Old Jul 12, 2013, 06:13 PM
hobbypartz is offline
Find More Posts by hobbypartz
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
NEW Fixed Wing 3 Axis Gyro System
Fixed Wing 3 Axis Gyro System Overview (6 min 23 sec)
http://www.hobbypartz.com/73p-3axisg...ing-plane.html
If you desire an aircraft that is easier to fly with more forgiving controls, or just want a little more of an edge while performing 3D maneuvers, a 3 axis gyro is just what your looking for. The Hobbypartz 3 axis gyro offers various benefits for the radio control pilot and delivers quick response. Stable flight is achieved in the enhanced stability mode. The gyroscope automatically adjusts to compensate for ailerons, elevator, and rudder. This also enhances the wind resistance of the aircraft and reduces speed failure and softens stall characteristics to allow for stable confident flight. 3D flight maneuvers such as inverted flight, knife edges, and prop hanging becomes easier with the assistance of the gyro. The independent gyro gain adjustment potentiometer and the algorithm software for gyro gain allow this unit to perform at its best automatically. Activating and de-activating the gyro can be controlled via an assigned switch programmed to your transmitter. All 3 axis parameters can be manually adjusted on the board via the potentiometer dials for rudder, aileron, and elevator.
hobbypartz is offline Find More Posts by hobbypartz
Old Jul 17, 2013, 02:05 PM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
Originally Posted by hobbypartz View Post
https://www.youtube.com/watch?v=scRr...HSsIZvv3Y6G3Gw
The above video on axix pot adjustment is a bit missleading.
The pots are centered at first. You rotate them to the left or the right to change the direction of the gyro reaction to the axis changes.
The amount of sensitivity is set by how far you rotate in the direction you chose.
Regards,
Eric.
Eric Henderson is offline Find More Posts by Eric Henderson
Old Oct 18, 2013, 09:46 PM
speakertoanimals is offline
Find More Posts by speakertoanimals
Joined Jan 2013
Eric: I take it you've used that 3-axis gyro? care to give a quick synopsis on your thoughts on it? And any comparisons to others?
speakertoanimals is offline Find More Posts by speakertoanimals
Old Oct 24, 2013, 10:43 PM
Joined Dec 2005
I only used the rudder flight assistance and it worked fine. Got rid of the waggle.
Eric.
Old Apr 19, 2014, 09:29 AM
EDMUND WEST is offline
Find More Posts by EDMUND WEST
Joined Apr 2014
3axis gyro
Does the gyro prevent you from performing rolls, loops or other maneuvers?
EDMUND WEST is offline Find More Posts by EDMUND WEST
Discussion Hobbyzone TGZ380 Flybarless 3 Axis Gyro System kgd1 Mini Helis 822 Oct 06, 2015 04:24 AM
Discussion Anyone need a 3-Axis Gyro System for Fixed Wings? hobbypartz Nitro Planes 0 Jun 26, 2013 02:04 PM
Discussion $25 FBL Dynam 3GS 3 AXIS GYRO SYSTEM N8LBV Mini Helis 3 May 19, 2013 11:44 PM
Sold Align 3GX nib 3 axis gyro flybarless system viper7 Aircraft - Electric - Helis (FS/W) 0 Feb 24, 2013 11:33 PM
Sold 3 AXIS Gyro for fixed wing. Ranchhand Aircraft - General - Radio Equipment (FS/W) 2 Feb 15, 2013 08:52 PM
