Old Jul 10, 2013, 09:40 PM
microairman1 is offline
Find More Posts by microairman1
Team Heads up RC
microairman1's Avatar
United States, IL, Waukegan
Joined Sep 2012
DTF High Wing Aerobatic
this is my aerobatic scratchbuilt plane. it is a version 3(version 1 and 2 had a kfm-3 step) with a kfm-4 airfoil, I think the maiden should go well.it is 4ch with 4servos and the ESC.it is gonna use a turnigy aerodrive 2836 950kv on 3s with an APC 10x7/11x7.it is my first time really painting a plane and I don't think it turned out to bad so let me know what you think. thanks for looking.
microairman1 is offline Find More Posts by microairman1
Old Jul 11, 2013, 10:45 AM
Team Heads up RC
Joined Sep 2012
motor should be here today so I can get a remaiden!
Old Jul 11, 2013, 11:36 AM
iceburg47 is offline
Find More Posts by iceburg47
iceburg47's Avatar
United States, UT, Orem
Joined Jan 2006
Looks good; far better than my first paint job.
In going for aerobatics on a high wing did you use much down thrust on the motor?
iceburg47 is offline Find More Posts by iceburg47
Old Jul 11, 2013, 11:56 AM
Team Heads up RC
Joined Sep 2012
about 3 degrees down and 3 degrees right.
Old Jul 11, 2013, 12:09 PM
Team Heads up RC
Joined Sep 2012
so....maiden went ok but it has a problem I cant figure out. when I go to give it right aileron it rolls about to 45 degrees and then just slides its tail to the side and no controls help it.it does the same with left aileron. any ideas how to fix it? I already tried aileron differential.
Old Jul 12, 2013, 06:07 PM
JimStanmore is offline
Find More Posts by JimStanmore
Changing one life at a time...
JimStanmore's Avatar
United States, NJ, Pemberton Township
Joined Aug 2010
When you say "slides to the side" do you mean it yaws in the plane of the banked wings or the plane of the wings before the bank? I am also thinking that if no control has an effect, the control surfaces are too small. At a quick glance, the horizontal stabilizer and elevator look sort of small.
My 25" WS su-26 has a 12" elevator.. Wing chord at root is 7-1/2" at root, tapering to 5-1/2" at tip. Horizontal stabilizer chord is 4-1/2" and 2-1/2" of that is elevator. That makes the horizontal stabilizer about 50% of the WS and the HS chord about 60% of the wing chord. The elevator is over 50% of the hs. The vertical stabilizer is 6" from the bottom of the rudder to the top and 5" long. The rudder is 3" or 60% of the 5". You might not have enough stabilization from the tail surfaces and enough control authority from the elevator and/or rudder.
You might ask on the thread you got the plans from. There are frequently issues with tail/nose moment, relative size of the various surfaces, incidence, etc. that have been worked out through trial and error by the designer.
Design links that might provide some help:
http://www.rcgroups.com/forums/showthread.php?t=1554685
http://www.rcgroups.com/forums/showthread.php?t=1788733
http://www.rcgroups.com/forums/showthread.php?t=1444763
http://airfieldmodels.com/informatio...rcraft_design/
EDIT: Just looked at a Super Decathlon three-view and the HS is only 27$ of the main WS. Looks like a real big rudder, though...
http://images.rcuniverse.com/forum/u...25/By76494.jpg
JimStanmore is offline Find More Posts by JimStanmore
Old Jul 12, 2013, 06:28 PM
Team Heads up RC
Joined Sep 2012
hey jim,
it is complete scratchbuilt,so no plans. I am going to make my rudder bigger(by about 35%) and see if that helps.it has plenty of elevator and aileron control(completely aerobatic) but the rudder is a little anemic. so I will see if that works.
Old Jul 15, 2013, 02:28 PM
Team Heads up RC
Joined Sep 2012
ok so over the weekend I made a bigger rudder for it. and it works perfect it is very aerobatic.if my dad gets home early today I am hoping to get some video to post here so we will see.
Idea The H-Wing Aerobatic Flying Wing: Knife Edge Loops, Anyone? surfimp Slope 52 Dec 26, 2013 10:47 PM
Build Log Ribbed wing 3d DTF foamie: Skeeter vinnieg Foamies (Scratchbuilt) 37 Sep 14, 2013 10:37 AM
Discussion Looking for high wing tail dragger aerobatic plane clive_m Electric Plane Talk 29 Dec 13, 2012 01:36 PM
Question High wing slow capable aerobatic trainer! boss351 Parkflyers 27 Nov 09, 2003 11:39 PM
