Old Feb 03, 2004, 04:28 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
new micro brushless
Just got sent this link by John "wow that's small" Mack:
http://www.mpm.maxonmotor.com/newpro...20Brushless%20
I am seriously annoyed because I was going to make one of these, they beat me too it
Right I am off to do something before someone else does!
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Feb 03, 2004, 04:53 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Ok, so who's going to figure out what size prop that motor can realisitically turn, both geared and ungeared. That's the $64,000 dollar question.
Obviously a number of people have now seen it. It's been posted in the power systems forum and in the 7.5mm brushless thread in this forum.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Feb 03, 2004, 05:26 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Graham
I cant wait to see what you make.
I would be at it but I am excited about the bit rx not glitching and wanting to build a new plane. If you need any help I can draw you up a quick design in rhino for your CNC. Provided you cut out some parts for me that would be hard for me to do by hand. I know you are capable of drawing all the necesarry parts just offering. I guess it could be made with some ply and PCB and some sort of bearing.
Gordon
I used the little program convert.exe
and .19mNm(millinewton * meter) = 0.1937468 gram force centimeter which is I guess the same unit you use for actuator torque. Or is it?
Billy
billystiltner is offline Find More Posts by billystiltner
Old Feb 03, 2004, 05:46 PM
Boston, Mass
Joined May 2001
Billy,
I deleted that info from my post as I'm not sure Mabuchi's spec and Maxon's are giving exactly the same thing and I don't want to mislead. When I measure actautor torque that is stall torque. Maxon doesn't seem to be listing stall torque in their specs. I think the units would be the same, but the state of the motor might not. Maxon lists the nominal voltage of this motor at 0.4 volts. I'm not sure what it could take for our purposes.
Maxon will sell motors in single quantities through their various world-wide sales offices. I checked once and they would sell me the motor that is the Astro Firefly motor one at a time and it would cost me about $20 more than an Astro Firefly. So, if someone wants to evaluate this motor badly enough they probably can get one without buying thousands of them. BTW, I think Maxon is one of the cutting edge small motor manufacturers. There are others, but I think they are in that cutting edge group.
Gordon
Old Feb 03, 2004, 06:49 PM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
it's 60mw. on 4.2 v, that's like 14ma. 20W/lb= 1.25W/oz = 43mw/g. so, for a floater with little power, it needs to be ~1.3g AUW. good luck getting even a brushless controller that weighs that much.
neat, but we need a 5-15g brushless before we start pushing the envelope this far...
opualuan is offline Find More Posts by opualuan
Old Feb 03, 2004, 07:28 PM
Littlescreamers is online now
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
I talked to a sales rep for over an hour about the small brushless motors,
The motors are made in Switzerland and are very very pricey!
under 1000 is gunna cost ya $60 each even if I bought 50,000 the quote was way to high for them to be usable!
Scott
Littlescreamers is online now Find More Posts by Littlescreamers
Old Feb 03, 2004, 07:48 PM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
Its ok Scott a picture tells a thousand words. I feel this motor could be reproduce easy enough .. its matter of what your time and labor is worth and being so small there is not much product there .. so materals are a no brainer..
AIR MOVER is offline Find More Posts by AIR MOVER
Old Feb 03, 2004, 08:31 PM
opualuan is offline
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
I've been paying $70-250 for my motors anyways, I'd have no problem spending $60 on a premium ultra micro motor, so long as it outperformed pager motors etc by a wide margin.
Old Feb 04, 2004, 03:20 AM
ChrisT88 is offline
Find More Posts by ChrisT88
Palm Beach, FL
Joined Jan 2004
Smallest brushless controller I've seen is a Schulze, was 2-3g if I recall correctly.
ChrisT88 is offline Find More Posts by ChrisT88
Old Feb 04, 2004, 06:41 AM
Sticky Shepherd
Oxford/England
Joined May 2001
I was wanting to build a 3 or 4mm one as a cheap alternative to a smoovy for use as a stepper motor. Contruction is fairly straightforward.
Graham
Old Feb 04, 2004, 08:02 AM
Heribert is offline
Find More Posts by Heribert
Germany
Joined Oct 2002
Deja vu
This type of motor is also used for the so called "penny motor", see http://www.mymotors.de/en/index.php4
The special characteristics of these motors is that their coils are made by a special galvanic layering method and the motors have just one bearing. The weight is about 2 gr + approx. 1 gr for a controller. These motors also are pretty pricey. If i remember correctly, for a 100 pcs the price is about 50 Euros/pc including the controller. In order to get some torque out of these motors you need an additional gearbox, pushing the price significantly higher to get a usefuls system for our hobby.
Nevertheless i myself made some of my own and had a deja vu experience when i saw above photo in the first post.
Heribert is offline Find More Posts by Heribert
Old Feb 04, 2004, 08:09 AM
Heribert is offline
Germany
Joined Oct 2002
I forgot to say: what you see on the picture i posted, is much more macroscopic than the maxxon motor. Its weight is about 5 grams including the controller, that is SMD placed on the epoxy plate that makes up the stator. The phase detection of the controller is made with a hall sensor.
Old Feb 04, 2004, 09:37 AM
Joined Nov 2003
That tiny little motor on the end of the finger is a 6mm motor and weighs 1.6grams
Scott
Old Feb 04, 2004, 09:57 AM
Heribert is offline
Germany
Joined Oct 2002
Hi rcflyer2
do you refer to the maxxon motor? If so the product info says something about 0.32 grams weight.
Heribert
Survey- New Micro Brushless motor fill Parkflyers 70 Jan 10, 2003 12:51 PM
Survey- New Micro Brushless motor fill Scratchbuilt Indoor and Micro Models 0 Jan 31, 2002 11:52 AM
New Jeti Brushless motors for ECO8? Tooly Electric Heli Talk 16 Jun 21, 2001 09:51 PM
Geared Micro Brushless T-52 Success! Aikens Foamies (Kits) 4 Jun 05, 2001 06:41 AM
Aveox new and smaller brushless controllers shelby Electric Plane Talk 0 May 16, 2001 09:18 PM
