Dual and Quad Link from TrueRC
Make your own Pepperbox and Gatling antennas
Link multiple antennas together for increased gain
The dual and quad links from TrueRC.com are an easy way to connect multiple antennas of the same frequency (1280MHz only) together for increased performance. By using 4 antennas, you will make your own Gatling; a long-range antenna with very high gain but a narrow beam. If you use the dual link, you'll be making a pepperbox which has 3dB less than the Gatling, but a much wider beam width and reduce the need for an antenna tracker.
Taken from TrueRC's website: Dual Link: Here's yet a new thing at TrueRC: The 1280MHz "dual-link". Like the quad-link, but to match two antennas instead of four. I made it for an interesting use: To convert a Gatling into a pepperbox antenna by replacing part of the matching network. Just unscrew either the two left or two right elements and screw the dual-link. (be sure to mark your connector to put them back at the same place.) Your Gatling will then turn into a 13dB pepperbox, useful at the field in case your tracker let you down. Quad Link: Matching network to link four antennas together for increased gain (5-6dB). Coax from antennas must be exact same length. Place four antennas 9 1/4" apart center to center, forming a square.
Pricing:
  • Dual Link: $30
  • Quad Link: $25
Link to product
Old Jul 16, 2013, 10:36 AM
longgtom is offline
Find More Posts by longgtom
Joined Feb 2012
Sorry for my apparent ignorance but if you combine two antennas using the dual link, would you then be able to combine an omni with a directional?
longgtom is offline Find More Posts by longgtom
Old Jul 16, 2013, 10:41 AM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
No, these are designed for two like patch antennas (i.e. a pair or 4 crosshairs)
you would need a separate receiver and diversity switcher for an Omni and patch combo.
matt
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Aug 06, 2013, 04:59 PM
quadcopter007fpv is offline
Find More Posts by quadcopter007fpv
quadcopter007fpv's Avatar
United States, CA, Riverside
Joined Feb 2012
when can we expect to see the 5,8 ghz ones, and yes i know they will be smaller
quadcopter007fpv is offline Find More Posts by quadcopter007fpv
Wanted WTB: Dual or Quad Lipo Charger Nitroelectric Cars - Accessories (FS/W) 0 May 04, 2013 09:31 PM
Discussion Expo/Dual Rate (throttle) for high power to weight ratio quad? serrated Multirotor Talk 10 Apr 02, 2013 09:01 AM
Sold Gatling Antenna from Hugo at TrueRC Canada Hmerly FPV Equipment (FS/W) 9 Mar 28, 2013 10:38 PM
Discussion New 450 Pro Dual Tail Slider (with metal links) half the cost of Align! PcChip Electric Heli Talk 5 Feb 12, 2013 09:37 PM
Gallery Dual rates set to high.....Linked control surfaces Aero-Nuts Your Plane Photos 0 Oct 15, 2004 09:21 AM
