Old Sep 02, 2013, 03:21 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Originally Posted by Kevin Greene View Post
They haven't in my MiG so far---I have about 50 flights on 3S...The rotor in the MiG is well balanced...
And yes, I did the mods to run the Habu @100% without cutoffs---But I haven't run an entire flight at 100% as per the flights in the vids I previously posted---I need to open up the Habu and balance fan in it as an out of balance fan will kill the bearings sooner...
Kevin
What type of balancer does it take to balance a fan? Thatís probably been discussed many times but I would like a link to a good write-up.
RC Man is online now Find More Posts by RC Man
Old Sep 02, 2013, 03:38 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Originally Posted by RC Man View Post
What type of balancer does it take to balance a fan? That’s probably been discussed many times but I would like a link to a good write-up.
These fans are so small that you can't balance them conventionally...NitroCharged has a video showing how to balance these fans...Click on his screen name and you should be able to find the video covering this...In a nutshell---It's trial and error using electrical tape to find the heavy blade(s) and remove material at the hub on the heavy side...All balancing is done with the fan intact and able to run...No removal of the rotor is necessary...After you see the vid you will understand...Here's the link to the vid...And thank goodness for guys like NitroCharged!!!
How to balance a micro EDF! (12 min 51 sec)
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Sep 02, 2013, 07:05 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by Doug Sipprell View Post
ahem....ahem.......
Good advice!! Regardless of the type of Lipo pack used.
RD
Doug have you opened up that cooling hole that the sticker covered?
Originally Posted by RCAV8R13 View Post
Can anyone show how you hook up a 3s battery to the Habu? Do you change the connector?
Kip
You can buy 3S packs from RCBabbel here on the forums, They have the UMX connector and your choice of balance tap.
Update on my Habu.
I mentioned before how bad the balance was on my original fan. Well after getting the replacement fan I got a real shock when I removed the original!
I installed the new fan and it is silky smooth. It is a huge difference in power as well.
I also drilled out the cooling holes in the motor mount area that someone linked here a couple days ago. Hopefully it helps keep the motor cool.
-Brian
kalmon is offline Find More Posts by kalmon
Old Sep 02, 2013, 07:38 PM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Update on my Habu.
-Brian
Stop putting little rocks into your Habu's intakes. It's not nice.
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Sep 02, 2013, 07:46 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Probably from ingesting the massive mosquitoes we have up here!
-Brian
Old Sep 02, 2013, 07:52 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
looks like you have mice living in your habu! wow!
walter3rd is offline Find More Posts by walter3rd
Old Sep 02, 2013, 08:40 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Doug have you opened up that cooling hole that the sticker covered? -Brian
No, I haven't as yet. No indication of motor or electronics overheating, using RCBabble 325, 70C TP packs. 5-1/4 minute flight times the norm, I haven't had a SLVC or LVC "event" as yet. Cleaned up intakes and exhaust tip with some 600 grit silicon carbide paper. Not sure if it really had any effect. The plane flys quite well, thus far, always sans landing gear.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Sep 02, 2013, 11:19 PM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
-Brian
Ingesting mosquitoes made me laugh - that just might be true! Muahaha RC version of bird strikes!
That's a really cool 'sculpture', btw.
Ben
Old Sep 03, 2013, 05:44 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Ben
No it's not... It's in the middle of a large field, so I know I would want to fly between the leg of that thing and likely crash my UMs.... ( well, it's cool!)
RealGambler is offline Find More Posts by RealGambler
Old Sep 03, 2013, 06:40 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Ben
It's not a sculpture it's a scale model! Joel can confirm that.
And RG, yeah that would be pretty cool to try and fly through the legs. I think I'd pay to see the video of that.
-Brian
Old Sep 03, 2013, 06:47 AM
Canada, QC
Joined Oct 2009
Think about it! Somebody could claim that he is the first one to fly an RC model between the legs of a mosquitoe.
Old Sep 03, 2013, 06:59 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Unfortunately it is in Russia. I don't think I have that kind of range or endurance on my Habu!
Link:
http://theawesomer.com/gigantic-mosquito/34818/
-Brian
Old Sep 03, 2013, 10:26 AM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Link:
-Brian
In Soviet Russia mosquito flies you?
Old Sep 03, 2013, 11:42 AM
echoplanar is online now
Find More Posts by echoplanar
echoplanar's Avatar
Lafayette, CA
Joined Aug 2002
Habu vs Mig 15
UMX Habu vs Mig 15 (4 min 8 sec)
echoplanar is online now Find More Posts by echoplanar
Old Sep 03, 2013, 01:34 PM
wslco10 is offline
Find More Posts by wslco10
United States, CA, Thousand Oaks
Joined Apr 2009
Originally Posted by echoplanar View Post
Very nice video, thanks. The Mig looked pretty fast, what battery did you use?
Bob
wslco10 is offline Find More Posts by wslco10
For Sale UMX BEAST 3D with AS3X with 3 batts tsecrist Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Sep 28, 2013 09:44 PM
As3x umx gee bee for a As3x umx beast 3d Tyler83 Non R/C Items (FS/W) 2 Jun 05, 2013 11:44 AM
Sold LOWERED PRICE UMX Sbach with custom as3x w/ 3 batts and charger Drewkc Aircraft - Electric - Airplanes (FS/W) 0 Mar 08, 2013 09:46 PM
For Sale UMX Sbach with custom as3x w/ 3 batts and charger Drewkc Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 06, 2013 10:32 PM
Sold E-Flite UMX Sbach 342 3D (AS3X) with spares kellymacdaddio Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2013 10:36 PM
