Old Jul 10, 2013, 12:49 PM
Triggerhappy is offline
Find More Posts by Triggerhappy
United States, NC, Zebulon
Joined Apr 2009
using reflective tape on wings?
When flying late afternoons I tend to become disoriented, so I went to ®Michaels (yes, I know it's a "girly" store, but I've utilized it many times for rc, bowery, and even BLACK POWDER handguns!)
Anyway, I got me some very blingy reflective tape for my wings' leading edge. I ran it all the way across, except for the last panel (where it starts to bend too sharp).
It's like a "diamond studded" pattern that sparkles in spectrum colors. Hadn't had a chance to fly with it yet.
Will this have a negative effect on the foil radius? I know these foils are highly engineered, with very small changes making big differences.
**** the tape is 19mm wide x .10 mm thick, and centered on tip of leading edge (equal amounts showing on top and bottom) ******
Triggerhappy is offline Find More Posts by Triggerhappy
Old Jul 10, 2013, 12:51 PM
glidermang is online now
Find More Posts by glidermang
Trigger:
I'm sure you will do just fine. Lots of guys put that on their wings.
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Jul 10, 2013, 12:55 PM
Joined Apr 2009
Thanx 'mange,
You caught me before I could edit the post for speling.
As much as I've read about how important the leading edge is to the performance of the wing, I think it may actually help!
Old Jul 10, 2013, 03:15 PM
gtrbaby is online now
Find More Posts by gtrbaby
New Zealand, Waikato, Hamilton
Joined Jul 2011
you don't need to wrap around the just above the centre line onto the top surface....if you can see the bottom part reflecting back at you - you are in trouble!!!
I use two colours - red on the left and silver on the right. - the tape I use is ridiculously thin and light.....
I find on sunny days - when you are in a boomer miles up and away - a flash of red or white can give you an idea of where you are........it has helped me a few times when I have been almost out of eyesight and lost the glider in turns.....
gtrbaby is online now Find More Posts by gtrbaby
Old Jul 10, 2013, 03:16 PM
Joined Jul 2011
also - you only need a strip about 6" long.......its easy to see
Old Jul 10, 2013, 03:41 PM
bbbp is offline
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
Originally Posted by gtrbaby View Post
y. - the tape I use is ridiculously thin and light..........
What tape is it?
BP
bbbp is offline Find More Posts by bbbp
Old Jul 10, 2013, 03:49 PM
Joined Jul 2011
Hi Bob, I live in New Zealand so not sure if you can get it there - its from a big box store - its not branded.... I just stumbled across it in an art isle....
Old Jul 10, 2013, 05:11 PM
Joined Apr 2009
[QUOTE=gtrbaby;25535719]you don't need to wrap around the just above the centre line onto the top surface....if you can see the bottom part reflecting back at you - you are in trouble!!!....[/QUOTE
Maybe I misunderstood or something. The bottom part of the wing us what you'll see, right?
And you're saying to stop the tape at just above the center of the le, correct ?
Old Jul 10, 2013, 05:24 PM
Joined Jul 2011
[QUOTE=Triggerhappy;25536731]
the bottom of the wing....as in the underside of the glider. if you are flying up the right way (which you should be) the bottom surfaces are shaded so wont reflect. the tape goes on the TOP of the wing - from the centreline up.
I only see its use when
you are miles away in a thermal and turning....gives you a visual clue
you are coming home from downwind
Old Jul 10, 2013, 06:09 PM
VintageFan is online now
Find More Posts by VintageFan
a.k.a Frank Campbell
Long Beach, CA, USA
Joined Jan 2007
Definitely on the top.
When the model is at 30 degrees to the horizon or lower you cant see the bottom. What you want is a flash from the top as it's turning. this will give you a visual clue to orientation.
My DLG has neon orange paint on the top surface at the tips. Really shows strongly when it's out and low and in a turn, you get a flash as it rotates.
VintageFan is online now Find More Posts by VintageFan
Old Jul 10, 2013, 06:48 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I only like an inch or two... more is not better. Top surface near the tips. When you circle, it will give a brief "flash flash" at altitude. Definitely a good thing I carried over from my XC days.
Most of my DLGs don't have flashy tape though. I tend to not get them that far out.
tom43004 is offline Find More Posts by tom43004
Old Jul 10, 2013, 08:37 PM
Joined Apr 2009
GTR, VINTAGE, TOM,
Thanx guys, you are so right! Duuuh!
I was thinking, well the plane is "up there", so I will see the bottom.....but I get that the sun won't hit the tape there, and even up high I'll most likely be out quite a but also. I guess I was assuming straight overhead.
The Taboo had a strip of reflective tape at the wing LE, and it came in handy the two or three times I managed to speck it out.
Old Jul 10, 2013, 09:05 PM
Buddy Roos is online now
Find More Posts by Buddy Roos
It's a mere flesh wound!
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
Years ago, I tested all the reflective tapes I could find, including the holographic types that the sailplane accessory companies were selling, on my TD ships in an effort to find the one that gave the best results. I got the best reflections from Chrome Trim Monokote. It's also one of the thinnest tapes I tested. The holographic tapes were very thick.
On my DLGs I use pieces about 10mm wide and 150mm long wrapped around the leading edge near the tips. On a sunny day the flashes are very bright and I've had people ask me if I had strobe lights on my planes. Many times I have lost sight of my plane and was only able to locate it by the flashes.
Buddy
Buddy Roos is online now Find More Posts by Buddy Roos
Old Jul 10, 2013, 09:33 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Buddy, I agree that straight chrome monokote trim is the best. We had an XC airplane at the Great Race many years ago that went missing for upwards of 5 minutes. It was stupid high and our driver took a wrong turn while we were cutting a corner at the limits of visibility. I trimmed the airplane in to a circle, we estimated where it should be and drove there... and four of us got out of the truck and started looking around the sky. After an uncomfortably long time, my spotter picked up a flash and pointed it out to me and we all jumped in the truck and continued. I always put it on stuff I'll be flying high and far now.
Old Jul 10, 2013, 09:38 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
I like a bit on the rudder as well. Helps when circling against background.
Gary
GaryO is offline Find More Posts by GaryO
Discussion Foam wing tape on electric planes? Kimber Electric Plane Talk 14 Mar 12, 2013 12:41 PM
Question What do you use for wing tape on 3 piece wing hog2soar Sailplane Talk 14 Aug 31, 2012 01:28 PM
Discussion Anyone use prism (reflecting) tape? Chris K Electric Sailplanes 9 Jul 19, 2007 09:38 AM
reflective tape on F5B? bwaltz High Performance 7 Apr 16, 2003 01:22 PM
Great prices on reflective tape Sotos Electric Sailplanes 0 May 11, 2002 06:18 PM
