Novak Speed Lube & Pro Solder Flux
Help keep your expensive brushless motors in top performance and improve your solder joints!
Novak is making sure they are offering the products to keep you “in the game” and these two latest releases are a great example of that. No they are not some sexy new high-power brushless motor, but are ‘tools’ to keep your prize RC possession in topnotch shape.
SPEED LUBE (#5860)
Novak's Speed Lube is a premium quality, American made bearing oil that is perfect for lubricating the high-speed ball bearings used in R/C brushless motors and vehicles. This oil is 4-times filtered for the highest purity and has penetrative additives that help the oil get into the crucial areas where it's needed—Oil quickly gets in deep, even with bearing shields in place.
Novak Speed Lube is also great for applications like skate & skateboard bearings where this high-speed bearing oil provides reduced rolling resistance for improved performance and superior protection against oxidation and rusting.
Stainless steel dropper tip for accurate application of the oil just where you want it, and a high-quality silicone stopper cap that stays on securely until you take it off.
Contains: 10ml liquid weight
Material Safety Data Sheet: CLICK HERE!
PRO SOLDER FLUX (#5861)
Novak’s Pro Solder Flux liquid soldering flux has been chosen specifically for use with Novak 3% Silver Solder (#5832), and other high temperature, lead-free solders. When used together, they provide the highest quality solder joints for optimum efficiency and ultra-low resistance connections. The fast wicking action of this high performance flux makes for quick & easy solder joints with perfect results when using stubborn lead-free solders.
The bottle features an easy-to-apply dropper tip for getting just the right amount of flux where you need it, and seals securely with a safety seal cap to avoid unwanted spills.
Novak’s Speed Lube and Pro Solder Flux were Developed in Conjunction with our In-House Engineering Staff and Factory Team for the Highest Performance
Click here to read up on more info on Novak's products.
There are no posts
For Sale 2 tubes of solder and 1 of flux geostomp Aircraft - Electric - Multirotor (FS/W) 2 Jun 23, 2013 07:25 AM
For Sale Solder Flux with Needle Applicator geostomp Aircraft - Electric - Multirotor (FS/W) 1 Jun 01, 2013 02:32 PM
Discussion Solvent for Electronic Soldering Flux? roo_ster Electric Plane Talk 14 May 10, 2013 07:29 PM
Discussion Soldering station questions - which tips, solder, flux? Brian_ DIY Electronics 46 Apr 28, 2013 08:22 PM
Discussion Where to buy Solder-It or Zinc flux and solder for lipo tabs in Aus?? Ampdraw Australia 3 Aug 16, 2010 04:31 AM
