Old Jul 12, 2013, 09:03 PM
mojambo is offline
Find More Posts by mojambo
Joined Nov 2012
DC motor current
A DC motor drawing 20 amps current on a 1000mah battery should last half an hour theoretically but is giving more than an hour flight time. Any reasons?
mojambo is offline Find More Posts by mojambo
Old Jul 12, 2013, 10:20 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Erm, 2A from a 1Ah battery would give 30mins, 20A would give 3mins.
Only way I can see the plane staying up an hour is if it spent most of the time gliding
desertstalker is offline Find More Posts by desertstalker
Old Jul 13, 2013, 12:53 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Because it's very bad at calculating .
The obvious explanation is that it's not, on average, actually drawing the current you think it is while it's in the air. How did you decide that your motor is constantly drawing 20A ?
Steve
slipstick is online now Find More Posts by slipstick
Old Jul 25, 2013, 02:28 AM
mojambo is offline
Joined Nov 2012
measured via a ampere meter on ground while motor is turned on
Old Jul 25, 2013, 02:58 AM
Staffs, UK
Joined Nov 2003
So which part of the your original post do you want to change ?
20A on 1000mAh should last 3 minutes NOT 30 minutes. If it's flying for over an hour on a 1000mAh battery then the AVERAGE current is less than 1A, not anywhere near 20A.
So either your current measurement or your battery size are completely wrong or the motor is running at full power for less than 5% of the time the plane is in the air .
Steve
Old Jul 25, 2013, 03:46 AM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Can you tell us a bit more about the model; and as others have pointed out, 20A from 1000mAH is 3 minutes: it would take 10000mAH to predict 30 minutes.
If you already know your flight time is about an hour, you know your average current must be a lot less than 20A.
To estimate average current, I note flight time and how much it takes to recharge the battery. For example, if I recharge 6000mAH into (my hypothetical) 10000mAH pack, and I flew for 1 hour, I know my average current had to be 6000mAh / 1 hour = 6000 mA = 6A.
For average power, I multiply by a nominal voltage roughly halfway between the pack's full and and after flight voltage, usually around 3.9V/cell, or 11.7V for a 3S pack. So 6A aerage would be about 70W average.
scirocco is offline Find More Posts by scirocco
Old Jul 25, 2013, 04:42 PM
whanderson is offline
Find More Posts by whanderson
Baltimore Bwi Rr Stn, Maryland, United States
Joined Oct 2003
FWIW - To get 1 hour flight time from a 1000mah battery the average current has to be 1A no matter what motor or prop - it's the law.
whanderson is offline Find More Posts by whanderson
Old Jul 25, 2013, 04:54 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
To be a bit more precise, a one-hour flight with an average current draw of one amp would use exactly 1000mAh from the battery. When applied to the real world, we also have to consider that only ~80% of the pack's full capacity is available for use or else the battery will end up damaged... so a one-hour flight with 1000mAh available means the average current has to be 0.8A.
Piece is offline Find More Posts by Piece
Old Jul 28, 2013, 04:37 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Maybe it's one of those "special" set ups. It's got more magic smoke pumped into it to give those kinds of results. Only explanation with those spec and results.
Oooor, the prop unloads some serious amount in the air, vs when tested statically, and the amps drop dramatically.
Glacier Girl is offline Find More Posts by Glacier Girl
For Sale 1000w Mastech High Current Variable Regulated Dc Power Supply 50v 20a Hy5020e Mastech Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 15, 2008 01:15 PM
Variable Current Control for DC Power Supply? Dave Hederich DIY Electronics 90 Nov 01, 2006 06:28 AM
Yippee! $4.95 Large 25 Amp DC Current Meter at Goldmine hall woo Micro Helis 10 May 05, 2005 12:37 PM
Yippee! $4.95 Large 25 Amp DC Current Shunt Meter hall woo Batteries and Chargers 4 Feb 15, 2005 12:54 PM
Current Supply to DC motor kahlveen DIY Electronics 11 Dec 10, 2004 10:55 AM
