Old Jul 17, 2013, 09:59 PM
mwoolard1912 is offline
Find More Posts by mwoolard1912
Joined Apr 2013
Question
Problem with BC-3S10 or Battery?
I am new to the sport of RC aircraft and to RC as a whole. This is my first experience with Li-Po Batteries and chargers. I haven't had my plane for very long and it is a RTF model that comes with a charger and a battery. The charger is a BC-3S10. I have had no issues with it till the other day. Here is how it played out.
I was going to take my plane out and my brothers smaller plate to fly. So I decided to charge the batteries. I charged mine first on my charger. It is a 3S battery so it uses the larger charging port. After mine was done I used my charger to charge his battery which is a 2S so it uses the smaller port. Everything worked fine and both batteries were charged. I had a very successful evening of flying so I decided to get a couple of extra batteries for my plane. When I got them i plugged one it to charge on my charger and it immediately started flashing fast indicating a issue with charging. Thinking my new battery could have a issue i decided to put my old battery that came with the plane on it. I got the same result. LED flashing quickly indicating abnormal charging condition. At that point I decided I may have an issue with the charger. Mostly because I felt it was highly unlikely that all three of the batteries I had would all be bad at the same time. After looking things over and trying to figure out what was going on i decided to try my brothers smaller battery again. I hooked it up and it started charging fine. So now I am not sure what I have going on. Is there any way I can check my batteries to make sure I don't have some issue with them? And if everything is ok there should I just assume I have a charger issue and get a new one?
mwoolard1912 is offline Find More Posts by mwoolard1912
Old Jul 17, 2013, 11:05 PM
chuck75 is offline
Find More Posts by chuck75
Georgia
Joined Jun 2007
You can check the batteries with a DVM for voltage.
Fully charged is 4.2 volts per cell. Most inexpensive DVMs are under $20, and read 4.2v as 4.20v +/- about .02v
A 12v light bulb can be used to test the load capability of the battery if you know what the battery current ratings are, and can find an appropriate 12v light bulb and socket.
If you do this, use the DVM to make sure that you do not discharge the battery below about 3.7v-3.8v per cell. This is the storage level for the majority of lipo batteries.
I noticed that others had simiar problems with the BC 3S10 in the past.
chuck75 is offline Find More Posts by chuck75
Old Jul 18, 2013, 07:22 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Please get rid of that charger. You need a charger that will report the pack voltage, individual cell voltage charging current and milliamp hours returned to the pack during charge. Here are a couple of suggestions.
Adequate:
http://www.hobbyking.com/hobbyking/s...arch=accucel-6
Much Better:
http://www.progressiverc.com/icharger-106b.html
Also please read this:
https://sites.google.com/site/tjingu...arging-how-tos
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jul 18, 2013, 07:38 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
As Glen indicated those chargers like the one you have are usually just asking for trouble. Very unreliable and don't give you much feed back. Given that a 50W charger can be purchased for around $25 there's no excuse to keep using crap.
As for your problem what's actually in there is basically 3 independent charging circuits, one for each cell of the battery. You said your 3s won't charge but your brothers 2s will. Problem simply is the 3rd charging circuit which is used on cell 3 is bad. Dispose of the charger and get something else.
If you're not looking to spend a lot of money the Accucel6 that Glen linked is a great first charger. Though small it's inexpensive and you'll still find uses for it later even if you buy something larger later. You will need a power supply to use it at home. If you have an old laptop power supply with right voltage laying around you can use that. Otherwise you can order one of these with the charger:
http://www.hobbyking.com/hobbyking/s...0_240v_5A.html
http://www.hobbyking.com/hobbyking/s...dproduct=20968
Since you didn't put your location in your profile it's hard for us to make recommendations on where to buy from. The links to HobbyKing provided are for their international warehouse. If you are in the USA you would want to order from their USA warehouse.
grimbeaver is offline Find More Posts by grimbeaver
Help! my charger or battery problem aka_TEKK Batteries and Chargers 7 Jun 11, 2013 05:55 PM
Discussion BC-3S10 lights speedster00 Batteries and Chargers 2 May 27, 2012 01:08 AM
Discussion BC-3S10 Ballance Charger mrnickg Batteries and Chargers 1 Mar 12, 2012 09:17 PM
Question BC-3S10 Battery Charger Duke2448 Batteries and Chargers 1 Jan 13, 2012 05:44 AM
Discussion bc-3s10 chargey fast blinking???? pcrg28328 Electric Ducted Fan Jet Talk 2 Dec 27, 2011 10:41 PM
