Old Nov 17, 2013, 09:07 PM
DaddyBigas is offline
Find More Posts by DaddyBigas
Need less hobbies, more toys
DaddyBigas's Avatar
United States, AR, Little Rock
Joined Oct 2013
Originally Posted by nos482 View Post
saw this somewhere so i thought i would fab one up......helped with the jello.......seems when it gets cold i have more jello with the QX gopro mount cause the rubber is less plyable......so tried this and seems to help as the nitro fuel line doesnt harden up as much in the cold
Very clever. Nice job.
I want a Mobius. I have an 808 camera now. I was getting tons of jello using the QX's mount. Oddly enough attaching the camera rigidly right on the QX (no rubber grommets) eliminated most jello. I wonder if the mobius would be better off rigid?
DaddyBigas is offline Find More Posts by DaddyBigas
Old Nov 17, 2013, 09:39 PM
tware is offline
Find More Posts by tware
tware's Avatar
Joined Nov 2005
I have a 808 as well. If you take some 1" thick foam weatherstriping (sticky on one side) and coil it up inside the QX GoPro cage, then force the 808 into the middle of the coiled foam, it does a really good job of isolating vibration. The adhesive tape on the foam will keep it coiled and stuck inside the cage. My 808 is probably a version 3, decent, but the mobius is so much better in every way.
tware is offline Find More Posts by tware
Old Nov 17, 2013, 09:48 PM
DaddyBigas's Avatar
Joined Oct 2013
Originally Posted by tware View Post
I have a 808 as well. If you take some 1" thick foam weatherstriping (sticky on side side) and coil it up inside the QX GoPro cage, then force the 808 into the middle of the coiled foam, it does a really good job of isolating vibration. The adhesive tape on the foam will keep it coiled and stuck inside the cage. My 808 is probably a version 3, decent, but the mobius is so much better in every way.
Thanks, will try that.
Old Nov 17, 2013, 10:50 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Originally Posted by Rob2160 View Post
Thanks for that, I'll make one of these tomorrow
Found this vid also.
http://www.youtube.com/watch?v=usRE3gLFnOc
Probably the video I learned it from. lol
Shadrack is offline Find More Posts by Shadrack
Old Nov 17, 2013, 10:58 PM
Corona44 is offline
Find More Posts by Corona44
Australia, NSW, Windsor
Joined Apr 2006
Adding a "Quad" Avatar to DX9 display
The new Spektrum DX9 transmitter has the capability to display additional "Avatars" for each model memory.
In stock form the Spektrum software assigns only 1 of 3 Avatars, Fixed Wing Aircraft, Sailplane or Helicopter when you setup a new model, however the DX9 already has all the same graphic files as the DX18 in its firmware, so if you would like to have a nice little QUAD instead, edit your models config file on your Mac or PC and add the following single line of text as shown in RED below.
Here is the first part of my 350QX file but same applies if your flying a Nano QX, Phantom or whatever.
<Spektrum>
Generator="DX9"
VCode=" 1.01A"
Originator="HS309XBxM5v6U0BpwICvhlUMedb0gD"
mmNum=2
bCode=4
PosIndex= 5
Type=Acro
curveIndex= 7
enabXPLUS=Disabled
modelimage=8
Name="Blade 350 QX"
</Spektrum>
<Acro>
Wing=Standard
Tail=Normal
</Acro>
After adding the line, save the file and reload from the SD card to DX9 memory.
Corona44 is offline Find More Posts by Corona44
Old Nov 17, 2013, 10:59 PM
KuyaJon is offline
Find More Posts by KuyaJon
KuyaJon's Avatar
United States, MS, Vancleave
Joined Mar 2012
Hello, first post to the forums... So here goes... A few hundred posts ago there was talk of adding the TM1000 to the 350QX to get more telemetry options. Then the topic faded out. I really want to get my DX9 to tell me altitude and voltage remaining when I am flying. After opening up the quad's frame I see a perfect spot to mount the TM1000 next to the GPS antenna, behind the battery compartment. This would keep everything neatly inside the quad. My question is whether anyone feels the TM module would interfere with the GPS being that close. Does anyone know if the TM1000 creates interference similar to what the GP cameras have been causing with this quad? To my knowledge it is transmitting back to the TX, but I do not know if its transmissions are known to cause GPS issues. I am planning to run the power to the TM from the existing servo pins at the front of the quad, I will just remove the signal wire from the TM data lead to prevent unbinding issues. Thanks for any help!
KuyaJon is offline Find More Posts by KuyaJon
Old Nov 17, 2013, 11:05 PM
DaddyBigas's Avatar
Joined Oct 2013
<Spektrum>
Generator="DX9"
VCode=" 1.01A"
mmNum=2
bCode=4
PosIndex= 5
Type=Acro
curveIndex= 7
enabXPLUS=Disabled
modelimage=8
Name="Blade 350 QX"
</Spektrum>
<Acro>
Wing=Standard
Tail=Normal
</Acro>
Whoa! Excellent tip. Will do that tomorrow for sure. We need an unofficial document to cover all the stuff available via direct editing of SPM files. Hopefully Spektrum will add all this to the DX9 UI someday. Or maybe a PC based SPM editor will pop up.
Will have to see what other images are available for model display.
Old Nov 17, 2013, 11:23 PM
Rob2160 is online now
Find More Posts by Rob2160
Team Armattan
Rob2160's Avatar
Australia, NSW, Sydney
Joined Jun 2010
Originally Posted by fixed3d View Post
Zippy is a little bit longer and thicker but fits well with no mods. Get a solid 2 minute longer flight. Costs $27 shipped.
Thanks for the info, I looked at these Zippys but thought they might be too big.. after reading your post I just ordered 4 - an extra 2 minutes will be just perfect.
From Aus Hobbyking warehouse four of them worked out to $22 each with shipping.
Rob2160 is online now Find More Posts by Rob2160
Old Nov 18, 2013, 12:21 AM
Chargedflyer is offline
Find More Posts by Chargedflyer
It only hurts when I crash!
Chargedflyer's Avatar
Joined Feb 2012
<Spektrum>
Generator="DX9"
VCode=" 1.01A"
mmNum=2
bCode=4
PosIndex= 5
Type=Acro
curveIndex= 7
enabXPLUS=Disabled
modelimage=8
Name="Blade 350 QX"
</Spektrum>
<Acro>
Wing=Standard
Tail=Normal
</Acro>
I'm a complete newb on my dx9 and don't wont to mess this up. I would love to add a quad avatar. Is there any way you can post a YouTube video? or some step by step how to do this? Thanx..
Chargedflyer is offline Find More Posts by Chargedflyer
Old Nov 18, 2013, 03:16 AM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
A couple pics from the other day using the GP3B. Pics taken at 1/2 sec intervals.
Dora Nine is offline Find More Posts by Dora Nine
Old Nov 18, 2013, 08:30 AM
kmj73us is offline
Find More Posts by kmj73us
SPOOOOOOON!
kmj73us's Avatar
Joined Oct 2006
Here they are:
http://www.rcgroups.com/forums/showp...56&postcount=1
kj
kmj73us is offline Find More Posts by kmj73us
SFS75 is offline
Find More Posts by SFS75
Q500 4K, Inspire 1, Typhoon H
SFS75's Avatar
United States, CA, Lancaster
Joined Oct 2005
Beautiful shots!
SFS75 is offline Find More Posts by SFS75
Old Nov 18, 2013, 08:35 AM
live4java is offline
Find More Posts by live4java
Death before decaff
live4java's Avatar
United States, CA, San Bruno
Joined Jun 2013
<snip>
Great information, and all the avatars (along with the methods) are listed in this thread.
Something that's pointed out there is to use something like Wordpad or Notepad++ under Windows, since Notepad will alter the End of Line.
live4java is offline Find More Posts by live4java
Old Nov 18, 2013, 09:46 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
What setting? I stopped using it to take pictures as I hate the distorted look. I usually record at 1080P60 narrow.
Then I just pull pictures out of the video.
Old Nov 18, 2013, 11:03 AM
kmj73us is offline
SPOOOOOOON!
kmj73us's Avatar
Joined Oct 2006
I wonder if the fisheye remover option in the gopro software works on the photos, too?
kj
New Product E-Flite Apprentice S 15e RTF With SAFE Technology.... ChuckTseeker Beginner Training Area (Aircraft-Electric) 8146 Today 01:19 AM
New Product Blade 350 QX Quadcopter, BNF ChuckTseeker Multirotor Talk 137 Nov 02, 2015 06:43 PM
Discussion Blade 350 QX with Video rcpaintfx Multirotor Talk 395 May 13, 2014 12:16 PM
Off Site UMX ASK-21 BNF with AS3X Technology by E-flite sunderll Aircraft - Sailplanes (FS/W) 1 Jun 24, 2013 10:41 PM
