them and building one of the foamie models again would make more sense to me.
eflightray is offline Find More Posts by eflightray
Old Jul 18, 2013, 02:43 PM
Joined Jul 2006
I am just not that good of a flyer and I get frustrated. I collected a few planes and need practice. Since they are so cheap from hobby king, I have a few that are above my level. I have something that is a step up from a trainer, but I keep crashing it. My eye site is getting bad at long distances and I can't distinguish the tree line from the sky. That is where I hit. I like this little plane, because you can keep it in the air. When my skills get better and I can keep planes close to me, I will start flying the others again. I hate simulators, and the local flying club I am in said, "you have to fly until you are good enough to react without forethought. They you will be able to fly and have more fun. The ailerons are on the outside of the wing. You may be seeing the linkage. Anyway, I read a few posts of guys putting ailerons on this thing and I thought it would be a good rainy day project to teach me how to build planes.
Thanks.
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
It looks like he used the scale outline molded into the wing for his ailerons.
You are likely experiencing adverse yaw. Try moving the linkage from the servo to the bell crank to the innermost hole. That will give you more aileron deflection. If you have a computer radio I would suggest an aileron to rudder mix.
Another option would be to change the size and shape of the bell crank to mechanically induce some aileron differential.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Jul 18, 2013, 02:58 PM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
http://www.rcgroups.com/forums/showp...19&postcount=3
cmdl is offline Find More Posts by cmdl
Old Jul 18, 2013, 06:18 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
eflightray is correct. The ailerons need to be outboard. I don't think the dihedral is the problem. And if the servo worked on the P-51 is should be OK here.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jul 19, 2013, 05:14 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Thanks.
Not wanting to seem rude, but have you considered getting you eyes tested and wearing glasses.
Flying model planes generally needs good eyesight simply so you don't put others at risk. I regularly get my eyes checked and do wear glasses, but can still have the occasional problem distinguishing orientation.
Back to the flying, do you still have rudder as well as ailerons ?, if so try coordinating rudder and aileron for turns. It's very useful practice for flying most aileron models and will give better quality turns, not just use the 'bank and yank' method.
Old Jul 19, 2013, 07:08 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
It would help to take the dihedral out of the wing. The dihedral is trying to keep the wing from rolling while you are trying to make it roll. Differential would also make it roll better, Takes the adverse yaw out of it. Moving the pivot point for the bellcrank further forward would give you diff. in the right direction.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jul 19, 2013, 12:17 PM
failboat is offline
Find More Posts by failboat
yank and bank!!
Joined May 2013
force is much more effective at a longer lever, so I would definitely imagine the ailerons would be more effective further outward towards the wingtips.
Wow, that's the inside of a champ fuselage? Not very sturdy looking.
failboat is offline Find More Posts by failboat
Old Jul 19, 2013, 01:26 PM
Eclipse_7's Avatar
Joined Nov 2003
I'm not sure if people have noticed, but his ailerons are on the outer part of his wing. He has a torque tube set up like all the 4 ch. micro warbirds. From the picture it looks like he is using the scale outlines of the ailerons that are moulded into the wing.
Discussion adding ailerons to a hobby zone champ? nelsonmay10 Beginner Training Area (Aircraft-Electric) 9 Jul 22, 2013 06:17 AM
Sold Hobby zone champ kilabean Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jul 01, 2013 12:03 PM
Sold Spektrum DX6i Tx and Hobby zone champ combo kilabean Aircraft - General - Radio Equipment (FS/W) 1 Jun 30, 2013 09:26 AM
Discussion has anyone added ailerons to a parkzone champ rtf nelsonmay10 3D Foamies 2 Jun 24, 2013 07:19 AM
Discussion Problem(?) with new hobby zone champ southtexican Electric Plane Talk 13 Jan 04, 2013 02:08 PM
