Traxxas Chargers – EZ-Peak 5amp & EZ-Peak 4amp
New from Traxxas are these two very affordable and faster charging battery chargers for NiMH and NiCd battery packs.
The EZ-Peak 5amp is an AC/DC unit that also includes a convenient USB charging port to juice mobile electronics. The EZ-Peak 4amp is an AC charger that is powerful enough to charge a 7-cell battery pack in 45 minutes.
EX-Peak 5amp
The new Traxxas EZ-Peak™ 5amp NiMH Charger delivers 25% more power and 20% faster charging than standard 40Watt chargers, resulting in less downtime and more runtime. Some chargers advertise fast, 5-amp charge rates, but are only rated for 40Watts of power. Other chargers require connection to a DC power supply or a 12V battery to deliver full charging current. The EZ-Peak 5amp (available as Part #2937X) delivers 50Watts of power from a standard AC wall outlet to charge 7-cell NiMH battery packs in record time—approximately 35 minutes! Simple push-button operation with selectable charge rates makes it easy to charge Traxxas Power Cell™ NiMH batteries, 5-cell receiver packs, and 4- to 8-cell NiCad and NiMH packs. Just plug in your battery pack, select the charge rate, and push the "Start" button to begin charging with the EZ-Peak 5amp. Advanced peak-detection circuitry makes sure the battery receives a perfect charge every time. The color-coded charge status LEDs indicate charging progress for foolproof charging, peak performance, and maximum runtime.
A convenient USB port is perfect for charging mobile electronics and is compatible with the USB-powered chargers for the DR-1 and QR-1 helicopters. The integrated receiver (RX) battery charge port allows charging of 4- or 5-cell receiver packs.
The EZ-Peak 5amp Charger is equipped with a Traxxas High-Current Connector for use with all Traxxas NiMH Power Cell packs and all NiCad and NiMH battery packs equipped with Traxxas connectors. Also, the EZ-Peak 5amp is backed by the Traxxas Lifetime Electronics Warranty for years of reliable service.
SPECIFICATIONS / EZ-PEAK 5amp (#2937X)
AC Input:100–240 Volts
DC Input:12–18 Volts
Charge Current Range: 1.0A–5.0A (50W Max.)
NiCad/NiMH Battery Cell Count:4-8 Cells
Receiver Battery Cell Count:4-5 Cells (1A Max.)
Net Weight: 340g
Dimensions:147 x 104 x 40mm
EX-Peak 4amp
The new Traxxas EZ-Peak™ 4amp NiMH Charger combines simple plug-and-charge operation with selectable charge rate for convenient charging of all Traxxas Power Cell NiMH batteries. The EZ-Peak 4amp delivers full 4-amp charging power directly from a standard A/C wall outlet! Just plug in a 5- to 8-cell NiMH or NiCad battery pack and the EZ-Peak begins charging at the rate you select. Charge at 1 amp for receiver packs, 2 amps for the Power Cell 1200mAh batteries included with Traxxas 1/16 models, or 4 amps for 3000–5000mAh Power Cell NiMH packs. Advanced peak-detection circuitry makes sure the battery receives a full charge. The status LED flashes red to indicate charging is in progress, then turns green when charging is complete for foolproof charging, peak performance, and maximum runtime.
The EZ-Peak 4amp Charger is equipped with a Traxxas High-Current Connector for use with all Traxxas Power Cell™ packs and other NiCad and NiMH packs with Traxxas connectors. Adapters are sold separately for charging receiver packs (#3065) and batteries with Molex connectors (#3062).
For more info on these chargers and other Traxxas products, CLICK HERE!
Old Jul 17, 2013, 02:13 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
It looks nice, but it better be cheap, as an Imax B6 based charger, even the more expensive rebrands that even have a different outer casing, can do all this, and also charge NiCad, Lead-acid and LiPo, at the same charge rate as this one...
SoloProFan is online now Find More Posts by SoloProFan
For Sale Traxxas EZ Peak Plus charger *Like new* ChrisB17 Cars - Accessories (FS/W) 2 Feb 17, 2016 05:17 PM
Help! Hyperion Charger EOS 0720i NET3 will not charge above 5amps spitfire007 Batteries and Chargers 2 Apr 03, 2013 12:58 PM
Sold Traxxas EZ peak charger plus...$35 Shipped hone1er Aircraft - Electric - Batteries & Chargers (FS/W) 1 Aug 07, 2012 07:12 PM
For Sale traxxas ez-peak charger and series1 batteries spoonf20c Cars - Accessories (FS/W) 0 Jun 17, 2011 01:11 AM
Sold Jamara (Dymond) X-PEAK 3 Plus - 5s/5amp lipo/Nixx charger/discharger punkindrublik Aircraft - Electric - Batteries & Chargers (FS/W) 1 Oct 04, 2008 06:27 AM
