Old Dec 05, 2001, 07:45 AM
AndrewsJr is offline
Find More Posts by AndrewsJr
United States, OH, Cincinnati
Joined Nov 2001
How does a fully symmetrical airfoil generate lift?
Ok, so I understand Bernoulli's (sp?) principle of a reduction in pressure as the velocity of a fluid increases. On a semi-symmetrical and a flat bottom foil it is easy to see that the top surface is longer than the bottom, hence lift is generated.
But....on a fully symmetrical foil the distances are the same, so how is lift generated? I'm guessing the angle of attack of the wing has something to do with the answer.
Anyone?
Thanks, Jon.
AndrewsJr is offline Find More Posts by AndrewsJr
Old Dec 05, 2001, 08:18 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Angle of attack has everything to do with the answer. Even a flat plate at a positive angle of attack generates lift when moving through the air.
DaveSawers is offline Find More Posts by DaveSawers
Old Dec 05, 2001, 08:30 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Re: How does a fully symmetrical airfoil generate lift?
Originally posted by AndrewsJr
But....on a fully symmetrical foil the distances are the same.....
Yes if you just measure the aerofoil, but no if you measure the distance travelled by the air.
A symmetrical aerofoil only produces positive lift when it is at a positive angle of attack (LE higher than TE).
The airstream splits between top and bottom at the stagnation point which is in front of and below the centre of the nose radius.
The distance 'over the top' is therefore greater than 'over the bottom'.
ChrisP is offline Find More Posts by ChrisP
Old Dec 05, 2001, 08:38 AM
Admiral_Red is offline
Find More Posts by Admiral_Red
Vice President at MultiGP
Admiral_Red's Avatar
San Antonio, Texas
Joined Oct 2001
Reading the replies, you can also see why flat bottomed wing is more efficient at low speeds than a fully-symmetrical...less angle of attack. That is the reason you see alot of electrics and gliders, with a flat bottomed, semi, or undercambered wing, less power and drag for the same lift. On an IC powered plane, you have all the power in the world to fly around a fully sym wing.
Admiral_Red is offline Find More Posts by Admiral_Red
Old Dec 05, 2001, 08:53 AM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Check this out for a good description of how lift is generated.
http://www.monmouth.com/~jsd/how/htm/airfoils.html
or http://www.grc.nasa.gov/WWW/K-12/airplane/short.html
Both have interactive Java applets to help you out and can tell you in very straightforward tems more than you ever wanted to know
Bernoulli and distances over the top and bottom are oversimplistic and often misleading explanations, or fallacies as the NASA site puts it
scirocco is offline Find More Posts by scirocco
Old Dec 05, 2001, 08:57 AM
Michael Heer is offline
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
Bernoulli's Principle contributes only in a slight way to the generation of lift. The reason things fly has much more to do with Newton's third law of motion: that for every action there is an equal and opposite reaction. Rockets lift off as an opposite reaction to all that energy going out the bottom. As pointed out above a plane's angle of attack is very important in the generation of lift. A few positive degrees of angle causes the air to be pushed down at the back of the wing and the opposite reaction is that the wing is pushed up. As a plane develops more speed the force becomes greater and the elevator can be used to cause the whole plane to point up more and increase the angle of attack. With sufficent speed (power) you can go vertical. That is why fighter jets can fly with such short wings, lot's of power/speed. To high of an angle of attack for your planes speed and the adhesion of the air over the wing surface is broken and your plane stalls as it loses the downward push of the air which generates the upward push on the wing.
By the way the Bernoulli Principle assumes that the split ait from the front of the wing has to get to the rear of the wing at the same time whether it goes over the top or the bottom of the wing and thus with the correct airfoil generates lift. That assumption doesn't check out. Hope that helps. Mike Heer
Old Dec 05, 2001, 09:05 AM
PaulF is offline
Find More Posts by PaulF
PaulF's Avatar
Twin Cities, MN
Joined Aug 2001
>>you can also see why flat bottomed wing is more efficient at low speeds than a fully-symmetrical...less angle of attack<<
So, would this explain why two similar planes (both with identical gearing, motors, batteries) have different flying times? My 24 oz flat-bottomed trainer flies a lot longer than my 18 oz symmetrical-wing acrobat plane. It appears that I need more throttle to keep the symmetrical plane aloft, whereas, I can dramatically cut the throttle on the flat-bottomed plane and it retains its altitude.
PaulF is offline Find More Posts by PaulF
Old Dec 05, 2001, 09:18 AM
San Antonio, Texas
Joined Oct 2001
Despite all the hoopla about airfoils and the like, when a model gets small enough, it really does not perform like a full scale would. You can scale down the airfoil, but you can't shrink the air molecules that you fly in. I once flew my rudder and elevator trainer with the wing backwards, trailing edge forward to prove this point. Funny thing is, it really did not seem to care too much about the wing being backwards in flight. Floated in for landings, and generally flew fine.
James
Old Dec 05, 2001, 09:50 AM
marcus is offline
Find More Posts by marcus
eschew obfuscation
Far north Dallas, Texas
Joined Oct 2001
Did I pull up while inverted?
James
Your .sig somehow seems appropriate at the this moment. ;-)
marcus is offline Find More Posts by marcus
Old Dec 05, 2001, 10:14 AM
San Antonio, Texas
Joined Oct 2001
When you have been flying for 20 years, you tend to do some silly stuff for kicks. I only performed the high speed inverted landing once, didn't have the power for a go around
Old Dec 05, 2001, 10:45 AM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Originally posted by Michael Heer
Bernoulli's Principle contributes only in a slight way to the generation of lift. By the way the Bernoulli Principle assumes that the split ait from the front of the wing has to get to the rear of the wing at the same time whether it goes over the top or the bottom of the wing and thus with the correct airfoil generates lift.
I thought that Bernoulli only established the relationship between air velocity and pressure, or am I wrong ? I didn't think that he was at all involved with lengths of streamlines over aerofoils. But please correct me if I'm wrong.
When I was at university in the mid/late 60's studying Aeronautical Engineering, we spent ages on the Joukowski transformation of the pressure around an aerofoil into a circle. I guess Joukowski must be completely out of fashion now as I have never heard anything about this ever again ! And oh all the hours on boundary layer theory. And every time I stir my coffee I still think of free vortices and forced vortices.
If you tell me that Newton is more relevant I believe you. At least he and Reynolds were British, God bless them !
No wonder I fled the insanity and joined the car industry.
Old Dec 05, 2001, 11:07 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Searching for "symmetrical"
This is a popular subject... there's 5 threads on it in Modeling Science.. search for "symmetrical".. to avoid re-inventing old wheels..
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 14, 2015, 03:07 PM
ahmet tumer is offline
Find More Posts by ahmet tumer
Joined Dec 2015
There is a great article explaining the generation of lift based on circulation concept. The effect of shape and angle of attack is well explained. The last three pharagraphs explain the theory behind the generation of lift; in the last part you can find the example for the symmetrical case.
You can read the article: How does an airfoil generate lift?
ahmet tumer is offline Find More Posts by ahmet tumer
Old Dec 15, 2015, 09:53 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Considering the last time this thread was posted in was 14 years ago...
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Dec 15, 2015, 10:49 AM
bandetlol is offline
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
That was his first post too.
Maybe he was just frozen in a glacier
bandetlol is offline Find More Posts by bandetlol
Discussion is fully symmetrical airfoil same as profile? subarus Electric Plane Talk 20 May 04, 2007 04:23 PM
Question Does a symmetrical airfoil produce any lift? Hogster Parkflyers 30 Jul 25, 2004 12:58 AM
How does changing thickness effect airfoil characteristics? Joel K. Scholz Modeling Science 3 Jul 02, 2003 07:51 PM
How does everyone store their planes? garyc Beginner Training Area (Aircraft-Electric) 30 Dec 07, 2001 09:05 AM
How does this all work? Teamairplane Electric Plane Talk 5 May 27, 2001 05:20 PM
